VCDS Cable
Re: VCDS Cable
Post by Shoppinit » Tue Jun 02, 2020 8:34 pm
Cool. You done your first auto scan?
steve2003rs6
Re: VCDS Cable
Post by steve2003rs6 » Tue Jun 02, 2020 8:47 pm
Ha ha. Not yet. Tomorrow all being well.
Spent most of the afternoon on the instrument cluster.
Been watching Ross-tech videos and you tube videos on how to use.
Just getting familiar at the moment.
steve2003rs6
Re: VCDS Cable
Post by steve2003rs6 » Thu Jun 04, 2020 5:42 pm
Shopp just run first auto scan. A few problems came up. Fuel bank 1 and fuel bank 2
Some others to do with tpms and central locking.
Saved files but cannot see where saved.
Will re auto scan tomorrow and clear faults.
Regards Steve.
HPsauce
Re: VCDS Cable
Post by HPsauce » Thu Jun 04, 2020 5:52 pm
Just a little tip. When clearing faults go into each controller manually that has faults then read and clear them.
I know it's "supposed" (if you have the full version with a genuine cable) to be able to automatically clear all, but in practice I've found that not to be reliable.
steve2003rs6
Re: VCDS Cable
Post by steve2003rs6 » Thu Jun 04, 2020 6:16 pm
Hi HPsauce. Thanks for the info. It is a genuine unlimited Ross-tech cable. Should have “fun” rectifying the faults listed.
Will take a photo tomorrow of the faults info.
Until I get to grips with saving the info.
HPsauce
Re: VCDS Cable
Post by HPsauce » Thu Jun 04, 2020 6:22 pm
To save stuff I tend to use the COPY function then paste the results into a text file (or Word doc) and save it separately.
HPsauce
Re: VCDS Cable
Post by HPsauce » Thu Jun 04, 2020 6:27 pm
And stating the obvious, lots of faults may be quite old/historical.
So when first using VCDS log/save all the faults, then methodically clear them, then scan again and see what has returned immediately. Some errors do.
Then go for a run and check again and save those and clear. And again after your next run.
You'll soon figure out which errors are historical/irrelevant, which are intermittent and which are pretty "hard". Though even some of those aren't significant.
steve2003rs6
Re: VCDS Cable
Post by steve2003rs6 » Thu Jun 04, 2020 6:30 pm
Many thanks buddy. I did save the file. But didn’t paste it.
Just getting familiar with VCDS and a new laptop.
Will get there in the end. Regards Steve.
Ps really impressed with VCDS. Nice piece of kit
mikep99
Re: VCDS Cable
Post by mikep99 » Thu Jun 04, 2020 6:35 pm
The log files should be saved in the installation folder - under logs / scans
Mike
steve2003rs6
Re: VCDS Cable
Post by steve2003rs6 » Thu Jun 04, 2020 6:38 pm
Cheers mikep99.
Will try that tomorrow when I rescan
sweegie
Re: VCDS Cable
Post by sweegie » Thu Jun 04, 2020 7:02 pm
Great. Got that cluster cloned and installed yet? :audibash:
Recycling dinosaurs for fun
steve2003rs6
Re: VCDS Cable
Post by steve2003rs6 » Thu Jun 04, 2020 7:25 pm
Hi sweegie thanks for asking
Cluster stripped to fit the chrome dial rings. To fit the two large rings you have to separate the glass front.
Someone had superglued it in two places. So the glass broke
Re ordered a third cluster with factory fitted chrome dials.
Swopped the glass/dials to the RS6 spare cluster.
Going to remove my original cluster and swop the glass/dials over.
At some point get the original cluster dis display renewed.
Must admit the chrome dials lifts the instrument panel very nicely.
Best regards Steve
Astrosquirrel
Re: VCDS Cable
Post by Astrosquirrel » Thu Jun 04, 2020 10:54 pm
Paying close attention to this thread. Would anyone know of a good cable to use with VCDS Lite?. Cheers.
steve2003rs6
Re: VCDS Cable
Post by steve2003rs6 » Fri Jun 05, 2020 8:35 am
Hi astrosqirral. I only know Ross tech for original cable. But some members on here more knowledgeable than me will be able to help you. Regards Steve.
Mark-RS
Re: VCDS Cable
Post by Mark-RS » Fri Jun 05, 2020 12:07 pm
https://www.ebay.co.uk/itm/USB-Cable-fo ... SwO9Ze2LQq
This will do just fine. The Lite version is for 3rd party cables and this is the one I currently have that works just fine.
Users browsing this forum: Google Adsense [Bot], RS620 and 119 guests
