Sticky Clutch Pedal
sakimano
Re: Sticky Clutch Pedal
Post by sakimano » Thu Nov 14, 2013 1:18 am
Hose doesn't work either unfortunately.
Dave7
Post by Dave7 » Thu Nov 14, 2013 10:04 am
So is the car still drivable when this happens or would you have to pull over? Just wondering if the clutch can be pulled back up with your foot or if you have to wait a while. I guess if there were any safety concerns while driving / overtaking something, Audi would have to sort it out with a recall.
irishmike wrote:Hi Guys,
I have my RS4 just over a month now,loving it so far, but I think I have the Sticky Clutch issue.
It's stuck halfway down on me 4 times now, twice after "Spirited" driving, twice shortly after starting off.
From reading posts here it seems like there is a bit of uncertainty about it, but it points to a new clutch,
I;m just trying to figure out if this issue causes any damage and if so how I'm going to convince the dealer to replace it!
Any advice?
56 B7 RS4 Saloon in Sprint with Black Optics, Privacy Glass, Buckets and FBSW
O
Covkiller
Post by Covkiller » Fri Nov 22, 2013 11:14 pm
I had this problem, I had a new clutch fitted, hey presto problem gone.
irishmike
Post by irishmike » Mon Nov 25, 2013 12:41 pm
Just an update on this.
Car was in the Garage, they did a pressure bleed of the system. I thought it was sorted as the usual high revving trick didn't work.
However this weekend it stuck again.
New clutch time I think!
irishmike
Post by irishmike » Mon Nov 25, 2013 12:44 pm
Car still drives ok.
You just need to put your toe under the pedal and pull it back up
fokker wrote:So is the car still drivable when this happens or would you have to pull over? Just wondering if the clutch can be pulled back up with your foot or if you have to wait a while. I guess if there were any safety concerns while driving / overtaking something, Audi would have to sort it out with a recall.
Any advice?
KGRS4
Post by KGRS4 » Sun Mar 09, 2014 9:50 pm
I have this problem too, sprinted acceleration going from 1st to 2nd.
1. Normal commuting: no issues with clutch
2. Spirited drive (under 7K rpm): gears change fine, no issues
3. Hard driving (change at redline, 1-2,): clutch suddenly becomes heavy, engages immediately off the floor, I get lunged forward and develops 4 inches of free play in travel where nothing happens. Resolves completely in next few changes and seems back to normal. No clutch slipping, no burning smells. Only happens 1-2.
Seems to be quite common from what I'm hearing. I also have 3 months warranty from the garage I bought it from I'm thinking of giving them a call tomorrow.
What has been a perfect fix? Clutch? Or are some getting away with just the odd cylinder and pipes?
Red B7 RS4 Saloon......That is all!!
Gavla
Post by Gavla » Sun Mar 09, 2014 10:24 pm
KGRS4 wrote:I have this problem too, sprinted acceleration going from 1st to 2nd.
That's pretty much my story right there apart from a few weeks back the clutch went completely and would not engage any gears!!! I considered trying the return pipe, master/slave cylinders first (as it's cheaper) but most people who tried this route ended up having to replacing the entire clutch! :shock: In my case I decided to upgrade to a LOBA 550NM Stage 1 clutch as my car is already modified and I'm planning on enjoying the car a few more years. The new clutch is still bedding in and there is some minor chatter but it's hard to hear with my non-res and you just drive around it. If your car is standard then I'd go for the normal Dual Mass.
You'll be looking around the £2K mark for a std one though... :drink:
Good luck ;-)
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
KGRS4
Post by KGRS4 » Mon Mar 10, 2014 8:18 am
I have a standard motor but if this seems to be a common problem with an OEM clutch I'd rather put a different one in if this is likely to happen again? Or at least a stronger kind etc.
Ill have to phone the garage I bought it from as I've still got warranty with it see what they say
irishmike
Post by irishmike » Mon Mar 10, 2014 12:04 pm
Just got the hydraulics replaced on mine this weekend under warranty.
Going good so far :)
Fingers crossed :)
Gavla
Post by Gavla » Mon Mar 10, 2014 12:16 pm
KGRS4 wrote:I have a standard motor but if this seems to be a common problem with an OEM clutch I'd rather put a different one in if this is likely to happen again? Or at least a stronger kind etc.
My thoughts were similar hence why I upgraded. Worth exploring the warranty though - fingers crossed ;-) Good luck!
Bladerider
Post by Bladerider » Mon Mar 10, 2014 10:03 pm
Mine has done it for 4 years and 40k miles so far !!
I discussed it with Doug the other day at MRC when they did the decoke and he said that it is definitely the pressure plate and only a replacement clutch/flywheel will fix it 100%
Mine is no worse despite the extra power from the recent work. Its easy to drive round and once it starts doing it you can still change gears okay - I havent tried pushing it too much on track but will update this and the other thread Im on when I do.
J.
irishmike
Post by irishmike » Mon Mar 10, 2014 11:53 pm
Does it happen often?
Do you get the burning smell?
Just wondering if it comes back if it's something I can live with...
Bladerider
Post by Bladerider » Tue Mar 11, 2014 12:07 am
Everytime I cane it.
And no, it doesnt make a burning smell, but then I have usually let the car chill and cool a bit before I know I will be stopping so perhaps have never had the aroma !! :D
In fact I keep having a bit of head confliction as Doug at MRC told me I now have to give the car a good thrapping to 8500rpm pretty much every time I use it, preferrably close to end of journey to try to limit coking up again. After decades of turbo cars its doing my head in !! as all i want to do for the last 5 minutes of a journey is drive off boost and let the car cool right down as never particularly liked my turbo timers.
Too much info lol
Yes, you can live with it easy if you are even slightly adept at driving.
J.
irishmike
Post by irishmike » Tue Mar 11, 2014 10:56 am
Not too much info at all. Great to hear it tbh.
I'll print it out and show the gf to explain my driving style :)
Used to turbos myself so it will be a change all right.
irishmike
Post by irishmike » Sun Apr 13, 2014 1:00 pm
Just a quick update.
Been a month now and no more sticky clutch.
Looks like the cylinder replacement did the job.
Users browsing this forum: Google [Bot] and 161 guests
