Clutch pedal, has anyone got to the bottom of problem
R1RS4
Re: Clutch pedal, has anyone got to the bottom of problem
Post by R1RS4 » Mon Jun 16, 2014 8:45 pm
Did they fit the new style or old?
Could check if you still have the receipts;
This is what they have just fitted
A8E2 721 465 BB £68.69
A8E0 721 465. £17.91
Cheap as chips..... But 3 hrs to fit, apparently they have to drop a drive shaft plus 10 bolts and 2 screws, fluid and a tie wrap
RS4 B7 Avant,2007
TonyHayers
Post by TonyHayers » Mon Jun 16, 2014 8:50 pm
R1RS4 wrote:Did they fit the new style or old?
I did hear, but can't confirm, that the clutch return pipe has been revised 7 times since launch.
I was under the impression that clutch return pipe was a gearbox drop job - interested to hear otherwise as significantly reduces labour.
06 Phantom Black Saloon:
^ GONE :cry:
R1RS4
Post by R1RS4 » Mon Jun 16, 2014 9:50 pm
No mate, it's not a gearbox out job, total job £420 inc VAT
They removed a drive shaft to gain access, labour includes checking fault, investigation + road test (launch) undertake repair, recheck with road test + (launch)
RS4 B7 Avant,2007
jaysrs4
Post by jaysrs4 » Mon Jun 16, 2014 10:45 pm
Here we go! Sounds like you're about to get the tools out Jeremy!!
We'll both have to give it a go together!
spikeyboy101
Post by spikeyboy101 » Tue Jun 17, 2014 1:40 pm
In my view the clutch on the RS4 is only good for about 60k miles.
So if your apporaching that figure probably worth just having the clutch and flywheel replaced as well.
I tried to take the cheaper route of just having the return pipe replaced, didnt work and ended up having full clutch replaced - in the end it cost me £400 more than if i just had all the work done from the off.
TonyHayers
Post by TonyHayers » Tue Jun 17, 2014 3:27 pm
Haha. Dunno, clutch related stuff is bit out of reach for me I think. I've had a drive shaft out pretty easy tho when I replaced a hub so maybe. I like a challenge ;)
^ GONE :cry:
TonyHayers
Post by TonyHayers » Tue Jun 17, 2014 3:29 pm
spikeyboy101 wrote:In my view the clutch on the RS4 is only good for about 60k miles.
Yeah. I had my clutch replaced and wish I'd done all hydraulics and flywheel at same time :roll:
^ GONE :cry:
pixsaudisex2
Post by pixsaudisex2 » Tue Jun 17, 2014 5:26 pm
I got some problems coming... and if my usual plans are followed it will be attempted on the drive...(whole clutch)
Sad thing is i would have had a go at this if it was not for the fact i can not even see how to start..
Think im going to try all the pipes first.
Annoys me mind old rs2 all metal pipes ETC such a better idea. Clutches lasting till 150000 miles as well... Blooming plastic and clip in fixings...
TonyHayers
Post by TonyHayers » Tue Jun 17, 2014 6:12 pm
pixsaudisex2 wrote:I got some problems coming... and if my usual plans are followed it will be attempted on the drive...(whole clutch)
Full clutch on the drive? Respect! :bowdown:
How would you drop the gearbox?
Have you got one of those fancy lift things or just axle stands?
^ GONE :cry:
KGRS4
Post by KGRS4 » Tue Jun 17, 2014 6:58 pm
If you have the equipment to do it in the drive then go for it. I stripped my M3 engine out in the street as uncles drive was in use busy as hell 3 months that!
Red B7 RS4 Saloon......That is all!!
spikeyboy101
Post by spikeyboy101 » Tue Jun 17, 2014 10:14 pm
Remeber to buy some replacement manifold studs before you start as you will probably need to cut, retap and replace as they tend to corrode and can't be undone.
The_Coat
Post by The_Coat » Fri Jun 20, 2014 8:19 pm
scaghead wrote:
R1RS4 wrote:
scaghead wrote: Tbh mate...the more I think about it, it makes more sense to get them to do the lot at once. And then it's done,the car has not let me down in 5 and a half years and I am planning on keeping it at least another year as there is no super saloons about barring the c63 which sounds epic,but IMO is not as good as the rs in every day use..
Have you had the new clutch return pipe fitted yet?
Mine had the pedal staying down with the clutch smell, Camberley changed the pipe, and now all ok
It's a 3hr job and it's about £420, apparently the pipe gets hot and the inside wall collapses or swells and becomes restricted so the hydraulic fluid cannot get away.
The new pipe resolves this
Have had the modified clutch return pipe done about three years ago ..not saying that has not failed though as it could have done...
Any news mate??
RS4 Avant - Misano Red
scaghead
Post by scaghead » Sat Jun 21, 2014 8:44 pm
Not yet mate..going in Monday..as said probably going to get the lot done at once..
lengster1
Post by lengster1 » Sat Jun 21, 2014 11:59 pm
I tried return pipe blah blah just bite the bullet and get a full clutch done,I'm pretty sure it would of been cheaper,mine went at 50 k but runs higher power n torque.
ArthurPE
Post by ArthurPE » Sun Jun 22, 2014 12:05 am
I had a new slave
New hose with insulation sheathing
Fluid
Still did it
I think its got to do with the TO bearing guide bushing
Either heat related tolerances or debris/dust or both
Users browsing this forum: No registered users and 211 guests
