Brake ducts..
DaveP
Post by DaveP » Wed Feb 15, 2006 3:41 pm
You don't have to cut the tops at all, I did it purely to prevent the top part blocking any air to the top of the disc...
I cut pretty much the minimum required from the bottom of the splashguard in order to make it fit.
DaveP...
Audi Allroad - Daily slogger
S1 Exige - Track beast
s4woody
Post by s4woody » Wed Feb 15, 2006 6:24 pm
cheers dave.. :thumbs: :redrs4:
GARTH ROAD MOT CENTRE LTD
020 83353032
paldi
Congradulations
Post by paldi » Fri Apr 14, 2006 9:18 pm
To DaveP - My first post - to congradulate you! I am a Phaeton owner and was offering this as an idea for RS6 guys to cool their brakes. Glad to see the concept works on the S4/RS4. Please try to save a few parts in case us Phaeton owners ever need them, LOL.
paldi
Here's a schematic...
Post by paldi » Sat Apr 15, 2006 3:12 am
Image[/img]
rs666
Re: Congradulations
Post by rs666 » Sun Apr 16, 2006 10:23 am
paldi wrote:To DaveP - My first post - to congradulate you! I am a Phaeton owner and was offering this as an idea for RS6 guys to cool their brakes. Glad to see the concept works on the S4/RS4. Please try to save a few parts in case us Phaeton owners ever need them, LOL.
So will these go on my RS6?
The brake fade is one of the real dissappointments with the RS6, anything to help this would be a real bonus.
CliveH
Re: Congradulations
Post by CliveH » Sun Apr 16, 2006 6:57 pm
rs666 wrote: So will these go on my RS6?
Damon - on the basis that the RS6 calipers and discs fit on the S4 and RS4 with little modification, I see no reason why the Phaeton ducts won't go on your RS6, but I could be wrong!
Clive
Nige_RS4
RE: Re: Congradulations
Post by Nige_RS4 » Sun Apr 16, 2006 7:21 pm
Damon, I wouldn't recommended the ducts for non-drilled/slotted discs, as they can (and do) scoop water up on the S4/RS4 and deposit them between the pad and the disc (might be different on the RS6).
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
CliveH
Re: RE: Re: Congradulations
Post by CliveH » Sun Apr 16, 2006 7:28 pm
Nige_S4 wrote:Damon, I wouldn't recommended the ducts for non-drilled/slotted discs, as they can (and do) scoop water up on the S4/RS4 and deposit them between the pad and the disc (might be different on the RS6).
Agreed, but I think Damon is using the RS6+ (drilled) discs?
Clive
rs666
RE: Re: RE: Re: Congradulations
Post by rs666 » Sun Apr 16, 2006 8:10 pm
Yep, cross-drilled (when I clean them out :wink: )
rs666
Post by rs666 » Tue May 16, 2006 7:52 am
So what were the parts costs? Assuming you need to order the bolts too.
CliveH
Post by CliveH » Tue May 16, 2006 7:59 am
Damon,
Sorry I didnt get to meet you last night.
The Phaeton ducts are about £65 from a VW dealer, but I'm not sure if that includes the bolts too.
Clive
rs666
Post by rs666 » Tue May 16, 2006 8:03 am
No worries Clive, will catch you again.
So what would you estimate for fitting time? Going to APS on Saturday for some Nurburgring prep and thought I might get them banged on. With a proper ramp and workshop what do you think?
CliveH
Post by CliveH » Tue May 16, 2006 8:31 am
Damon,
I fitted mine (for "I" read "shineydave"!) when we changed the brakes.
Whether you use a ramp or not, it's wheels and discs off, but it's an easy job, just a few bolts. The time taken is really down to how quickly you can whip the wheels, calipers, and discs off (I'd say 20-30mins a side, incl fitting the ducts).
On the S4/RS4, it also involves cutting a small piece out of each splashguard in order to stop the disc fouling in this area, but you may not have this issue on the RS6. The only way to find out is to offer it all up and rotate with a disc in place, see where it fouls (if at all) and that's the bit you need to cut out. This will all add to the time of course, if it's necessary.
Clive
MarkB
Brake ducts
Post by MarkB » Thu Jun 01, 2006 3:13 pm
Nige_RS4 wrote:Damon, I wouldn't recommended the ducts for non-drilled/slotted discs, as they can (and do) scoop water up on the S4/RS4 and deposit them between the pad and the disc (might be different on the RS6).
I'm not sure why we should worry about fitting them on cars that don't have drilled brakes. The Phaeton they are fitted to as standard has non drilled or slotted discs.
By the way the scoops are on back order, non available in the country :(
Mark
s4woody
RE: Brake ducts
Post by s4woody » Thu Jun 01, 2006 5:35 pm
no bolts included when i bought mine..there still sittin on the shelf in my garage..(the ducts not the bolts)..
020 83353032
