To VAG-Com users, FATS times database for the Euro S4s
MarkB
Post by MarkB » Fri Sep 29, 2006 10:11 am
Paulm wrote:Good bit of work there Mark. I must say though your timing looks even worse in that format :? I take it you are not any closer to finding the prob?
Minhea's timing upto 4300rpm is very impressive
It does show mine as bad, but much the same a Dippy's with his AMD map. We are the only two who have posted AMD maps.
I did the graphs to highlight if the advance curve was much the same or not. It does appear to be similar so I might start trying to push the timing forward. The knock sensors aren't retarding the ignition at all at the moment. Probably waisting my money putting 99 in the tank with such poor timing.
I know I'm running more boost than MRC maps. Hope to get some plots going on that today. Just hope the map is giving enough fuel as I don't know any easy way to check that. Any ideas?
Mark
S2tuner
Trader (Expired)
Post by S2tuner » Fri Sep 29, 2006 10:11 am
Here's one of my latest logs, stage 3:
,4.53,3120,104.39,100.0,24.8,,,,,,,,,,
,4.84,3240,138.06,100.0,17.3,,,,,,,,,,
,5.13,3400,189.39,100.0,12.0,,,,,,,,,,
,5.43,3600,227.25,100.0,11.3,,,,,,,,,,
,5.73,3840,250.31,100.0,12.0,,,,,,,,,,
,6.05,4120,268.78,100.0,10.5,,,,,,,,,,
,6.35,4440,277.50,100.0,10.5,,,,,,,,,,
,6.68,4680,280.86,100.0,10.5,,,,,,,,,,
,7.01,4920,295.64,100.0,11.3,,,,,,,,,,
,7.35,5240,307.53,100.0,14.3,,,,,,,,,,
,7.70,5480,319.64,100.0,12.8,,,,,,,,,,
,8.05,5760,317.28,100.0,19.5,,,,,,,,,,
,8.42,6040,322.44,100.0,23.3,,,,,,,,,,
,8.79,6240,326.72,100.0,23.3,,,,,,,,,,
,9.17,6520,331.50,100.0,25.5,,,,,,,,,,
,9.55,6720,338.33,100.0,27.0,,,,,,,,,,
,9.92,7000,341.31,100.0,23.3,,,,,,,,,,
,10.30,7160,332.50,100.0,29.3,,,,,,,,,,
,10.68,7360,323.86,100.0,30.0,,,,,,,,,
Cheers,
Mihnea
MarkB
Post by MarkB » Fri Sep 29, 2006 10:15 am
S2tuner wrote:Here's one of my latest logs, stage 3:
Cheers,
Mihnea
Nice one
Timing plots.jpg (44.37 KiB) Viewed 1265 times
Mark
MarkB
Post by MarkB » Fri Sep 29, 2006 10:23 am
Cheers,
Mihnea
Fats time of 3.02 secs!!!!!!! :bowdown:
Mark
S2tuner
Trader (Expired)
Post by S2tuner » Fri Sep 29, 2006 10:29 am
RS4 gearbox and 235/35ZR19 tires. :D
MarkB
Post by MarkB » Fri Sep 29, 2006 10:53 am
Ah. The gearbox helps...
Mark
oliew
Post by oliew » Fri Sep 29, 2006 11:17 am
mihnea, do you have a record from your older runs when you got the 4.5fats time the req boost/actual you logged?
cant wait to go out in the car when i come down!!!!
S4 B5 - MRC
S2tuner
Trader (Expired)
Post by S2tuner » Fri Sep 29, 2006 12:05 pm
19's don't though...
MarkB wrote:Ah. The gearbox helps...
oliew
Post by oliew » Fri Sep 29, 2006 12:09 pm
yeh i love 19's cant wait to put mine back on, if you had 17's on i recon your fats time would be about half a second faster looking at the trends in logs that ive done anyway
S4 B5 - MRC
MarkB
Post by MarkB » Fri Sep 29, 2006 12:25 pm
shineydave wrote:do these look ok? MRC custom map with standard exhaust and 17"s
TIME RPM MAF Throttle Timing
0.3 1720 32.28 16.1 20.3
0.9 1880 34.42 16.5 21
1.51 2000 44.39 22.7 21
2.1 2200 66.22 88.2 18
2.72 2400 84.08 100 15.8
3.32 2680 112.31 100 12.8
3.93 2960 135.81 99.6 11.3
4.53 3280 158.14 100 9.8
5.13 3600 174.39 99.6 12
5.74 3920 185.11 100 12
6.35 4240 200.25 100 12.8
6.99 4600 219.81 100 10.5
7.64 4920 226.81 100 12.8
8.32 5240 240.33 100 12.8
9.01 5560 246.89 100 18
9.73 5840 260.44 100 19.5
10.47 6120 250.47 100 18
11.2 6400 249.78 100 18.8
11.96 6640 249.08 100 24
12.72 6880 251.86 100 21
13.45 5720 17.39 8.2 17.3
14.13 5240 17.67 8.2 15.8
Was this done in 3rd gear? Gives a FATS time of 5.24 secs!!
Mark
MarkB
Post by MarkB » Fri Sep 29, 2006 12:28 pm
S2tuner wrote:19's don't though...
They aren't as bad for the time as the gearbox is good for it. Still a cracking time though
Mark
shineydave
Post by shineydave » Fri Sep 29, 2006 6:16 pm
yup, third gear, if i recall it was about 15 degrees ambient, full tank, spare wheel and 2 racing snakes in the front seats
MarkB
Post by MarkB » Fri Sep 29, 2006 7:03 pm
You've got a strong car then :thumb:
Mark
shineydave
Post by shineydave » Fri Sep 29, 2006 7:12 pm
125,000 miles and still going like a train. did a couple of logs and took an average but on one of the runs i actually got under 5.0 seconds
MarkB
Post by MarkB » Fri Sep 29, 2006 7:17 pm
I'd have to drop mine off a cliff to get a good time like that :audibash:
Mark
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 23 guests
