engine temperature
The part numbers for the Coolant Temp Sensor can be found at the end of this thread:
http://rs246.com/index.php?name=PNphpBB ... ic&t=54533
I changed this on my car recently, the sensor was faulty (error logged in VAGCOM) but the gauge was showing the correct temp so this may not be your problem. I believe the ECU uses this sensor but the gauge must use a different one.
fletchie55
Blue_Thunder
- Top Gear
Blue_Thunder
- Top Gear
A word of warning, the replacement part number in the link didn't fit my 1998 S4. The sensor used on mine uses a different plug to connect it. Not sure if this applies to all pre-facelift cars.richs4 wrote:The part numbers for the Coolant Temp Sensor can be found at the end of this thread:
If anyone reading this needs the replacement sensor mentioned in the other thread... PM me!
fletchie55
my gauge sometimes reads 60 sometimes more but never 90, but if i use the climate control to go into channel 51 i can see it from cold go up to 90 and stay there in about 5 mins. So surely my gauge in the dash is faulty and not the sensor as channel51 would show low.?
this has always been the same since i bought the car too.
S4 B5 - MRC
No, one channel on the sensor appears to be working so you are getting a good reading on the ECU but the other is duff so the gauge is reading wrong.oliew wrote:Mark, ah so the sensor must be working ok on mine then, the dash gauge must be at fault.
Ol
Shame is I never logged my ECU reading before changing my sensor to know if that side of the sensor was fine or not. Car ran just the same after the change so I must assume it was OK
Mark
Users browsing this forum: Google [Bot] and 94 guests
