Audi RS6 Performance C7
Jack Falla
Re: Audi RS6 Performance C7
Post by Jack Falla » Sat Dec 17, 2016 9:55 pm
So, after spending £250 per custom spring from H&R to get a 55mm drop I have decided it was a complete waste of money. I fit the springs monday this week and after the advised settlement time of the springs I have achieved only 4mm from the 40mm I originally had fitted.
Today I bit the bullet and bought some Gepfeffert KW fully adjustable coilovers so I can really get the look I am after. Fingers grossed the Non-resonated milltek and KWs should be here before christmas. :jump: :nogarors4:
Lamborghini Squadra Corse
RDC Automotive Group Ltd
Lordes Luxury Car Storage
Lordes Detailing Devision
FEYNLAB CI
Cars & Coffee CI
Jack Falla
Post by Jack Falla » Sat Dec 17, 2016 10:39 pm
Mike - How do I re code the boot to shut on the key, DRL to be 100% on dipped beam, Start stop to always be off and light off instead of on? Any others worth doing??
FEYNLAB CI
Cars & Coffee CI
Post by MikeFish » Sat Dec 17, 2016 11:02 pm
Jack Falla wrote:Mike - How do I re code the boot to shut on the key, DRL to be 100% on dipped beam, Start stop to always be off and light off instead of on? Any others worth doing??
I'll dig the codes out later Jack. I assume you have VCDS or know someone with the cable?
I haven't done the 100% DRL mod but was meaning to look at it as it turns all the way off when the indicator flashes which looks rubbish so I was going to change it to something like 50% when indicators flash.
Other mods I did was to activate the DRL switch off option in MMI (so I can work on the car with the igniton on at night without the lights on).
Also, turn off seat belt warning, stop the handbrake coming on when you open the door (hate when parking and you open the door to check kerb / lines and heand brake comes on), release handbrake with accelerator when seat belt is off and rear lights on with DRLs.
The one I haven't figured out yet is to stop the chime coming on when you open the drivers door when the engine is running (pressing the left steering whell button turns it off temporarily).
Post by MikeFish » Sat Dec 17, 2016 11:05 pm
Jack Falla wrote:So, after spending £250 per custom spring from H&R to get a 55mm drop I have decided it was a complete waste of money. I fit the springs monday this week and after the advised settlement time of the springs I have achieved only 4mm from the 40mm I originally had fitted.
It will look awesome with that kit. I was just in the garage looking at mine and was thinking about fitting the 20mm springs on the front so I can fit the spacers on to bring the wheels out but then thought about your custom rear springs and wondered if that was a better option but would mean losing the rear spacers. Your experience with these custom springs is pushing me to lifting the front slightly to bring the front wheels out more.
Post by MikeFish » Sat Dec 17, 2016 11:09 pm
This is the instruction I found online for the remote boot closing and from door switch (which didn't work until I figured out the next part). Every car I've done so far has already had these settings correct, so just make sure yours are set to these values first:
[Select]
[46 - Cent Conv]
[Coding - 07]
Click on byte 2, bit 2
Tick Comfort operation: Remote control active
[Do It!]
[Select]
[4D - Trunk Elec]
[Security Access - 16]
Input 12345
[Adaption - 10]
Activation using rear lid opening button in remote key - Touch function for closing
Change to ACTIVE
[Do It!]
Once you've checked both of the above items are selected check the following options and change to the values shown if not already set (this is the bit that actually makes it work):
6D – Trunk electronics
Security access – 16 = 12345
Address 6D:4G9 959 107 A recoded (ADP-(4)-Activation using rear lid opening button in remote key-Tap function for closing) from not active to active
Address 6D:4G9 959 107 A recoded (ADP-(3)-Activation using rear lid opening button in remote key-Touch function for closing) from active to not active
Address 6D:4G9 959 107 A recoded (ADP-(4)-Activation using rear lid remote unlocking switch-Tap function for closing) from not active to active
Address 6D:4G9 959 107 A recoded (ADP-(3)-Activation using rear lid remote unlocking switch-Touch function for closing) from active to not active
This will result:
remote opening – long press - touch
remote closing – short press - tap
door switch – short press – tap
Touch = long press is set for opening to prevent accidentally opening the hatch.
I normally mess up on that bit as the option look so similar and the list above is not in the same order as they appear on the screen so it ca ntake a couple of goes to get it all working as it should. I should perhaps make a note of the order and rearange the list above to make it simpler to follow. Just make sure you select the right one each time.
Jack Falla
Post by Jack Falla » Sat Dec 17, 2016 11:22 pm
Thanks Mike. Bloody hell its all a bit confused. I have a friend who is a Audi technician so was hoping he could grab one from the dealership.
50% when indicators are on is a good idea. Also the handbrake!
