RS5!!!!
4.2 V8 32v Naturally Aspirated - 444 bhp
SR71
Post by SR71 » Thu Feb 25, 2010 11:25 am
The origin of the 7:58 time for the RS4 is Erik's interview (rs6.com) with him: http://www.rs6.com/showthread.php/7570- ... k+Stippler
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
ArthurPE
Post by ArthurPE » Thu Feb 25, 2010 3:12 pm
SR71 wrote:The origin of the 7:58 time for the RS4 is Erik's interview (rs6.com) with him: http://www.rs6.com/showthread.php/7570- ... k+Stippler
thnx for the link, I was wondering where the 'origin' of this time came from...
he had a passenger in the car? wow
iirc somebody else on another forum claims to have been there (I believe him, he did the MTM SC RS4 video), and the 7:58 was an 'estimate', an educated one no doubt, but was not actually run?
Sims
Post by Sims » Fri Feb 26, 2010 8:31 pm
Not sure if this has been posted - apologies if it has.
Some interesting facts about RS5:
DRC
Dynamic Ride Control allows you to set up the suspension according to the task in hand, at the press of a button. Theres Comfort mode for motorway cruising, Dynamic mode for twisting lanes or, should you want to take the car to a circuit, select Sport and the suspension tightens, reducing body roll even further. All this fine-tuning of the ride makes the RS 5 taut, agile, sporty and precise.
SPORT DIFFERENTIAL
Sport differential all-round driving improvement The sport differential, for a performance addition to quattro which is standard on RS 5, is designed to make driving obviously smoother, more agile and more satisfying and not just when youre pushing the car towards its limits.
Safe, accurate turning
The sports differential enables the quattro system to not only transfer torque between the front and rear axles to counter traction losses, but also between the rear wheels. When cornering, power is redirected to the outside rear wheel, literally pushing the car through the corner. The driver benefits from feeling more in control and the need to make small steering corrections, so familiar in an ordinary car, become a thing of the past.
Why react when you can predict?
Conventional stability management systems detect errors, then correct them. We think thats a little late. The sport differentials technology has such a short reaction time - less than 100 milliseconds that any instability is sensed and dealt with before it has any effect. Almost like it never happened.
You're still in control
The sport differential has been designed to work in tandem with Audi drive select. This enables the possibility to change the characteristics of the engine, transmission, steering, shock absorbers and the active sport differential to suit your mood and the demands of the road.
AUDI DRIVE SELECT
Not all driving situations are the same. The Audi drive select system on the Audi RS 5 changes handling and response at the touch of a button to suit how you want to drive. There are four modes: comfort, dynamic, auto and individual.
For long-distances, Comfort adjusts your set-up to create a more relaxing ride. Dynamic changes the settings for a sportier driving experience, adjusting steering and throttle response. The Auto mode adapts the system depending on the current driving situation while individual, which is available in conjunction with a Satellite Navigation system, allows you to configure the dynamics of the car to your own preferences depending on what special equipment is fitted.
BRAKE SYSTEM
The 18-inch high-performance braking system is able to safely harness the formidable power of the Audi RS 5.
8-piston fixed callipers at the front wheels plus single-piston sliding callipers at the rear.
Brake callipers painted in high-gloss black.
Brake discs internally ventilated, perforated and with a floating mounting.
Brake disc diameter of 365mm at the front, and 324mm at the rear.
Aluminium tandem brake booster with a ratio specific to the RS 5.
Optional front Ceramic brakes with 380mm diameter and 6-piston calipers panited in Dark grey with Audi Ceramics signiture MODULAR LONGITUDINAL PLATFORM
The RS 5 is built on Audis modular longitudinal platform. This innovative chassis enables the engine to mount behind the front axle instead of over it which helps to achieve a more even weight distribution between the front and rear wheels. The result is a car that corners with confidence and handles superbly.
