That'll be cause of the chatter then - not the clutchGavla wrote:adsgreen wrote:Gavla wrote: Yep single mass fly wheel which is lighter
http://www.loba-motorsport.com/shop/aud ... -disc?c=33
Clutch pedal, has anyone got to the bottom of problem
Re: Clutch pedal, has anyone got to the bottom of problem
My clutch was working well most of the time. It got "sticky" if I went through 1-3 gears and shifted near the redline. I never rev the engine to redline while stand still. So I surely didn't upgrade because of that. I was getting tired of car not behaving like it should 100% of the time. Maybe you don't mind pulling the pedal up (even if it's bad shift from your part), but I got tired of it. As I said, it's the best 2 grand I've spent on the car.sakimano wrote:It does work all the time. Unless you are referring to the very specific driver caused issues i outlined. If so you would rather pay 2 grand so that you could rev the engine with the clutch down and not have it get a little sticky? Not sure I agree.
Did you replace the flywheel?
Yes, clutch and flywheel.
Yeah that's not working very well at all. If you can't wind a high revving engine out to redline without it failing, what's the point. I'd have addressed it too. Problem with the slave/master fix is the labour approaches a clutch job so may as well go all the way.Marten wrote:My clutch was working well most of the time. It got "sticky" if I went through 1-3 gears and shifted near the redline. I never rev the engine to redline while stand still. So I surely didn't upgrade because of that. I was getting tired of car not behaving like it should 100% of the time. Maybe you don't mind pulling the pedal up (even if it's bad shift from your part), but I got tired of it. As I said, it's the best 2 grand I've spent on the car.sakimano wrote:It does work all the time. Unless you are referring to the very specific driver caused issues i outlined. If so you would rather pay 2 grand so that you could rev the engine with the clutch down and not have it get a little sticky? Not sure I agree.
I have this same problem and im used to it now
http://forum.rs246.com/viewtopic.php?f= ... 5&start=30
is another post on it where a guy has had it for 4 years and 44k miles
And where another lad has had all the hydraulics replaced and all has been fine
Red B7 RS4 Saloon......That is all!!
Not sure if it is the same issue,but on Saturday while driving the rs the clutch pedal stuck to the floor and I had to get my foot under it to release it..but now I am struggling to change gear at all limped the five min drive back home in third..had a nightmare getting into reverse to put it into the garage,and when I got out there was that horrible clutch smell..left the car and started it up again Sunday morning, and when pushing the clutch pedal to the floor could hear a hissing noise and this would stop as I lifted the clutch pedal tried this another two times and did exactly the same thing..
Sounds expensive mate
Not sure if it will be any good to you but your welcome to borrow my Vagcom if you want to scan the car for errors, just give me a shout if so.
RS4 Avant - Misano Red
Cheers for that mate..The_Coat wrote:Sounds expensive mate
Not sure if it will be any good to you but your welcome to borrow my VAGCOM if you want to scan the car for errors, just give me a shout if so.
Should of said as well..have not had any problems with the clutch slipping or having higher pedal ride..the clutch seemed fine tbh..
What were your driving conditions mate? Hard driving, normal traffic?scaghead wrote:Not sure if it is the same issue,but on Saturday while driving the rs the clutch pedal stuck to the floor and I had to get my foot under it to release it..but now I am struggling to change gear at all limped the five min drive back home in third..had a nightmare getting into reverse to put it into the garage,and when I got out there was that horrible clutch smell..left the car and started it up again Sunday morning, and when pushing the clutch pedal to the floor could hear a hissing noise and this would stop as I lifted the clutch pedal tried this another two times and did exactly the same thing..
Quite a couple of minute spirited drive not crazy mad...but was in second and went to change into third at about 7k on the rev range...jaysrs4 wrote:What were your driving conditions mate? Hard driving, normal traffic?scaghead wrote:Not sure if it is the same issue,but on Saturday while driving the rs the clutch pedal stuck to the floor and I had to get my foot under it to release it..but now I am struggling to change gear at all limped the five min drive back home in third..had a nightmare getting into reverse to put it into the garage,and when I got out there was that horrible clutch smell..left the car and started it up again Sunday morning, and when pushing the clutch pedal to the floor could hear a hissing noise and this would stop as I lifted the clutch pedal tried this another two times and did exactly the same thing..
Quick update,going in next Monday..and if it is nothing obvious they can see causing the problem I have told them to change the complete cluth flywheel etc.scaghead wrote:Not sure if it is the same issue,but on Saturday while driving the rs the clutch pedal stuck to the floor and I had to get my foot under it to release it..but now I am struggling to change gear at all limped the five min drive back home in third..had a nightmare getting into reverse to put it into the garage,and when I got out there was that horrible clutch smell..left the car and started it up again Sunday morning, and when pushing the clutch pedal to the floor could hear a hissing noise and this would stop as I lifted the clutch pedal tried this another two times and did exactly the same thing..
Let's hope it a simple fix and not a whole clutch replacement. Fingers crossed for you mate.
Tbh mate...the more I think about it, it makes more sense to get them to do the lot at once. And then it's done,the car has not let me down in 5 and a half years and I am planning on keeping it at least another year as there is no super saloons about barring the c63 which sounds epic,but IMO is not as good as the rs in every day use..The_Coat wrote:Let's hope it a simple fix and not a whole clutch replacement. Fingers crossed for you mate.
True, least you know it's all been replaced and one less job that may need doing in the future.
scaghead wrote:Tbh mate...the more I think about it, it makes more sense to get them to do the lot at once. And then it's done,the car has not let me down in 5 and a half years and I am planning on keeping it at least another year as there is no super saloons about barring the c63 which sounds epic,but IMO is not as good as the rs in every day use..The_Coat wrote:Let's hope it a simple fix and not a whole clutch replacement. Fingers crossed for you mate.
Have you had the new clutch return pipe fitted yet?
Mine had the pedal staying down with the clutch smell, Camberley changed the pipe, and now all ok
It's a 3hr job and it's about £420, apparently the pipe gets hot and the inside wall collapses or swells and becomes restricted so the hydraulic fluid cannot get away.
The new pipe resolves this
RS4 B7 Avant,2007
Have had the modified clutch return pipe done about three years ago ..not saying that has not failed though as it could have done...R1RS4 wrote:scaghead wrote:Tbh mate...the more I think about it, it makes more sense to get them to do the lot at once. And then it's done,the car has not let me down in 5 and a half years and I am planning on keeping it at least another year as there is no super saloons about barring the c63 which sounds epic,but IMO is not as good as the rs in every day use..The_Coat wrote:Let's hope it a simple fix and not a whole clutch replacement. Fingers crossed for you mate.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 183 guests
