Brake ducts..
CliveH
RE: Brake ducts
Post by CliveH » Thu Jun 01, 2006 5:42 pm
I have a load of bolts left over from fitting mine if anyone needs them...
Clive
Nige_RS4
RE: Brake ducts
Post by Nige_RS4 » Thu Jun 01, 2006 5:45 pm
I'm not sure why we should worry about fitting them on cars that don't have drilled brakes. The Phaeton they are fitted to as standard has non drilled or slotted discs.
I have personal experience of them causing this problem during a typical UK downpour on the motorway, even with my slotted disks! The Phaeton is about 12" higher than the S4. Have you've seen an S4/RS4 with them fitted, the scoop is the lowest point on the car and sticks out undeneath the plastic engine cover thing by about 30mm.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
s4woody
RE: Brake ducts
Post by s4woody » Thu Jun 01, 2006 5:55 pm
when i tried to fit mine i noticed that none of the holes lined up so i never drilled any i just put them back on my shelf..now with what nige has pointed out could the holes be drilled so to keep the ducts upwards and not pointing dwn..mite not pull in so much water that way..
GARTH ROAD MOT CENTRE LTD
020 83353032
Nige_RS4
RE: Brake ducts
Post by Nige_RS4 » Thu Jun 01, 2006 6:18 pm
Woody, did you get the Phaeton backplates too, as the ducts bolt onto these?
p.s. if you point the ducts upwards, you will lose the majority of the cooling effect! I personally think that the best solution is to fit the backing plates in advance (you need to take the disc off to do this) and then just bolt the scoops on for track days (5 min job per side that can be done with the wheel still on).
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
s4woody
RE: Brake ducts
Post by s4woody » Thu Jun 01, 2006 7:02 pm
i got the full kit..ducts and backing plates..i,ll attack this job 1 day just not sure when..cheers nige.
020 83353032
MarkB
RE: Brake ducts
Post by MarkB » Thu Jun 01, 2006 7:49 pm
I'm now wondering if I can be bothered to do it at all, I don't intend to track the car at all...
Mark
RS4ever
Re: RE: Brake ducts
Post by RS4ever » Fri Jun 02, 2006 11:58 am
MarkB wrote:I'm now wondering if I can be bothered to do it at all, I don't intend to track the car at all...
If you are not going to track your there is no point doing it! It will only give you more street cred ;) "hey look at my brake cooling"
Seriously, your brakes will never get hot enough to warrant it on the road.
RS4ever
Re: RE: Brake ducts
Post by RS4ever » Fri Jun 02, 2006 12:04 pm
Nige it will be very difficult to remove the ducts with the discs in place and a real hassle each time.
I have had no problems with mine on wet days. I have slotted discs.
MarkB
Re: RE: Brake ducts
Post by MarkB » Fri Jun 02, 2006 12:16 pm
I decided for the price I might as well give it a go...
Mark
RS4ever
RE: Re: RE: Brake ducts
Post by RS4ever » Fri Jun 02, 2006 12:23 pm
Its fun fitting them at least :D
CliveH
Post by CliveH » Fri Jun 02, 2006 12:25 pm
I just went with the flow and, as you say Mark, for the price...
Clive
Nige_RS4
Post by Nige_RS4 » Fri Jun 02, 2006 12:26 pm
Have you actually tried removing them (the ducts only), as I'm not exactly mechanically minded, but I managed to do it in no time by turning the wheel on full lock and jacking the car up a bit! I would imagine that if you left them on for a while, removing them might ne mote difficult as the bolts could sieze, however just adding them for track days should be pretty straight forward?
Just my thoughts.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Nige_RS4
Post by Nige_RS4 » Fri Jun 09, 2006 2:02 pm
Here are some pics from my camera phone :(
[img]modules/pnCPG/Coppermine/albums/userpics/10231/rs246_norm_IMAGE_014.jpg[/img]
Orange outline is exposed duct from front of car.
[img]modules/pnCPG/Coppermine/albums/userpics/10231/rs246_norm_IMAGE_017a.jpg[/img]
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
MarkB
Post by MarkB » Fri Jun 09, 2006 2:19 pm
I take it the lower picture was taken with the wheels hanging down...
Mark
Nige_RS4
Post by Nige_RS4 » Fri Jun 09, 2006 2:34 pm
Mark, yes, but unless your car has been lowered significantly, it does stick out below the undertray ... just!
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
