On the road again...
mavada
Re: On the road again...
Post by mavada » Tue Jun 29, 2021 2:08 pm
Thanks all for the input.
See if i can find the missing bracket and its part #
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Gregstv
Post by Gregstv » Tue Jun 29, 2021 8:13 pm
As said also check the rubber grommets are in the inlet manifold where the to pins on the air box fit into. These help hold the back of the air box down.
The other problem I had was the wiring loom had been removed at some stage and not refitted correctly. This was stopping the air box sitting all the way down.
mavada
Post by mavada » Wed Jun 30, 2021 5:13 pm
Thanks Gregstv,
No cell today after clearing faults :biggrin3:
Oh yes, i got the broken light symbol today, checked all lights, all ok.
Not seen it again...
One of those gremlins/punishment neglecting him for 4 years....
Yellow Koni's
mavada
Post by mavada » Sat Jul 03, 2021 2:56 pm
...it seems i cant find the rear koni shocks which are out of production (koni 82-2526sport)
Ive seen the ST X coilovers (budget part of KW) are available for the S6 C5, but not sure if these fit the RS?
The konis arent listed as suitable for the RS6, but they do...
I cant find the FK Silverline X either (height adjustable with koni shocks).
Yellow Koni's
mavada
Post by mavada » Sun Jul 04, 2021 11:10 am
It seems even on eBay the koni sport rear shocks arent available.
They all say numerous available, but when i ask them, they cant get hold of them.
It is koni 82-2526sport (2×)
Maybe someone over here has a contact who has them in stock and from which i can buy them?
Yellow Koni's
mavada
Post by mavada » Sun Jul 04, 2021 7:49 pm
I just came across AP coilovers (also made especially for the RS6 C5), they seem to come from the KW factory.
They do look very similar to the KW's V1.
From what ive read the AP's are galvanized zink plated, where the KW's are stainless steel, which would explain the price difference.
Anyone have experience with those? Quality and ride?
Yellow Koni's
mavada
Post by mavada » Mon Jul 05, 2021 5:21 pm
Managed to get the konis, the 82-2516sport local, the 82-2526sport from France.
Yellow Koni's
mavada
Post by mavada » Thu Jul 08, 2021 12:30 pm
Konis arrived today, now see if i can fit them myself...:)
Yellow Koni's
Post by Shoppinit » Thu Jul 08, 2021 12:33 pm
You'll need some spring compressors.
mavada
Post by mavada » Thu Jul 08, 2021 12:36 pm
Hi Ben,
Yes, dont know if there is a recomendation to which kind or?
I see they go for peanuts.
Yellow Koni's
Post by Shoppinit » Thu Jul 08, 2021 12:38 pm
DOn't think it matter much.
mavada
Post by mavada » Thu Jul 08, 2021 12:41 pm
Ok il will see.
Ill start with the easiest ones, the fronts.
And see if i can re-use the dustboots and bumps, not sure if they fit and in what condition they are.
Yellow Koni's
Post by Shoppinit » Thu Jul 08, 2021 12:54 pm
It's not a hard job, just a bit physical.
mavada
Post by mavada » Thu Jul 08, 2021 12:59 pm
I will use your excellent guide "Bilstein PSS9 installation".
But i wil probably cursing and ranting at times:)
Not sure to use a torque wrench or just by feel?
Yellow Koni's
Post by Shoppinit » Thu Jul 08, 2021 1:58 pm
Up to you. I don't usually bother on suspension. I just do it up bloody tight.
