This is true however you're never ever be colder than ambient (taking pressure out of the equation) so you will not gain any power just keep what you have for longer. So for tuning and power plot purposes this is a red herring.RTS BRAT wrote: The concept is simple, the denser the air the more power, the colder the air less retardation and reveal the true power.
This is a common misunderstanding of what is going on.To prove the concept is easy take a funnel and cut the small end off so that it is the same size a peace of tube. Hold both out of the window in turn and see which has the most resistance. The greater the resistance the greater the air pressure must be.
The larger the leading edge of the funnel the more air is forced into the same space. Try this at 40 and the confirm that Ram air only works at 120mph. admittedly the faster you go the greater the effect, as I stated at the beginning the fans on a dyno only spin at 60 mph.... This is the exact reason that when you tune a turbo car you have to ensure that it receives enough cool air to perform. If anyone purchases the Kit simply do two runs, one with the standard fan set up and one with a fan pointing directly into the duct. I know you will see a difference. On the road you won’t have the issue of air displacement as the air will be uniformly hitting the face of the car. In fact Ricks homemade version should prove the point depending on the shape of his duct!
The force is greater because more air molecules are hitting the larger surface than the smaller one. Pressure is largely irrelevant in this case however yes the air pressure in front of the funnel may be fractionally (and I mean fractionally almost too small to measure at road speeds) all that happens is that excess air will spill out over the edges of the funnel rather than be compressed. The assumption that a big scoop funnel will increase pressure is based on the fact the air has no other option on where to go but this is false.
Air like most things doesn't like being compressed and will in preference move somewhere else if it can. Now a funnel will taper down to a narrower point and what will happen here...
It's classic example of a venturi effect - instead of what you may think would happen (the pressure increasing) the air instead flows faster. This faster air will have a lower pressure than what you started with so what you end up doing is causing a reduction in pressure by having a big funnel.
This is why cars have a large airbox as the idea if for the air to slow down and gain some pressure. If you have like in the RS4 an airbox with multiple air intakes it's not really possible for the pressure to increase as it'll just spill out into the other air intake feeds.
As for the fans being closer - thats more down to air losing speed after the fan. Move the fan closer the air will be travelling faster when it hits the airbox intakes.
So given that CAI won't add numbers (just maintain them) and the ram air is of marginal benefit at very high speed I can't see how on face value that this will add 30 odd hp with 60mph fans.
