This...:mavada wrote:http://audisrs.com/about16043.html&high ... gear+ratioShoppinit wrote:Sounds like the car won't come out of park then.
Maybe your selector cable as come off / snapped.
Can you plug the vagcom in and see what gear the gearbox thinks it is in when you move the selector? Might be an easy fix.
/edit: cat - the first link you posted showed me a cat before you fixed it.
From Doug:
''Common problem is the gear selector switch - easy to see if it is in the gear that it thinks with diagnostics. We see that all the time so best to check that before you change boxes.''
