Engine / Gearbox Removal
5.0 V10 50v biturbo - 571 bhp
douglas96
Re: Engine / Gearbox Removal
Post by douglas96 » Wed Jul 18, 2018 2:45 pm
Excellent write up and very detailed pictures!
I bet that was a fingers crossed moment when you came to start it after going back together!
Thanks for sharing.
don0301 wrote:
Wed Jul 18, 2018 10:53 am
And if you can do all that....you are a Royal Navy Engineer!
God, hahaha!
Paulm
Post by Paulm » Thu Jul 19, 2018 11:30 am
Awesome :rocker: :rocker:
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
ATinOf
Post by ATinOf » Thu Jul 19, 2018 6:52 pm
Thanks for the comments guys - its really not that bad, there's nothing complex in it - its just a big job
This probably took me about 40 Hrs on and off to get out, which sounds a long time but thats with a fair bit of just looking at it and pondering and photographing every stage, I lost count of how many times I charged the camera! and you should factor in at least 20 cuppas
To put it in perspective I can get the engine and box out of my chevy pick up in about 4 hrs but theres sh##t loads of room in that engine bay!
There are a few tips for putting the V10 back in I will dig out the relevant pics for those and let you guys have them
I also have a list of parts you will need just for removal and refit of this (fluids, bolts, seals) -its an expensive task in itself, I will dig that out later
Underachiever
Post by Underachiever » Mon Jul 23, 2018 9:11 am
Excellent job. The hard bit will be putting it all back together.
wireliner
Post by wireliner » Fri May 03, 2019 2:26 am
massive job done here.
congrats for that :notworthy: :notworthy:
Jim Haseltine
Post by Jim Haseltine » Fri May 03, 2019 8:25 am
I'm part way through the task at the moment, working a couple of hours each evening and a day or so at weekends. Most of my time seems to be spent looking at it thinking "I can see it but how on earth do I get a tool on it?" which means a 2 hour evening is usually about 10 minutes work. Still, it is allowing me to buy more tools without too much protest from my other half - looks like a set of thin wall and a set of shallow sockets might come in useful so they're next on the list.
Despite the car having been reasonably well cared for prior to my ownership, from what I'm finding it looks like in 110K miles and 8 years it's not had anything done previously that required the engine dropping. Having said that, I've so far got away with one sheared bolt, a stripped out star head and having to cut through the clips on both front exhaust sleeves.
If the weather is reasonable this weekend I'll be moving on to the engine looms.
c3nturi0n
Post by c3nturi0n » Fri May 03, 2019 11:59 am
great work... wish i had more time on my disposal to strip mine.
Keep us posted how you get one and i'm sure it will pay off in the end!
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
Jim Haseltine
Post by Jim Haseltine » Sat May 04, 2019 1:06 pm
Rather than start a new thread that'll duplicate a lot of what's already here I'm being presumptuous and adding a little.
The wiper scuttle panel doesn't come out because it's stuck in by years of grit, wax and whatever the car has been washed with:
And, it comes out UPWARDS next to the screen. To release it you need to get some lubrication in the gap between the plastic and the rubber at the base of the screen - a fine screwdriver run carefully along the gap helps work it in and remove some of the (for want of a better word) mud. Then it helps to have an assistant and to work very carefully. Starting at one end (I chose the left as I had more elbow room) have your assistant pull the panel forwards horizontally towards the front of the car. They won't move it more than a fraction at best but it'll widen the gap. Then with a wide but thin prising tool and something to spread the load on the screen (very important unless you want to pay for a new screen) insert the prising tool in the gap between the plastic and the rubber at the far end of the panel and lever upwards gently. The panel should release (I won't say 'pop up' because it won't) and you can then work your way slowly further along. Eventually enough of the panel will be free so you can grab it and release the rest of it. Removing it completely is a case of flexing it a bit to get it past the wiper spindles and bonnet hinges.
Oh, and don't attempt the job in a high wind as the bonnet WILL come down on your head a number of times.
Post by bam_bam » Sun May 05, 2019 10:36 am
Why are you cooking it on the hob?
Jim Haseltine
Post by Jim Haseltine » Sun May 05, 2019 3:31 pm
'cos it was the only flat surface in the house not littered with parts or tools.
Post by bam_bam » Mon May 06, 2019 7:35 pm
Furry muff.
Jim Haseltine
Post by Jim Haseltine » Mon May 06, 2019 10:45 pm
Not exactly the response from my other half. Luckily for my continued possession of certain parts of my anatomy, circumstances (not the least of which is that I have more project cars than Daft Mick) dictate that we have our own places so the only comments so far have been "Holy hell" and pointed questions as to how long I think the job will take.
Well I had a good day on it today and reckon that a few more hours will see it ready for the engine to come out.
Jim Haseltine
Post by Jim Haseltine » Sat May 11, 2019 2:37 pm
So, only the gearbox cable left I think. Everything else is a couple of minutes work - the ecus will be bubble wrapped and strapped to the inlet manifold before I move anything.
However, a massive black cloud, spots of rain and rumbles of thunder mean that's as far I can go until Tuesday.
Jim Haseltine
Post by Jim Haseltine » Wed May 15, 2019 5:11 pm
So Tuesday it was strip this, strip that, remove gearbox cable, remove all but 3 down pipe nuts - 2 because I couldn't reach them and one because it was solid.
Today:
That was as far as I could pull the engine forwards due to a lack of space. You'll notice that this pic was after I'd got the turbos off, which leads me on to this pool of oil which came out of the back of the rh turbo
the inside of which is a tat oily...
and even more oil drained out later from both of them. This is not oil from the turbo drains, it's from the insides of them, as you can see from the the outlet of the rh turbo
There's more float in the rh turbo than the left, enough to see (and hear). I can push the shaft across enough for the blades to touch the housing. It's difficult to measure, but with the shaft pulled across I can easily get a 0.38 feeler gauge between the blade and the housing.
ATinOf
Post by ATinOf » Mon Jun 17, 2019 11:16 pm
Interesting, if i'm reading you right Jim you dropped the exhaust down pipes instead of pulling them off with the engine? I struggled to get those bolts off with the engine out, i'm guessing they were a right bi*$% with the engine in?
Nice job; we need more engines out on the drive - come on guys get your spanners out......
And thats a nice oil tray, I could do with one of those.....
Users browsing this forum: Google [Bot] and 160 guests
