moody warning lights....
cfcdoc
Re: moody warning lights....
Post by cfcdoc » Sun Oct 23, 2011 10:30 am
Shoppinit wrote:It's a cable that contains the key for the software. So the software is freely downloadable, but won't work without a genuine cable. So you can install it on as many computers as you like, but you'll need the cable to connect to the car.
Many thanks.. the site you gave me the link to has a "pro pack" its only a touch more, is it worth it?
She may be big and heavy but its whats on the inside that counts.....
Post by Shoppinit » Sun Oct 23, 2011 11:02 am
I don't think so. The one time I needed the 2x2 adapter I made one up from bits I had lying around.
cfcdoc
Post by cfcdoc » Mon Oct 31, 2011 3:50 pm
ok, the front brake pad warning light intermittently comes on and now the brakes are squeaking, I`ve tried searching online for c5 rs6 squeaky brakes and have found a plethora of explanations from new brakes having a squeal and I need to do several hard brakes to clear films to you need new discs and pads which incidentally were fitted prior to me purchasing the car on the 14/10.
Add to that the airbag light came on but is now off again..its like a tombola when you start this thing up, you never know what lights will be flashing..lol :audibash:
Post by Shoppinit » Mon Oct 31, 2011 3:58 pm
cfcdoc wrote:lots of steam coming out the reservoir though..
Out of the brake fluid reservoir? :shock:
Post by Shoppinit » Mon Oct 31, 2011 4:05 pm
Mine squeel sometimes and make some odd noises when coming to a halt. I just don't worry about it. As long as they work when I need them :)
posterboyj
Post by posterboyj » Mon Oct 31, 2011 6:36 pm
can you find out what make the pads are?
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
cfcdoc
Post by cfcdoc » Mon Oct 31, 2011 7:04 pm
not steam as such..heat haze I suppose, certainly felt hot when undoing the reservoir cap. I assume in answering posterboys question that the pads are OEM.
Maximo
Post by Maximo » Thu Nov 10, 2011 5:32 pm
Bizarrely they can also come on if you've got a problem with the MAFs or a lot of unmetered air getting into your engine (normally when MAFs are not seated correctly). Go figure.
I think that's something to do with how the traction control works, at a guess there is a fuel/air mixture change that reduces power but without knowing the amount of airflow it gives up and doesn't both hence the warning light comes on.
Are maybe the car is just saying, look somethings not right I can't help so slow down. :biggrin3:
R18 GTX Estate > Saphire 2.0i Ghia > R19 16v > Vectra V6 SRi > M3 > RS6 Avant
Users browsing this forum: No registered users and 227 guests
