Fitted TT style pedals!!
- mikeyquattro
- Top Gear
- Virdee Autos
- Trader (Expired)
Yep I did all the belts, and water pump, just to be on the safe side.
Wouldn't mind seeing the B7 pedals. Remember your more than welcome to see the steering wheel.
What cosmetic bits you got planned, pm if you prefer
Virdee Autos ~ 07950-526592
i used a pair of brake pedal covers from a manual Phaeton and the accelerator from a TT. You need to trim off a rubber block from the Phaeton pedals and they just slip straight on with a blob of silcone to secure. The accelerator pedal needed to be trimmed by 5mm to take the TT pedal but you can probably get around this by ordering a LHD one which is 10mm wider.RS4_Schumi wrote:nothing to do with the mats - but a second call here for a "how to" on the TT pedalswhich look superb.
HTH
I'll check up on the mats today! Very keen to see the embroidry myself, there was a question mark as to whether it would be possible due to the backing on the mats. Fingers crossed or its a disaster!
Finally got round to fitting these pedals,and i used the lhd accelerater pedal,which went on no problem with a bit of silicone.
No one mentioned what a nightmare it is to get the old pedals off,much harder than the golfs
Happy with the result and i made a bit of a blue peter style footrest to match with some stainless and cut black tape to copy the pedal design.
Sounds dodgy but looks pretty good.
Drive low,park lower
