Headlight repairs
Re: Headlight repairs
Post by Shoppinit » Fri Sep 16, 2011 1:19 pm
Mmm. Turns out these headlights are really simple inside. The reflectors are attached to the body at 3 points. 2 at either side at the top of the reflector and 1 at the bottom. The 2 at the top are where the manual adjusters are - the 2 white cogs. The one at the bottom is adjusted by the stepper motor for the xenon height and is directly below one of the manual cogs.
So the cog on its own (not above the motor) is used to adjust left to right. I'm not touching that one. The other manual cog is used to push / pull the top of the reflector and the motor is used to push / pull the bottom of the reflector.
There is no feedback on the level of the light - it is a completely open loop.
The motors are activated directly by the car level sensors. I pulled the motor out and as you push or pull on the suspension, the stalk goes in or out to pull or push (respectively) the bottom of the reflector and thus adjust the aim.
So now I'm thinking I have a problem with the motor. I can't for the life of me see why the aim would drop on its own.
Post by Shoppinit » Fri Sep 16, 2011 1:23 pm
Some pics:
//replaced broken links. Fcuk imageshack.
mrmule
Post by mrmule » Fri Sep 16, 2011 5:35 pm
Surely you connected up a little jig to test the motor Shop?
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
Post by Shoppinit » Fri Sep 16, 2011 7:05 pm
mrmule wrote:Surely you connected up a little jig to test the motor shop?
Nah, that would be far too sensible. What I actually did is plug it all in with its guts hanging out and held the little knob between my finger and thumb while heaving and pulling on the body to make the little knob thrust in and out of my sweaty fingers.
Very satisfying all round, methinks. The risk of getting 50 thousand volts up the wazoo just adds to the excitement.
If bam hasn't exploded by now then I give up.
mrmule
Post by mrmule » Fri Sep 16, 2011 8:34 pm
Forget bonk_bonk. I'm standing in a sweaty gig in Brixton and even I laughed out loud.
Good job Shop :)
Post by bam_bam » Sat Sep 17, 2011 1:53 pm
mrmule
Post by mrmule » Sat Sep 17, 2011 2:38 pm
You're a lefty then Luke? ;)
Post by bam_bam » Sat Sep 17, 2011 3:29 pm
mrmule wrote:You're a lefty then Luke? ;)
Only immediately after wanking. BTW pic related but not me.
fox
Post by fox » Wed Oct 12, 2011 7:04 pm
Shoppinit wrote:So now I'm thinking I have a problem with the motor. I can't for the life of me see why the aim would drop on its own.
Did you manage to bottom this out in the end JOOI?...
Al
Emission-tax-dodging 2000 S6 Avant.
Bog-stock and boring silver, but with an interior blacker than the Earl of Hell's waistcoat. And RS 19s.
Post by Shoppinit » Wed Oct 12, 2011 7:58 pm
Seems to be holding steady for the time being. I don't drive much at night though so I haven't checked properly for a while. I'll let you know. I am now thinking that vibration causes the cogs to slowly unwind. I've marked them up and will see if they have moved.
fox
Post by fox » Wed Oct 12, 2011 8:13 pm
Mmkay.
Think my car's gone the same way. Ho hum. Tear into it at the weekend - see what's gone on...
Al
Post by Shoppinit » Mon Mar 19, 2012 10:23 am
Aim is off again! The cogs haven't moved. I might have to look into the level senders to see if there is a problem there!
RS! :assflash:
This is really weird. I took the car out for a blast earlier and hit a dip at 100+ kleptons and the headlight came back into aim. I actually saw the beam slam back into position. There is definitely something very strange going on.
Maximo wrote:That does sound like the stepper motor doing silly things. When you took the headlight apart last time did you see how the stepper motor connected? Could it be that hitting the dip forced the connection back into place?
If you turn the lights on and then start the engine do both dip and re-align? Maybe we've something less well engineered than the TC in the Gearbox. :D
I like the way you think. That makes sense if the reflector popped off the end of this at some point previously:
And then popped back on when I hit a bump. Would explain the aim coming back to the right position...
Maximo
Post by Maximo » Mon Mar 19, 2012 2:11 pm
So I'm going to guess the stepper motor just turns and that either pulls or pushes the reflector? Could the reflector be getting caught on something loose inside the unit and that's made it pop off?
R18 GTX Estate > Saphire 2.0i Ghia > R19 16v > Vectra V6 SRi > M3 > RS6 Avant
Post by Shoppinit » Mon Mar 19, 2012 2:15 pm
It's a linear stepper motor, so it doesn't turn, it just moved in and out. I'd love to take it apart to see how it works. :)
I don't think there's anything in there that can get caught, but it's worth a look. The reflector basically swings about the the 2 other fixing points and the motor adjusts the aim up and down.
Maximo
Post by Maximo » Mon Mar 19, 2012 2:27 pm
It'll be really simple inside, just a motor around a corkscrew at a guess, well that's how I'd do it anyway. To be honest I'd ahve put the corkscrew attached to the reflector and rotating motor, that way it would be a fixed connection rather than a pop-on pop-off type. Must have been a YTS boy designing the headlights for VAG at the time. So with the light unit apart is the reflector unit easy to move, does it have a pivot point?
Thinking about it, could the stepper motor be out of sync? Maybe it's forogotten where it should default to.
Users browsing this forum: No registered users and 137 guests
