TPMS sensors mass suicide..?
Iain_S4
Re: TPMS sensors mass suicide..?
Post by Iain_S4 » Thu Jun 02, 2011 11:48 am
I've just ordered a new antenna. How does the antenna release from the bracket/holder - had a quick look a few weeks ago but to my shame didn't figure it out then. Its easier to ask than fiddle with it for ages.
pisquano
Post by pisquano » Thu Jun 02, 2011 12:02 pm
neckarsulm wrote:If the system is active i.e. you can access setting via the DIS then the sensors will be working.
To test, after a longish drive, keep engine running and deflate a tyre.
ok so I have a potentially stupid question
if the system is triggered only after a longish drive, then the actually pressure measured of the tyres won't necessarily be accurate 100% isn't it? audi recommends to inflate the tyres at ambient temperature, or you can get wrong levels.
but then, does the system compare the stored levels to the "measured" levels, adjusting the latter to the fact that at that stage the tyres are warm hence there is a difference factor to be removed?
not sure If I made myself clear
"you can be my wingman anytime!"
"bullshit...you can be mine!"
CheeRS
Post by bam_bam » Thu Jun 02, 2011 12:17 pm
The TPMS only warn of a drop in pressure. If the tyres pressures are stored when hot, then when the car cools there will be a warning, ne?
pisquano
Post by pisquano » Thu Jun 02, 2011 12:37 pm
that's why I ask. if stored pressures are with cold tyres, then TPMS compares those to pressures in hot tyres? (higher pressure than real)
CheeRS
almoRS
Post by almoRS » Thu Jun 02, 2011 1:03 pm
Iain_S4 wrote:I've just ordered a new antenna. How does the antenna release from the bracket/holder - had a quick look a few weeks ago but to my shame didn't figure it out then. Its easier to ask than fiddle with it for ages.
Once you pop-out the honeycomb grill just pull the antenna out of the bracket on the cable, then fix the same one back in. It is a single plugged cable.
RS3 Saloon, Merlin Purple, incoming.....
S3 Sportback Black Edition, Panther Black, BBS CHs
Previous:
RS6 C7 Riviera Blue, Carbon Pack, Sports exhaust, BC Forged HS04
C63 AMG Coupe, Fire Opal Red, Performance Pack, HRE P44SC's
RS4 B7 Saloon, Avus Silver, HRE P40s, Tubi exhaust
Volvo S60 R Black Saphire, Evolve Suspension + aerodynamics, BMC
Volvo S40 T4 Standard
Post by bam_bam » Thu Jun 02, 2011 1:17 pm
pisquano wrote:that's why I ask. if stored pressures are with cold tyres, then TPMS compares those to pressures in hot tyres? (higher pressure than real)
I don't understand your point. TPMS is a simple IF THEN statement i.e. IF tyre pressure is lower than stored pressure THEN warning. It doesn't care about temperatures.
The reason Audi ask you to store pressures when 'cold' is this will be the lowest acceptable pressure, a baseline if you will. If pressures were stored when hot then when the tyres have cooled, there will be less pressure, hence a warning.
It is an extremely simple system, it's not rocket surgery.
pisquano
Post by pisquano » Thu Jun 02, 2011 1:36 pm
my point is that if you compare an pressure value of a hot tyre (increased temporarily) with a value when cold (accurate) the comparison is unprecise by definition because of the temporary increase in pressure when running.
but yea, once the tyres have become "cold" again the TPMS will trigger its warning there and then if the value is lower.
anyway there a few things that could go wrong with TPMS: my question is whether VAGcomm can detect each of them: (1) battery out (2) broken sensor (3) broken antenna (4) any combination of 1,2 and 3
CheeRS
neckarsulm
Post by neckarsulm » Thu Jun 02, 2011 8:31 pm
You don't need Vag Com to detect those faults, if any of them occurs, a message is posted in the DIS to that effect.
Trying to deduce which problem has caused the fault message does require VCDS.
As for temp readings, surely VCDS cross references temp with pressure so it can tell sooner if there is pressure loss?
e.g. a 4 PSI pressure loss at the same temp could be read as a 2 PSI loss with an increase in temperature of x
pisquano
Post by pisquano » Fri Jun 03, 2011 9:51 am
OK I see.... but then again I need to do some more testing as the system didn't warn me although I had a tyre less than 3bar minus the stored value
CheeRS
Iain_S4
Post by Iain_S4 » Sun Jun 05, 2011 6:59 pm
Ok, new antenna fitted but still have TPMS fault message in the DIS :( .Stored tyre pressures, took car for a drive etc to no avail. Do you need Vagcom to clear the fault message?
neckarsulm
Post by neckarsulm » Sun Jun 05, 2011 8:37 pm
Iain,
I don't think you need to clear the fault with VCDS as it should check it on start ip.
Did you check with the VCDS that the fault was actually the antenna?
Does the fault come on as soon as you turn the ignition on?
On the last car I changed the aerial it didn't fix the problem and my next suggestion would have been new sensors and then TPMS ecu which others have had to change.
Brooner
Post by Brooner » Wed Jun 08, 2011 6:23 pm
Just repaced my antenna but when i removed the rear mesh a metal clip came out and i can't see were it goes anyone any ideas were it should be clipped
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Iain_S4
Post by Iain_S4 » Wed Jun 08, 2011 9:57 pm
Brooner wrote:Just repaced my antenna but when i removed the rear mesh a metal clip came out and i can't see were it goes anyone any ideas were it should be clipped
That happened to me to - couldn't manage to figure out where it came from :oops: but kept it somewhere. The panel seems to stay in ok without it. If anybody has it figured out please let us know.
neckarsulm wrote:Did you check with the VCDS that the fault was actually the antenna?
No, I didn't have access to VCDS so didn't check. The fault originated when the car was running its winter wheels and as I didn't know how old they were thought a battery might have gone in the wheel sensors. However, it was suggested that the TPMS fault message in the DIS meant it was more serious. When the summer wheels were put back on the fault persisted so without access to VCDS hoped it was the antenna and changed it.
Brooner
Post by Brooner » Fri Jun 10, 2011 6:51 am
Ian
i have Vagcom i can run a test if you like pm me if you would like me to run a test
Brooner
Post by Brooner » Fri Jun 10, 2011 6:22 pm
Got this while trawling the net as my TPMS is still going off after changing the antenna audi had a look and shock horror "sorry sir cant see any thing wrong we have reset the settings so keep an eye on it" fecking fitters there useless are there no mechanics anymore so now it's either all the sensors battery life ruuning out after 4 years or the controler module so i decided to disable the sensors for now untill i change my tyres and then i will replace all 4 sensors so here how to disable the TPMS
select 17 Instuments then adaption Channel then enter 61 now what ever value is there subtract 512 and that should disable the TPMS i will let you know if it stays off as i just did it tonight
Users browsing this forum: No registered users and 193 guests
