Has anyone 'upgraded' to the 2010+ RNSe?
Firestarter
Re: Has anyone 'upgraded' to the 2010+ RNSe?
Post by Firestarter » Tue Oct 08, 2013 3:58 pm
PetrolDave wrote:
JoeyManhattan wrote:I've heard that the CAN wires need to be run in order for the new AMI to function properly, not sure if this is so.
All the wires needed by the AMI are already at the RNS-E, and from some eBay sellers (and other places) you can by a ready made cable.
Go for the 2010+ RNS-E plus AMI.
For my numptyness sanity are you saying that if I was to purchase a 2010+ RNS-E plus AMI I could simply swap over, plug in and not have to provide any other cables etc for it all to work? I have VCDS but not quite sure what I would need to reprogram if at all?
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT :-)
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre :-)
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
PetrolDave
Post by PetrolDave » Tue Oct 08, 2013 5:48 pm
DALO wrote:RNSe (even the later versions) surely only support one or the other via the software? AMI goes into the glove box location where the CD changer lives in any case
That's two different points:
1) the 2010+ RNS-E CAN support (electrically and in software) both CD changer and AMI - I've tried it and it works.
2) You're right that physically there's no room for both AMI and CD changer in the glove box, but that doesn't stop you using an Aux In to CD changer adapter and having both AMI and Aux In :bigblink: (which is not possible "the Audi way" as they both use the same audio inputs into the RNS-E).
PetrolDave
Post by PetrolDave » Tue Oct 08, 2013 5:51 pm
Firestarter wrote:are you saying that if I was to purchase a 2010+ RNS-E plus AMI I could simply swap over, plug in and not have to provide any other cables etc for it all to work? I have VCDS but not quite sure what I would need to reprogram if at all?
No I'm not saying that at all - I'm saying that all the signals you need for AMI already exist at the RNS-E - but that's not the same as saying it's plug'n'play.
What it means is that you don't need to run wires from the AMI to anywhere other than the RNS-E, but you need to buy/make the AMI to RNS-E wiring.
pDkALO
Post by pDkALO » Tue Oct 08, 2013 10:15 pm
PetrolDave wrote: 1) the 2010+ RNS-E CAN support (electrically and in software) both CD changer and AMI - I've tried it and it works.
Interesting - I did not know that.
PetrolDave wrote:What it means is that you don't need to run wires from the AMI to anywhere other than the RNS-E, but you need to buy/make the AMI to RNS-E wiring.
Not sure you even need to do that nowadays Dave - virtually all new ones I've ever seen (such as current eBay item 111179619933) include the RNSe to AMI loom
pDkALO
Post by pDkALO » Tue Oct 08, 2013 10:25 pm
Thank you much, before I make an ebay purchase does anyone know of any sellers that already have swapped the faceplates over?
It's better value to do it yourself if you have access to VCDS and a set of small screwdrivers: buy an A3 193 spec RNSe on eBay for around £400, swap the faceplate from the RS in an hour or so, recode it thru VCDS for use in an A4, plug it in and grin at the lovely high res screen and thousands of music tracks you've now got on SD cards, then go back indoors, fit the A3 faceplate onto the old RNSe, recode it for an A3 and sell it on eBay for around £250.
Job done. :thumbs:
PetrolDave
Post by PetrolDave » Wed Oct 09, 2013 5:41 pm
Many eBay listings now include the cable - you're still buying the cable as they won't be giving it away for free :bigblink:
PetrolDave
Post by PetrolDave » Wed Oct 09, 2013 5:42 pm
DALO wrote:It's better value to do it yourself if you have access to VCDS and a set of small screwdrivers: buy an A3 193 spec RNSe on eBay for around £400, swap the faceplate from the RS in an hour or so, recode it thru VCDS for use in an A4, plug it in and grin at the lovely high res screen and thousands of music tracks you've now got on SD cards, then go back indoors, fit the A3 faceplate onto the old RNSe, recode it for an A3 and sell it on eBay for around £250.
Job done. :thumbs:
+1
JoeyManhattan
Post by JoeyManhattan » Wed Oct 09, 2013 8:49 pm
The problem I have just encountered is that the vastly available Nav units are not the USA models, which I need in order to utilize the US Nav discs....Looks like it is going to be a hunt to get the proper Nav unit.
2008 RS4, Mugello Blue Pearl, Silver Interior
armyair
Post by armyair » Wed Oct 09, 2013 11:55 pm
Surrey Sam wrote:Yup, just waiting for an SDS variant to come up and then I shall be installing the collection of electrical stuff now sitting on my desk.
Dave - have you tried running your AMI and CD changer together? I'm a little reluctant to go fully over to MP3.
They both work fine in my RS6 with a 2010+ RNS-E fitted.
My Bluetooth loom is from a B7 model and so I wouldn't imagine the B7 would be any different to a RS6!!???
Current:
2004 RS6 Avant, 1999 Range Rover, 2008 Iveco Daily (faster than the 6 hands down)
Past:
2008 Jaguar XK, 2006 S4 Avant, 2009 Mini Cooper S (Wifey's daily drive)
PetrolDave
Post by PetrolDave » Fri Oct 11, 2013 6:12 pm
JoeyManhattan wrote:The problem I have just encountered is that the vastly available Nav units are not the USA models, which I need in order to utilize the US Nav discs....Looks like it is going to be a hunt to get the proper Nav unit.
Try contacting the member Haaggie on audiforum.us - he normally has the US units available.
Users browsing this forum: Google [Bot] and 1202 guests
