led drl's
PetrolDave
Post by PetrolDave » Sun Nov 01, 2009 8:02 pm
aarghesfore wrote:does anyone know if our sidelights have a bulb blown feature?
Yes they do.
almoRS
Post by almoRS » Sun Nov 01, 2009 9:49 pm
Ditto for me. Ordered Wednesday, arrived Friday. Fitted tonight in about 20 mins. Look good. Cheers to Brooner and PRI.
RS3 Saloon, Merlin Purple, incoming.....
S3 Sportback Black Edition, Panther Black, BBS CHs
Previous:
RS6 C7 Riviera Blue, Carbon Pack, Sports exhaust, BC Forged HS04
C63 AMG Coupe, Fire Opal Red, Performance Pack, HRE P44SC's
RS4 B7 Saloon, Avus Silver, HRE P40s, Tubi exhaust
Volvo S60 R Black Saphire, Evolve Suspension + aerodynamics, BMC
Volvo S40 T4 Standard
RS6chris!
Post by RS6chris! » Mon Nov 02, 2009 4:28 pm
Is there not a bulb we can just fit in without cutting wires and putting resistors in etc?? Or am i reading this thread wrong?? lol.
I.m useless at anything electrical but could manage just a bulb swap maybe!!!
P_G
Post by P_G » Mon Nov 02, 2009 6:41 pm
Yep, the bulb from PRI racing (see link somewhere above)
Side light ones may be a bit more tricky; typically enough they are not listed in the RS4 manual, instead if they go you are to seek an authorised dealership to replace them. Yeah; right!
Brooner
Post by Brooner » Fri Nov 06, 2009 2:30 pm
may sound like a silly question but were are the side lights cant see any in my headlight?
PetrolDave
Post by PetrolDave » Fri Nov 06, 2009 2:34 pm
Brooner wrote:may sound like a silly question but were are the side lights cant see any in my headlight?
There's 3 sections to the headlights - indicators on the outside, then the actual headlight (main & dip controlled by a moving mirror) and on the inside the DRL's & sidelights combined.
The DRL bulb is in the centre of the reflector and the sidelight bulb is above it.
scaghead
Post by scaghead » Fri Nov 06, 2009 8:14 pm
might try the fleabay ones as they are only a couple of quid although I do like the idea of proper LED ones even if they are 50 quid.
did you try them bulbs on your sidelights?? if so what were they like? cheers fella
Brooner
Post by Brooner » Sat Nov 07, 2009 11:27 am
Thanks dave on closer inspection i see them now Doh! sry for being thick :)
chrissy
Post by chrissy » Sun Nov 08, 2009 1:56 pm
Been swotting up on this. Thanks to all who have done the hard work.
As soon as I get back from my next trip I will start swapping out the DRL, Side and number plate bulbs. Anybody done the brake lights? I thought that I read a post where it had been tackled before. Tried looking but couldnt find it. Anybody got any links to the brake lights mod?
Chrisc
kandyman
Post by kandyman » Sun Nov 08, 2009 8:36 pm
thanks for all the info, just ordered some from priracing, once done will put pics up.
aarghesfore
Post by aarghesfore » Mon Nov 09, 2009 9:26 am
Scaghead, I did order those blue sidelights off ebay but they had not arrived before I went away on business on Thursday. I won't be able to try them until next weekend when I am back but will post an update and will put some pics up if they are any good. They do look pretty low rent even on the ad so my hopes ain't high!
scaghead
Post by scaghead » Tue Nov 10, 2009 7:35 am
aarghesfore wrote:Scaghead, I did order those blue sidelights off ebay but they had not arrived before I went away on business on Thursday. I won't be able to try them until next weekend when I am back but will post an update and will put some pics up if they are any good. They do look pretty low rent even on the ad so my hopes ain't high!
cheers fella, even though they are low rent you never know. :)
aarghesfore
Post by aarghesfore » Sun Nov 15, 2009 6:36 pm
Hi, I fitted the blue sidelight bulbs off ebay this afternoon. I think they are pretty good, giving a similar light to the DRLs from PRI. They are very blue when not switched on but it isn't too noticeable as they are so small. Overall I would recommend them. Changing them is a bit like the DRLs, i.e. the passenger side takes about 30 seconds whilst the driver's is much more fiddly. It is a bit easier that the DRLs as they just push back in rather than needing a twist.
I did take some pics in the day but they did not really do them justice, can try at night but as I have done both it won't show the contrast.
Cheers.
kandyman
Post by kandyman » Mon Nov 16, 2009 4:53 pm
aarghesfore wrote:Hi, I fitted the blue sidelight bulbs off ebay this afternoon. I think they are pretty good, giving a similar light to the DRLs from PRI. They are very blue when not switched on but it isn't too noticeable as they are so small. Overall I would recommend them. Changing them is a bit like the DRLs, i.e. the passenger side takes about 30 seconds whilst the driver's is much more fiddly. It is a bit easier that the DRLs as they just push back in rather than needing a twist.
Cheers.
done the same this weekend, will get pics up when ive taken them in the dark, i paid £1.99 with free posting for the side lights. well worth it :D
P_G
Post by P_G » Mon Nov 16, 2009 10:12 pm
I went the slightly more expensive route
http://www.priracing.com/product.php/13 ... ulb--pair-
Should see what they are like in the next few days when they arrive and I get around the fitting them. The PIAA DRl ones are great so stuck to the tried and tested.
Users browsing this forum: No registered users and 1060 guests
