Delayed Start on My RS4
Ice_Coffee
Re: RE: Re: RE: Re: RE: Re: RE: Delayed Start on My RS4
Post by Ice_Coffee » Sun Jan 16, 2011 12:19 pm
PetrolDave wrote:
Ice_Coffee wrote:I don't know but according to VCDS I can code the car for the best battery recharging algorithims, based on manufacturer. All the big manufacturers are listed as options, Varta, Bosch etc etc
That only applies to cars with MMI - it doesn't apply to the B7.
Fair enough, I did not look in detail as I did not need a battery !
wolfgang
RE: Re: RE: Re: RE: Re: RE: Re: RE: Delayed Start on My RS4
Post by wolfgang » Sun Jan 16, 2011 5:00 pm
Would condensation in the ignition system not be a possible cause?
2007 RS4 Avant in Mugello Blue + Milltek non-res valved, MRC air filter, MRC remap with silent-mode startup
PetrolDave
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Delayed Start on My
Post by PetrolDave » Sun Jan 16, 2011 5:43 pm
wolfgang wrote:Would condensation in the ignition system not be a possible cause?
There's isn't an "ignition system" in the old sense of the phrase (points, coil, distributor).
There is a plug per coil, each driven directly by a 12V feed from the engine ECUs (4 per ECU). The likelihood of both ECUs and all 8 coils failing and re-starting at the same time (if they didn't the engine would run rough as it wouldn't be running on all 8 cylinders) is pretty close to zero.
B7RSX
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Delayed Start on
Post by B7RSX » Mon Jan 24, 2011 8:46 pm
Hi guys.
Right went out bought new battery. Put it in... delayed start STILL there. Battery didnt do anything.
Got the car on VAGCOM and here's the following codes that come up.
4 Faults Found:
005495 - Right Engine Mount Solenoid Valve (N145): Open Circuit
P1577 - 004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 2
Mileage: km
Time Indication: 0
Freeze Frame:
RPM: 194 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 10.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 10.414 V
012424 - Starter Relay: Electrical Malfunction
P3088 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 8.0°C
Voltage: 11.430 V
005634 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 24.0°C
Voltage: 12.573 V
Anyone shed some light on these codes?
Mugello Blue - Saloon - Black Optics - H&R Spring and Rear wheel spacers - Tubi Exhaust
Ice_Coffee
Post by Ice_Coffee » Mon Jan 24, 2011 11:19 pm
assuming you took this VCDS log after you changed the battery, alot of the issues seem related to a low battery which is to be expected from a new (not yet fully charged battery) further none of your faults have occured enough times to be your actual fault.
The one that sticks out to me is
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
I see no reason why the voltage should be 0 Volts if that was my car I think I might be alarmed at that, as it indictes a possible discontinuity in the power feed to that relay, I would double check the fuses, which is an odd thing to say as normaly a fuse blows and that is the end of it, but I have experienced times where fuses have not quite blown, and have caused issues
adsgreen
Post by adsgreen » Tue Jan 25, 2011 8:17 am
I'd clear the log and try again.
If you look at the starter one the voltage is down to 10v which even under cranking is a bit low. Certainly low enough to cause issues.
Ice_Coffee
Post by Ice_Coffee » Wed Jan 26, 2011 4:59 pm
Now that I have Elsawin I have managed to ascertain that this terminal 30 nonsense is just that, NONSENSE. If terminal 30 was really broken you would know about it as it powers almost everything the driver sees and touches.
Ice_Coffee
Post by Ice_Coffee » Wed Jan 26, 2011 5:01 pm
Im now keenly looking at this starter relay more info and diags to follow
Ice_Coffee
Post by Ice_Coffee » Wed Jan 26, 2011 5:36 pm
OK The relays are situated in the fuse bay, according to the instructions they are driver side, but I think on a UK vehicle it is passenger side, anyway im including a piture of what it looks like, and a picture that details the functions of the relays, I strongly recommend iinspecting relays 1,3 and 4, for evidence of overload, for example burn marks being left on the pins, it would have been really useful if you had spare relays to test in their place.
adsgreen
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Delayed Star
Post by adsgreen » Wed Jan 26, 2011 6:18 pm
Ice_Coffee wrote:Now that I have Elsawin I have managed to ascertain that this terminal 30 nonsense is just that, NONSENSE. If terminal 30 was really broken you would know about it as it powers almost everything the driver sees and touches.
The error is saying intermittent low voltage. This can manifest itself as lots of screwy symptoms.
wonder if an earth point has come loose or something.
Ice_Coffee
Post by Ice_Coffee » Wed Jan 26, 2011 8:14 pm
I hear what you are saying but if the entire dash was intermittently dying he would have posted that, but that would be the result of an intermittent terminal 30
adsgreen
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Delayed
Post by adsgreen » Wed Jan 26, 2011 10:41 pm
True but I wonder if the voltage sensitivity of the dash and other systems is lower than the starter system.
I'm no sparky and alot of it is voodoo but I've seen all kinds of wacky things happen on other hardware when voltages start going wonky.
B7RSX
Post by B7RSX » Mon Jan 31, 2011 10:06 pm
Quick update... Had decided to take car the to Audi and get them to fix it... albeit their expensive labour rates!
I know you guys gave alot of input but i honestly have no idea... not a technical person so aint got the foggiest! Really really apprieciate the input from you guys but im just not cut out for the techy side of it.
Anyways the car wasnt starting yesterday sat there for literally 20mins trying to fire it up to no luck! So thought i'd try wiring up a set of jump leads to see if it starts... low and behold it fired up straight away!
As you know i've tried a new battery from GSF and it didnt work when i connected the new battery up... but im thinking now that, that battery was a little smaller then the standard RS4 one in there already so maybe thats why it didnt work then?
Im considering getting identical battery from Audi to see if it will work?
neckarsulm
Post by neckarsulm » Mon Jan 31, 2011 10:16 pm
size isn't as important as the battery's rating
you don't need to get one from Audi as it'll be very expensive but a good quality one from ECP/GSF will be as good
What size did you put in, 075?
adsgreen
Post by adsgreen » Mon Jan 31, 2011 10:37 pm
Interestingly the jump cables attach at the front under the access panel near ecu2 and the battery is all the way in the boot. I'd be tempted to hook up the old or new battery that wasn't working to the jump lead points and try the car. My money is on a dodgy earth or live point in the rear and this is affecting the start.
Once started the car will run fine on the alternator power feed.
Users browsing this forum: No registered users and 259 guests
