Next RS6... this time in Black. Does anyone know BX**?
bilko1
Re: Next RS6... this time in Black. Does anyone know BX**?
Post by bilko1 » Thu May 18, 2017 1:29 pm
If you do strip it as a donor can I have dibs on the TCU please?
RS2
Post by RS2 » Thu May 18, 2017 1:39 pm
simonpoulton wrote:
Thu May 18, 2017 1:03 pm
If it helps, the proper audi harness (black, nicely taped up etc) fits into that red adaptor, then the yellow, green and blue segments all combine and fits into the stereo.
Thanks. I'll grab 10 minutes this evening to see what's going on with it and probably remove the external connector.
G pat wrote:
Thu May 18, 2017 1:13 pm
I for one would like to see the internals of the box, we wait with baited breath...
Just been through you're old thread, great stuff.
I'm as interested as anyone else as to what's happened.
I've just spent 25 minutes chatting to Chester Transmissions again about possible causes, how to diagnose from my current stand point, what to check and prices for replacement parts.
The last time I did this, I wasn't married and didn't have two sons... life has changed a little ;)
MG
Post by Shoppinit » Thu May 18, 2017 2:12 pm
Look on the bright side... once this car's finished you probably won't be married again.
simonpoulton
Post by simonpoulton » Thu May 18, 2017 2:18 pm
So it will be easier now - two sets of little hands for the fiddly bits and someone to help lift the damn gearbox!
Past: R56 Mini Cooper S
RS2
Post by RS2 » Thu May 18, 2017 2:27 pm
No problems :thumb:
Oh I know how lucky I am with my wife. All of my vehicles will go before she and the boys do.
The eldest already wants to help 'Daddy' whenever possible with my projects and both are very mechanically minded.
MG
RS2
Post by RS2 » Fri May 19, 2017 6:30 am
I checked the back of the RNS-D... it definitely doesn't have any more empty slots for the plugs to fit into.
Re gearbox, I've been looking at the intput and output sensor readings with the engine running. The input speed is registering the same as the engine and it doesn't change when a gear is selected. The output speed sensor is just registering 0.
I also tried the stall test. Put the car in gear (obviously running) and with your foot on the brake, accelerate with the other foot. The rpms should be held at around 1,600rpm if there is drive through the gearbox. Mine... = loadsa revs!!
Please DO NOT DO THIS ON YOUR CAR FOR MORE THAN A FEW SECONDS IF AT ALL. You can damage the gearbox very easily and it gets really hot... really quickly. Don't blame me if you blow it up doing that.
I'm still wondering if there's any oil in the gearbox...
MG
Post by chunky79 » Fri May 19, 2017 6:54 am
I wonder if the g-box ecu will shut drive down if the output sensor is faulty? I have a feeling it will, but the first thing and easiest thing to check is the oil situation, personally i'd have done this before doing anything else to save further damage to the box. No oil in the box, there's a chance you'll have screwed the verter and pump by now.
Post by Shoppinit » Fri May 19, 2017 7:10 am
Sounds like there's no ATF or the pump is borked.
V!per
Post by V!per » Fri May 19, 2017 7:16 pm
Yellow goes next to the Green - they can be joined together and then that goes ion to the radio
RS2
Post by RS2 » Sat May 20, 2017 10:42 am
Agreed but checking the oil the drive isn't an easy job on these cars.
Having just done a compression test on the engine (all good) I took a few minutes to look around underneath and there's oil blathered back from around the gearbox... A quick touch and look and it's yellow. I jacked up one side quickly to confirm... I don't think that there's any oil in it! As the PO was driving it when it failed, I have no idea what the internals will be like now 😯.
Next job, order a filter and some oil...
MG
Post by chunky79 » Sat May 20, 2017 4:10 pm
Going on your previous build thread I thought you had a ramp, sorry.
RS2
Post by RS2 » Sun May 21, 2017 7:32 pm
Unfortunately not. At the time, I was running a company that was housed under the same roof as two others that were service/tuning based and could use the workshop at weekends.
Now, I'm at home only and will be doing everything on the drive... On the floor.
I'm hoping that there isn't too much damage and that it'll regain drive once there is oil in it.
Mɐʇʇ
Post by Mɐʇʇ » Sun May 21, 2017 9:04 pm
I did my box with the car on axle stands & an engine crane. As long as you've got a creeper trolley, it's tolerable.
Post by chunky79 » Mon May 22, 2017 6:50 am
I was taking a gearbox out of a telehandler (jcb) the other day, I tried using a creeper board for the first time doing this job (done over 100) and I couldn't undo things, the bloody board kept moving around :bash:. Launched the creeper board across the workshop and used my trusted piece of shed roof instead.
Nobby
Post by Nobby » Mon May 22, 2017 9:00 am
I bought a creeper trolley about 6 months ago and have yet to use it. My driveway has a slight incline so I'd probably end up rolling into the middle of the road...
Where abouts are you based RS2? If your local to me and need a hand with the spanners I'd be up for popping over to lend a hand.
Daytona RS6 Avant
Users browsing this forum: Google [Bot] and 92 guests