I can take a picture of how my rear sits, I am running 20mm spacers with them and they are absolutely fine. It is lower it's just not the look I am after. I want it too be practically on the floor. I say practically as I do still want it practical.
If you like the height of mine I'm happy to sell you my custom 55mm H&R rears.
FEYNLAB CI
Cars & Coffee CI
Post by MikeFish » Sat Dec 17, 2016 11:35 pm
It looks confusing but essentially you just need to change 4 things. I can pretty much guarantee the first bit is already set up right.
Thanks for the offer but not sure it's worth the hassle for an extra 4mm. I have 15mm spacers on the rear, surprised you can get 20mm on there.
Jack Falla
Post by Jack Falla » Sun Dec 18, 2016 12:19 am
H&R seem to be convinced that I will achieve the 15mm I am after if I stick with them. I'm just impatient and think I'd rather get exactly what I am wanting with the coilovers. The arch sits on the ridge on the edge of the tire wall. Maybe they are 15mm I've tried so many spacers etc I'm lost with what's actually on the car now
FEYNLAB CI
Cars & Coffee CI
Jack Falla
Post by Jack Falla » Sun Dec 18, 2016 1:38 pm
This is how the rear sits with the custom H&R 55mm springs Mike.
FEYNLAB CI
Cars & Coffee CI
Jack Falla
Post by Jack Falla » Sun Dec 18, 2016 5:26 pm
Also do you know the codes for other changes.
- Handbrake
- DRL
- auto start
Etc etc
FEYNLAB CI
Cars & Coffee CI
Post by MikeFish » Mon Dec 19, 2016 12:04 am
Jack Falla wrote:Also do you know the codes for other changes.
- Handbrake
- DRL
- auto start
Etc etc
Try these:
Parking brake release without seat belt on
[Select]
[53 - Parking Brake]
Code presented by program
[Adaption - 10]
Select from drop down menu
Change parameter
[Do It!]
Disable DRL dim on turn signal
[Select]
[09 - Central Elec.]
Code: 20113
[Adaption - 10]
Channel 3
Set between 5 and 100
[Do It!]
Disable/memorize/invert Start & Stop
[Select]
[09-Cent. Elect.]
[Security Access - 16] (enter security code - 20113)
[Adaptation - 10]
Select Channel 34 and Read
if you subtract 4 from the original value --> Start&Stop always disabled
if you add 32 to the original value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
if you add 64 to the original value --> Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled.
Press Test then press Save
Disabling seatbelt reminder chimes.
Turn off the annoying "Bing bong" when you move the car on the driveway without your seatbelt fastened.
[Select]
[17 - Instruments]
[Coding - 07]
[Long Coding Helper]
Click on byte 0 and in bit 4 you'll see the selectable option: "Seat Belt Warning inactive"
Check this option
[Do It!]
Enabling the Daytime Running Lights on/off setting in the MMI
Adding the option to turn off / turn on the DRLs via the MMI
[Select]
[09-Cent. Elect.]
[Coding - 07]
Click on byte 3 and enable bit 0 (Daytime running lights adjustable via MMI)
[Do It!]
Tail lights on with front DRLs
[Select]
[09-Cent. Elect.]
[Coding - 07]
Click on byte 2 and enable bit 7
[Do It!]
Post by Ian_C » Mon Dec 19, 2016 1:52 am
Jack Falla wrote:Image
Mike, surprised you didn't reply to this - that picture looks no lower than yours which runs 40mm lowering springs?
Jack Falla
Post by Jack Falla » Mon Dec 19, 2016 2:36 am
- Handbrake
- DRL
- auto start
Etc etc
Try these:
[Select]
[Adaption - 10]
Change parameter
[Do It!]
[Select]
Code: 20113
[Adaption - 10]
Channel 3
[Do It!]
[Select]
[09-Cent. Elect.]
[Adaptation - 10]
[Select]
[17 - Instruments]
[Coding - 07]
Check this option
[Do It!]
[Select]
[09-Cent. Elect.]
[Coding - 07]
[Do It!]
[Select]
[09-Cent. Elect.]
[Coding - 07]
[Do It!]
Amazing, thank you mate.
FEYNLAB CI
Cars & Coffee CI
Jack Falla
Post by Jack Falla » Mon Dec 19, 2016 2:46 am
It does sit lower than this, was on uneven surface and it's not a great example. I took a picture today and re-measured. It's sitting roughly 8-10mm lower than my 40mm springs did.
FEYNLAB CI
Cars & Coffee CI
Jack Falla
Post by Jack Falla » Mon Dec 19, 2016 2:48 am
FEYNLAB CI
Cars & Coffee CI
Return to “Readers' Rides”
Users browsing this forum: No registered users and 70 guests
