This is correct, after changing modes you have to release the pedal before the change will happen.FaisalJ wrote:Regarding the delay, I've noticed if I'm already on the gas pedal and switch on sports mode, the sharper throttle response only takes effect after I've completely come off the pedal (so next time I touch it).
Tesco 99 is good stuff!
map wihout C Clean
Re: map wihout C Clean
cheers gents sounds like its as expected then! prob same as standard flash but just less noticeable before...MikeFish wrote:This is correct, after changing modes you have to release the pedal before the change will happen.FaisalJ wrote:Regarding the delay, I've noticed if I'm already on the gas pedal and switch on sports mode, the sharper throttle response only takes effect after I've completely come off the pedal (so next time I touch it).
D
