partnumbers RS6 Brakes on RS4
2.7 V6 30v biturbo - 380 bhp
zeke
Post by zeke » Mon Jun 14, 2010 5:26 pm
Are the brake pads of the RS6 C5 the same as the RS4B7?
CliveH
Post by CliveH » Mon Jun 14, 2010 5:32 pm
They are the same size/shape and are interchangeable between the 2 calipers, but the RS6 pads are harder than the RS4 ones.
Clive
zeke
Post by zeke » Mon Jun 14, 2010 5:39 pm
Thanks, will harder be better for track use?
RS6 BRAKE PAD 4B3698151A $306 USD
RS4 BRAKE PAD 8E06+98151Q $478 USD
PRICE WISE IS BETTER TO BUY RS6 PADS
noodles s4
Re: partnumbers RS6 Brakes on RS4
Post by noodles s4 » Mon Oct 17, 2011 1:19 pm
You may also want to consider the JHM lightweight brakes,they have a very good rep and are well priced. :thumbs:
The key to Immortality is first living a life worth remembering.
Brooner
Post by Brooner » Sun Oct 30, 2011 10:20 am
Here's a complete Install i had done on my old RS4 did the B7 set up froint and rear
http://forum.rs246.com/viewtopic.php?f= ... +RS4+disks
zeke
Post by zeke » Tue Dec 20, 2011 1:47 am
Hello guys,
I don´t know if everybody know its, but the same type of floating disk that we have in the RS4 B5 is the same as the one in the R8, if this type of disk better, why change the original for the one they used in RS4 B7 beside the size that is 360 mm vs. 365mm
Best Regards
:beerchug:
Zeke Gomez
Mexico City
RS4 B5 2002
RS4 B7 2008
RS6 C7 2018
zeke
Post by zeke » Thu Dec 06, 2012 12:37 am
Do anybody knows if we can used the front disk brakes of the new B8 RS4 on the B5 RS4?
Right now I´m using the frotn brakes (caliper and disk) of the B7 RS4
Saludos Mexico
RS4 B5 2002
RS4 B7 2008
RS6 C7 2018
zeke
Post by zeke » Wed Jan 16, 2013 12:24 am
Part number of both front rotors (disks) of the RS4 B8 are 8TO 615 301
The question will be, will it work (plug and play) just like the B7 rotors?
RS4 B5 2002
RS4 B7 2008
RS6 C7 2018
tsunamirs
Post by tsunamirs » Sun May 05, 2013 5:20 pm
Hallo are the RS6C5 plus disks with calipers plug and play on RS4B5 ? Or I shouldGive modify something ?
METALLO VELOCE
RS2 I5 B4 2,2 20v turbo avant 315HP
RS4 V6 B5 2,7 30v biturbo 380HP
zeke
Post by zeke » Fri Aug 16, 2013 7:29 pm
The Audi RS6 C5 have different offset on the rotor to the B5 Audi, so the only ones I know you can used with the same offset are the RS4 B7
I´m trying to find out, if we can used the ones from the Audi R8 V8 the 365 x 34mm
RS4 B5 2002
RS4 B7 2008
RS6 C7 2018
Human Joist
Post by Human Joist » Fri Nov 14, 2014 5:40 pm
From reading this it appears that the RS6 C5 callipers don't actually go straight on then
Post by bam_bam » Fri Nov 14, 2014 6:02 pm
Zombie thread.
MadeiraRs4
Post by MadeiraRs4 » Fri May 20, 2016 5:30 pm
good afternoon,
B7 RS4 discs and caliper serves in RS4B5? or I have to change something? can anyone confirm this 100%.
I'm thinking of buying discs rs4 B7, and then the calipers.
thank you
JohanPettersson
Post by JohanPettersson » Mon Mar 05, 2018 9:31 pm
Have seen the waved disk´s on the 8 calippers, what modell does it come frome ? From what i have found, are they bigger then 365mm or does them fit bolt-on? =)
RS4 B5
// Best regards, Johan
zeke
Post by zeke » Mon Mar 28, 2022 7:13 pm
After many years and miles on my car is been a while since I post something in this forum.
Well is time to change the front rotors on my RS4 B5. I don´t know if I replace it wih the same set up that I have right now (RS4 B7 rotors and calipers), or will it be better to fit them, with R8 rotors
Has anybody tried the B7 calipers, on R8 or RS5 / RS4 rotor 365x34mm
Saludos
RS4 B5 2002
RS4 B7 2008
RS6 C7 2018
