Best of luck that they don't find anymore dramas...
40k service items?(UPDATE NOT GOOD!)
Re: 40k service items?(UPDATE NOT GOOD!)
It didn't take them long to whip the motor out then ?
Started 9am Monday.
Awaiting gaskets now.
I'm hoping for early next week?
They told me 22hours labour in and out?
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
IME on some engines this type of seal often breaks down over time.
I dont know why they use them tbh.
My 997 had similar problems at 5 years old and was also an engine out job.
It was done under warranty but I dont want to know what the cost was.
The engine on these knocks out some serious heat...don't know if that would cause gasket failure?
As I've said already my leaks can't be seen from under the bonnet?...just hope everyone else's cars aren't slowly suffering the same fate as mine?
The only leak that Audi found initially was the oil pump?..because they removed the plastic under-tray to change oil this seeing the leaked oil on it.
The three today have only been found because engine is out?
At least when sorted I've piece of mind for a few years??....if I decide to keep it!!!!!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Ouch sorry to hear
Estimate yet?
Estimate yet?
Currently :
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
Seat Ibiza excellence Lux!
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2017 AMG E class wagon
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2012 Audi RS4 (B8)
<beep> the bed
How much is this costing at main dealer rates?
Audi warranty
Audi warranty
I had a look at mine last week as best as I could on the ramps with the undertray off and it was ok, no leaks.RS6chris! wrote:The engine on these knocks out some serious heat...don't know if that would cause gasket failure?
It might be something as simple as the covers were not de-greased or something at the factory.
I have an inspection pit at work so will check again in a few months.
The actual job of changing the gaskets is only two hours labour according to Audi?....it's the access too them that's the nightmare.
Sorry just to clarify was reading the tech sheet is it actully a "O" ring that is leaking on the oil pump not a gasket?
So... oil pump...O ring.
Timing chain covers...gaskets.
Rocker head covers...gaskets.
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
so they are charging you only 2 hours Labour?
They charged me 6 hours when my coolent hose burst at ADI 2012, the pipe was only £75 and they didnt even take my engine out, just the whole right hand side of the car.
Two hours plus parts for the three leaks found today.
22hours for the oil pump O ring.
Plus my 40k service
And
New front discs and pads!!!
<beep>.
Plus my 40k service
And
<beep>.
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Chris, you should be getting the costs up front before agreeing to the work, and even then haggling the rate. Labour rates at my Audi dealer are £136 an hour with the VAT, yours will most likely be similar. I hope you've been doing this!
Amar
All cost up front matey
They have been calling me at every stage asking if I want to proceed and I have negotiated with them.
I've been given some good will and labour rate is 80 per hour.
Chris
Chris
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Fair enough, that's not bad then, I had a feeling you were going in at it blind. Mad, isn't it? £2 O-ring, £2k labour.
Just had a look under my car as its on the ramp having the exhaust modded and copied so they can send one out to OZ.
there is fresh oil leaking from the undertray and its everywhere under it so its going in on Friday for bearings so I will get them to look at it as it wasn't that bad in sept when I cleaned it up, it was also serviced in Jan by Audi so not sure they picked up on it.
Trups
Trups
my car has just been serviced at the dealers (currently on 24k on 09 plate)... nothing mentioned about oil leaks etc.. and they did an oil change.
Just wondering if its something more common on higher mileage or slight older cars, or luck of the draw?
my warranty runs out at the end of May and i dont fancy getting stuck into £1,000s for labour bills. Wonder if its worth getting the garage to do a quick check.
