new rs4 with problems , help please
white.akita
Re: new rs4 with problems , help please
Post by white.akita » Wed Jul 05, 2017 2:53 pm
MrHilario wrote:I'm no mechanic, but this may help
viewtopic.php?f=35&t=121483&p=808526&hi ... ak#p808526
Thanks for that, I wonder if I put a one way valve inline with the pipe that goes under the manifold that it may fix the problem. Last thing I want to do is lift the manifold.
Sent from my SM-G935F using Tapatalk
white.akita
Post by white.akita » Wed Jul 05, 2017 2:57 pm
If I unplug the vac line I pictured I can suck air through it so it must have a leak somewhere.
I may squirt some wd40 in it and then use a airline to see where it comes out at ha.
jonytek
Post by jonytek » Wed Jul 05, 2017 9:58 pm
Mate let someone who knows what they're doing take a look or get a proper scan. I'm not sure you're going to solve it by spraying wd40 around.
BUILD THREAD
IG: @bad_rs_4
white.akita
Post by white.akita » Wed Jul 05, 2017 10:22 pm
That was a joke.
I'd rather fix it myself, just some pointers would of been nice as I've never worked on a rs4 before but never mind I will fix it.
No sure the point of this forum when everyone just says take it to a garage to be fixed ha.
rs user
Post by rs user » Wed Jul 05, 2017 10:57 pm
to fix problems on these a Vag Com is really handy
a mittyvac copy at a tenner or so wouldnt go amiss either
you can actuate solenoids and get up to all sorts of mischief with vag-com
i share your pain with d.i.y -i bought one the other day and it would turn over and not start
didnt recieve any advice/pointers-but probably because the normal starting issue is not to turn over at all[had that on my last one]
a lot of folk dont seem to do much d.i.y but others do it all
dougle_turbo
Post by dougle_turbo » Thu Jul 06, 2017 7:51 am
That was a joke.
Lots of people on here carry out their own work, but as has been said, Vagcom will highlight the specific problems. This will allow you to concentrate on the specific area of the engine/system that has a problem.
Its very difficult to give advice when 1. We don't know the exact fault codes (generic scanners don't give enough detail) and 2. By pulling pipes and wires you may well be creating more faults and problems. What people don't want to do is give you duff advice, that damages the car, hence why they keep saying get it scanned properly at a garage (if you don't want to buy Vagcom). You can't easily fix a problem without an accurate diagnosis.
2010 987 Cayman S.
Clio 172 Cup track car "Nicole" aka NV2 Sold
Clio 172 Cup track car "Nicole" aka NV1 - R.I.P
2007 Phantom black RS4 avant - with added ceramics. Sold
2006 Phantom black RS4 saloon. Sold
1990 Black Audi S2 (3B) - full engine rebuild. Sold
1981 Black Porsche 924 Turbo, rescued from under a tree and restored. Sold
white.akita
Post by white.akita » Thu Jul 06, 2017 8:34 am
Thanks for the replys.
I ordered a mityvac and it's supposed to be coming today.
I have the free version of VCDS on a old laptop so I will get the codes read.
But I do know I have a huge vacuum leak somewhere and just need to find it.
pule333
Post by pule333 » Thu Jul 06, 2017 9:30 am
white.akita wrote:That was a joke.
You need to be well established character to not be taken seriously when making jokes :)
If you want to fix your own car, a proper version of Vagcom is essential. Rs4 is no different to any other car in terms of DIY. But you absolutely need to know where to start. There possible 100s of scenarios where vacuum leaks are present.
Also, don't think you should start throwing "point of this forum" card around, it's a sure way to get ignored or alienated.
My point being, the info you provided is not enough to give you sound advice.
The best advice already has been given.
A) take it to garage to get proper diagnosed
B) buy proper diagnostic tool to do it yourself.
And please don't just unplug random lines, cables etc when the car is running..
RS4 B7 aka Vinnie
Jon_J
Post by Jon_J » Thu Jul 06, 2017 11:21 am
There are several points to this forum. If you were after a way of fixing your car without spending any money or using the correct diagnostic tools then yes, I guess the forum is pointless.
A health check is a couple of hundred quid and will most likely tell you the issue. You can then fix it yourself. Buying a cheap version of Vagcom is pointless.
I had a read through this and I am unsure where the vacuum leak has come from? How did you diagnose that this was the issue?
Not knowing the RS4 as you say, how do you know what pipes should have what vacuum? How do you know they don't have a vacuum when being driven, idling is very different.
As Pule333 says, be careful what you write, you come across as someone who bought an RS4 with an issue, doesn't want to spend any money fixing it so joined a forum for some advice, but then when you don't hear what you want to hear describe the forum as pointless?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
white.akita
Post by white.akita » Thu Jul 06, 2017 11:49 am
That's true I bought a rs4 with problems and would like to fix them myself like I have done with over a hundred other cars with help from forums.
I don't need anyone to tell me that it's best to take it to a garage and let them fix it.
I have tried to get codes with VCDS life but it won't connect to the engine controller.
I have a aquantence coming tomorrow to give it a full VCDS scan.
I will post the results and hopefully then someone can offer some help.
white.akita
Post by white.akita » Thu Jul 06, 2017 12:37 pm
My scanner says that the vacuum pump is OFF with the engine off and running.
Anyone know how to turn it back on !Image
rs user
Post by rs user » Thu Jul 06, 2017 8:07 pm
as i said normal Vag Com is no good-you need the modern hex can one-mine is a copy type so wont update but plenty good for what i need
try this for codes
vacuum pump only runs when needed-there is a switch on line /servo
https://www.google.co.uk/url?sa=t&rct=j ... Var9tSD5jQ
and this for insight
https://www.google.co.uk/url?sa=t&rct=j ... 37lQqhNzsg
white.akita
Post by white.akita » Thu Jul 06, 2017 9:36 pm
thanks very much, if i go for a ten minute drive then disconnect a vacuum pipe there is no vacuum in there whatsoever. everything i have read within this website and other websites say there should be vacuum in the system after the engine has been run for a short period. i have just ordered VCDS 17.1 so hopefully that can pinpoint the problem.
white.akita
Post by white.akita » Thu Jul 06, 2017 9:55 pm
thanks for them links, they seem to be exactly what i needed, a mityvac and VCDS is being delivered tomorrow so i can make a start.
white.akita
Post by white.akita » Fri Jul 07, 2017 4:12 pm
I have done output tests and basically everything to do with vacuum failed.
Users browsing this forum: Google Adsense [Bot] and 284 guests
