Should definitely be a green guy.PhilT wrote:Starting to look like a trader Mr Devil....?
Most active forum:
Parts
(25 Posts / 67.57% of user’s posts)
FS: Brand NEW Audi RS4 B7 front Caramic Brake Kit 380 x 38
- MartayMcFly
- 5th Gear
Re: FS: Brand NEW Audi RS4 B7 front Caramic Brake Kit 380 x
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
+1MartayMcFly wrote:Should definitely be a green guy.PhilT wrote:Starting to look like a trader Mr Devil....?
Most active forum:
Parts
viewtopic.php?f=64&t=111733
Gone but never forgotten:
LittleDevil - can you clarify exactly what is in this 'RS 4 B7 €6600EUR kit please...LittleDevil wrote:I can offer special price on that kit to fit on RS4 B7 so 6600EUR delivered to UK with custom spacers and bolts.
Kind Regards
LittleDevil
- Trader (Expired)
Kit contains: - all parts are NEW unusedneilparf wrote:LittleDevil - can you clarify exactly what is in this 'RS 4 B7 €6600EUR kit please...LittleDevil wrote:I can offer special price on that kit to fit on RS4 B7 so 6600EUR delivered to UK with custom spacers and bolts.
Kind Regards
- Audi 380 x 38mm Brake discs Left + Right
- Audi Front Ceramic Caliper with pads and wear sensors Left + Right + Screws for installation
- Audi Front Dustguards Left + Right + Screws
- 2 x Custom Spacers + 2 x longer bolts when installing brake discs
You only need to get 5mm longer wheel bolts when you install that kit.
If you want I can make you picture of complete kit!
Kind Regards
Thanks for that - so no - '1 x custom caliper holders + screws' required then for fitting this to the B7 RS4?LittleDevil wrote:Kit contains: - all parts are NEW unusedneilparf wrote:LittleDevil - can you clarify exactly what is in this 'RS 4 B7 €6600EUR kit please...LittleDevil wrote:I can offer special price on that kit to fit on RS4 B7 so 6600EUR delivered to UK with custom spacers and bolts.
Kind Regards
Kind Regards
Complete picture would be great...
I have 8mm wheel spacers - my wheel bolts are already longer to compensate for the spacers and I think are more than 13mm longer at least than the OEM wheel bolts...LittleDevil wrote:You only need to get 5mm longer wheel bolts when you install that kit.
So if I am reading this correct
Do you have a part number and price for the caliper Custom spacers ?
I am looking to fit a 380mm disc x 32mm not the standard 34mm would these custom spaces do the job? I am not looking at fitting a ceramic setup
RS4 B7 Avant,2007
Those spacers I think are custom/bespoke - i.e. non Audi...R1RS4 wrote:So if I am reading this correct
- Surrey Sam
Rich, if I'm following your chain of thought with those Porsche steel discs. You may not need to worry about spacers as I'm sure the Loba discs are 380mmx32mm and they fit the standard RS4 steel callipers. Worth further investigation and searching though.R1RS4 wrote:So if I am reading this correct
The spacers in this Ceramic kit are to correct the different offset from the B8/R8 bells so they fit the B7 application.
Sam = Ceramic godSurrey Sam wrote:Rich, if I'm following your chain of thought with those Porsche steel discs. You may not need to worry about spacers as I'm sure the Loba discs are 380mmx32mm and they fit the standard RS4 steel callipers. Worth further investigation and searching though.R1RS4 wrote:So if I am reading this correct
Yes Neil,neilparf wrote:Those spacers I think are custom/bespoke - i.e. non Audi...R1RS4 wrote:So if I am reading this correct
This is what he mentioned earlier
They are made from special aluminium. Those caliper cariers are made in one motorsport company in Germany and they sold alot of them already.
It's these that I am interested in
RS4 B7 Avant,2007
Yes Sam spot onSurrey Sam wrote:Rich, if I'm following your chain of thought with those Porsche steel discs. You may not need to worry about spacers as I'm sure the Loba discs are 380mmx32mm and they fit the standard RS4 steel callipers. Worth further investigation and searching though.R1RS4 wrote:So if I am reading this correct
My discs are new all round and I threw the old bells away so do not know the details
But I would like to know if I could put a set together, what it would cost and how it would perform etc and it would help B7 owners going forward
RS4 B7 Avant,2007
So could those spacers be made to space out and correct the offset for a C5 if I could get some bells to fit? a 380mm upgrade would be pretty cool and those mov'it steel discs are cheap!
PS sorry for highjack littledevil, those ceramic kits are an amazing price but still too much for me to contemplate currently. However the aluminium spacers are really cool and I'd have some off you if you can make them to different dimensions.
LittleDevil
- Trader (Expired)
Here are all details. You only need to install like on the picture and use calipers with Original Caliper holders wich are attached on caliper already and + 5m longer wheel bolts. This is actually like that you have 5mm spacer, so if you are on the "edge" already, you need to buy smaller spacer.
Full kit:
Custom Spacers:
RS4 B7 Wheel Hub:
Custom spacers installed:
Disc on wheel hub and spacer:
Also to see fitment of spacer from other side:
Longer screws for discs installation:
Full kit:
Custom Spacers:
RS4 B7 Wheel Hub:
LittleDevil
- Trader (Expired)
Just realized that on the pricture and wrong brake shields/dustguards, they are for steel brake. They are correct ones included.
Kind Regards
Kind Regards
Rich - you are looking for the spacers or the carriers?R1RS4 wrote:They are made from special aluminium. Those caliper cariers are made in one motorsport company in Germany and they sold alot of them already
Do you have a resource or link to those ceramic calliper carriers made by said motor sort company in Germany?
Users browsing this forum: No registered users and 185 guests
