rs6 c5 rebuild
ian_rs6avant
Re: rs6 c5 rebuild
Post by ian_rs6avant » Wed Jan 29, 2020 8:34 pm
bodyshopnos cracking on nicely with the respray, also the doner car turned up ready to start on the manual conversion! exciting times ahead sonfull steam getting all the running gear refurbed and the doner car stripped. ImageImage
Sent from my SM-G977B using Tapatalk
rs4wagon
Re: rs6 c5 rebuild
Post by rs4wagon » Thu Jan 30, 2020 7:26 pm
ahh thats you,commented on FB under them pictures :) i see you not fooking around,good job!!
DavidRS4
Re: rs6 c5 rebuild
Post by DavidRS4 » Fri Jan 31, 2020 12:40 pm
Going to be immaculate
ian_rs6avant
Re: rs6 c5 rebuild
Post by ian_rs6avant » Thu Feb 06, 2020 7:24 pm
body Shop are flying along cant wait to get it back!ImageImageImageImage
Outtlaw
Re: rs6 c5 rebuild
Post by Outtlaw » Fri Feb 07, 2020 10:36 am
This is getting exciting :nodder:
ian_rs6avant
Re: rs6 c5 rebuild
Post by ian_rs6avant » Thu Feb 13, 2020 8:08 pm
so the works not stopped, been busy still,. new door mouldings arrived from TPS and were dropped at body Shop.
I've also ordered my flywheel for the manual conversion and lead time on that is 4 weeks.
also collected the springs from powder coaters as they were looking a bit worse for wear. front 2 coilovers have been cleaned and painted so they can be rebuilt back up, hoping to get the rears done tomorrow and strip the doner car down. Image
dhali
Re: rs6 c5 rebuild
Post by dhali » Thu Feb 13, 2020 10:07 pm
Nice
ian_rs6avant
Re: rs6 c5 rebuild
Post by ian_rs6avant » Fri Feb 14, 2020 7:32 pm
built one of the coilovers back up today, well chuffed with how they turned out! ImageImage
IchBautAuto
Re: rs6 c5 rebuild
Post by IchBautAuto » Sat Feb 15, 2020 1:51 am
Looking good :thumb:
ian_rs6avant
Re: rs6 c5 rebuild
Post by ian_rs6avant » Mon Feb 24, 2020 3:54 pm
car is still at the body Shop and hopefully see paint this week! I finally found a but if time to strip the doner car down!
rear axle is ready to be dropped first thing in the morning, and I'll split the box from the engine. ImageImage
ian_rs6avant
Re: rs6 c5 rebuild
Post by ian_rs6avant » Fri Feb 28, 2020 7:15 pm
got a big weekend planned on the project. but had a spare hour today so I roughly mocked up the gearbox positioning on my spare engine.
it seems a straightforward job, I am still awaiting the flywheel to be delivered but seems the box will happily bolt straight up making use of 4 holes all ready there, I will then drill the starter bolts out into the new position and that will.make 6 out the original 10 used which would be satisfactory.
but it also seems one of the bolt holes on the sump area can be drilled and bolted, and the other 3 the sump can be alloy welded and drilled so quite confident it will happily work with minimum effort and all 10 bolts will be present.
one thing I disliked about not usning the spacer plate was other people have grinder the block to make the starter fit.
I think I have a solution for this but wont be able to tell exactly till my flywheel arrives and complete the mock up.
so far all I have spent is 400 quid for doner car which I'm slowly selling other parts off so should pretty much recoup.my cash. and a 30 quid spacer plate, and the flywheel which is under £400, some cars have duel mass flywheels which cost more.
bar the mapping I should come well under the 1k budget I set my self for the conversion.
ian_rs6avant
Re: rs6 c5 rebuild
Post by ian_rs6avant » Fri Mar 06, 2020 10:05 pm
so after many months the shell will be back tomorrow from the paint Shop, absolutely blown away with the results. ImageImageImage
DavidRS4
Re: rs6 c5 rebuild
Post by DavidRS4 » Sat Mar 07, 2020 7:16 pm
Looks mint!
ian_rs6avant
Re: rs6 c5 rebuild
Post by ian_rs6avant » Sat Mar 07, 2020 7:33 pm
DavidRS4 wrote:Looks mint!
pictures don't do it justice mate the metallic is insane in the sun really pops
ian_rs6avant
Re: rs6 c5 rebuild
Post by ian_rs6avant » Sat Mar 21, 2020 8:54 am
bit of a update, my landlord were I remt 2 units and run my business from has decided 2 weeks ago they were not going to renew my licence! and we are out in a couple of months! so I have had to stop spending and look for alternative premises which is a absolute nightmare! may end up having to sell up if nothing turns up.
Return to “Readers' Rides”
Users browsing this forum: Majestic-12 [Bot] and 17 guests
