Air filters ...
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
S4TAN
Post by S4TAN » Thu Jun 14, 2007 7:59 pm
Gonna go with the MRC generic ~380bhp map until you sort out your coolers?
Deus ex machina
buzzard
Post by buzzard » Thu Jun 14, 2007 8:07 pm
i to have been thinking about induction for a while
did the cheese box mod a while ago and it felt a bit smoother but that was when air temps were relativly low
now temps are getting up --- a nice cold unrestricted gulp of air would be a great boost for a turbo'd machine.
has anyone tried through the inner wing or a front fog area mod.
i run the fogless grills to help the intercoolers but not noticed to much help from that either.
i also noticed that one or two of the tuned boys have silver foil covered induction piping to reflect under bonnet heat away--nice touch.
cool charge air means better volumetric efficiency and more power.
S4 B5 long gone
S4 B8 Stage 2
Ads4
Post by Ads4 » Thu Jun 14, 2007 8:20 pm
S4TAN wrote:Gonna go with the MRC generic ~380bhp map until you sort out your coolers?
Customs gotta be the way to go. With the injectors and pump I reckon I should see just over 400 with my Milltek set-up?
Adam.
MRC B5 S4 Avant.
S4TAN
Post by S4TAN » Thu Jun 14, 2007 8:25 pm
I'd have thought so with your exhaust Adam - nice.
Deus ex machina
S4TAN
Post by S4TAN » Fri Jun 15, 2007 1:56 pm
seriously though i have thought about this for a while and if u have a standard untouched air box you can run an air feed into the bottom of it from the front IC grill area..
if you take out a headlight you will see the space and make it fit into the bottom of it feeding in cold air..
Woody - I've thought about this many times too - but never got round to a serious attempt at doing it... until today:
... took my headlight out and removed the D/S bumper grill ... with RS4i/c's theres just NO WAY you can route a hose from the air-box through to the bumper grill area (unless the hose diameter is about 1cm, which would be pointless!) ...I note in your photo you had the stock S4 i/c's in ... maybe able to do it with these in but not RS4 i/c's ....
Deus ex machina
MarkB
Post by MarkB » Fri Jun 15, 2007 2:02 pm
I wonder how much more space there is for this sort of mod if you are running the FMIC? Should give loads of space!
Mark
S4TAN
Post by S4TAN » Fri Jun 15, 2007 2:12 pm
Maybe ... but all the FMIC installs i've seen end up having the 2 big pipes in and out of the i/c each side which seem to fill the area where the stock i/c's used to be (i've seen one where the bumper grills wouldn't fit back on because of these pipes)
Deus ex machina
h8cak
Post by h8cak » Fri Jun 15, 2007 3:54 pm
Yes the mrc FMIC takes up the space where the grills go so they can not be replaced after fitting!!!
Wide Body S4
Dan_Gliballs
Post by Dan_Gliballs » Fri Jun 15, 2007 4:33 pm
Has anyboy on here fitted Aquamist Water Injection to a fairly stock S4 yet? ;)
jimbogrey
Post by jimbogrey » Fri Jun 15, 2007 4:40 pm
Having owned the S4 now for 18 months I think i can safeley say that the biggest factor affecting performance is the intake temperatures. the difference in power could be as much as plus or minus 25-30BHP, when comparing a fully heat soaked intake to one cooled fully after say 5minutes of wide open throttle. In my opinion fully insulating the visible intake components, before the MAF is a waste of time. most heat soak occurs when at idle or 0% throttle when coasting. the major metal component's heat up. i am of course refering to the y pipe, the turbos and the intercoolers and to a lesser degree the bi-pipe or similar and the intercooler hoses, not too mention the DV's.
So in real world driving there must be a precise amount of time after which internal engine bay components will return to external ambient temperatures after WOT driving. I believe that this takes far longer than most people realise.
I have considered whether it would be possible to speed up this process or even go below ambient external temeratures by installing a compartment containing " Dry Ice"( frozen carbon dioxide) in the air box, this i would have thought would greatly reduce intake temperatures or at least return them to ambient more quickly.
but there again I have just returned to the office after a lonfg lunch and may just be pissed!!!
Shoot me down
jimbo
Dan_Gliballs
Post by Dan_Gliballs » Fri Jun 15, 2007 4:46 pm
jimbogrey wrote:Shoot me down
S4TAN
Post by S4TAN » Fri Jun 15, 2007 5:18 pm
Agreed ... the air moves so quickly through these parts that i don't think inssulation will make much difference - however hot they get.
Nice idea - but don't think there's anywhere near enough room in the air-box to fit anything ... and it would impede the flow of air to the filter if you did mange to.
h8cak - how are you getting on with the S-Flow? (that has an ITG filter element doesn't it?)
Deus ex machina
s4woody
Post by s4woody » Fri Jun 15, 2007 5:54 pm
or you could always buy my RS4 coolers ... :jump:
GARTH ROAD MOT CENTRE LTD
020 83353032
S4TAN
Post by S4TAN » Fri Jun 15, 2007 6:14 pm
Didn't you install them? Or did you take them out before you sold the car?
Deus ex machina
MCB
Post by MCB » Fri Jun 15, 2007 6:25 pm
s4woody wrote:
i think you miss understand..
Your dead right for some reason I had the way the airbox works upside down, only had this apart so many times :!:
Reckon it is a sound idea Mate and with what has been said will only work with the standard IC's :thumbs:
S4B5 Avant
