Puff of smoke on startup
Nobby
Re: Puff of smoke on startup
Post by Nobby » Tue Aug 07, 2012 10:43 pm
I doubt it would be a turbo then, as your entire inlet and intercoolers would be covered in oil. Also unless the inlet manifold is extremely poorly designed you wouldn't get oil vapour or pools of oil into the 1st cylinder only.
Daytona RS6 Avant
imacool
Post by imacool » Tue Aug 07, 2012 10:49 pm
Nobby wrote:I doubt it would be a turbo then, as your entire inlet and intercoolers would be covered in oil. Also unless the inlet manifold is extremely poorly designed you wouldn't get oil vapour or pools of oil into the 1st cylinder only.
Well, that's what I thought. It would be very strange to get oil from intake manifold only into the 1st cylinder.
current: Quartz Grey A6 C6 Avant 3.0 TDI Le Mans
prev:Daytona grey RS6 C5 Avant,Black BMW 320D Coupe (E92),Red Honda Accord 1.8
Post by Shoppinit » Wed Aug 08, 2012 6:54 am
What nobby said. Also, why would it only be on start up if it was the turbo. Sounds like a drip of oil from the valve stem seal. It it's the case then it will fairly rapidly get worse.
imacool
Post by imacool » Wed Aug 08, 2012 1:16 pm
Shoppinit wrote: If it's the case then it will fairly rapidly get worse.
Thanks for reassuring me Shop, I can't wait to get the engine out and fix it... :FIREdevil:
Users browsing this forum: No registered users and 185 guests