S Tronic
The RS 5 comes with a 7-speed S tronic gearbox. This innovative dual-clutch transmission enables gearshifts to be executed in a few hundredths of a second with virtually no interruption in power flow.
This is the first time that this gearbox has been fitted in conjunction with a high-revving engine giving the performance and the acoustics that you would expect from an RS model.
The revolutionary S tronic transmission combines the responsiveness of a manual gearbox with the convenience of an automatic. Thanks to innovative dual-clutch technology, S tronic can make a gear change in just 0.2 of a second, with no interruption to the power flow, allowing you to benefit as fully as possible from the engines output at all times. Depending on how you wish to drive, you can either allow gear-changes to take place automatically or, for a sportier driving style, operate the S tronic system using the gearshift or steering wheel shift-paddles.
NEW QUATTRO
A car such as the Audi RS 5 needs special treatment to put its power to the road. Enter quattro, Audis renowned four-wheel-drive technology. And with the RS 5 comes the latest edition of the four-wheel drive system with self-locking centre differential and torque vectoring.
With quattro, optimal drive delivery to each wheel is managed automatically and continuously, for superior handling and phenomenal grip even in less than perfect driving conditions.
In 1980, the Audi quattro was the first permanent four-wheel drive production car. So while the technology is thoroughly tried and tested, it has also been enhanced and evolved ever since it was first introduced. Today, ultra-modern quattro technology is available on every Audi, right across the range.
RS 5 with quattro
In the RS 5, the power to the front and back wheels is split in a 40:60 ratio giving the car a sporty, rear-focused driving style that guarantees maximum agility and driving enjoyment.
quattro: what it does and how it works
Front-wheel or rear-wheel drive has certainly improved thanks to innovations such as electronic stability programmes, anti-lock brakes and traction control. But two-wheel drive cars will, particularly in extreme circumstances, sometimes exhibit certain (and usually undesirable) characteristics.
Due to the weight of the engine and other assemblies resting on the front axle, front-wheel drive cars tend to be slightly superior to rear-wheel drive cars in the amount of grip they can transmit to the road during wet conditions.
But in a front-wheel drive car, hard cornering or cornering on a slippery road surface can cause understeer: where the car continues forwards even though the wheels are turned.
Conversely, rear-wheel drive cars can suffer from oversteer: the driving wheels deliver more power than the road surface can handle, causing the rear end to slide and the car to travel sideways. This can be quite difficult for you to control and traction aid systems and electronic stability programmes will engage quite early.
Slippery surfaces
With quattro, drive is distributed to all four wheels permanently in varying amounts, depending on the road conditions and how the cars being driven; its constantly feeling how much grip there is for each wheel. If a wheel loses grip, drive is diverted away to wheels that have better contact with the road. All his happens imperceptibly, but it results in a feeling of exceptional composure and control, even in what would ordinarily be potentially dangerous driving conditions.
Cornering
With front-wheel or rear-wheel drive the car is effectively being either pulled or pushed round a bend. Instead, with quattro four-wheel drive, all four wheels work together and drive is delivered to where its needed and regulated where it isnt. This means greater stability, more assured road-holding, enhanced agility and improved steering precision.
How it works: the Self Locking Centre Differential The Self Locking crown-gear centre differential is at the heart of quattro on the Audi RS 5.
Operating entirely mechanically, it continuously reacts to road conditions and responds to any differences in the rotational speeds between the axles. This ensures more power is always transmitted to the wheels with a better grip.
Working in tandem, the Electronic Differential Lock (EDL) can act when needed to prevent the wheels from spinning. Excess power at one wheel is diverted to the other wheels that have more grip, maintaining traction in virtually every situation.
Asymmetric torque distribution
The latest version of new and enhanced generation of quattro features asymmetric and dynamic torque distribution with a 40:60 split, favouring the rear wheels, and it reacts to road conditions even more responsively.
As a result, steering, handling and grip are massively improved and the whole driving experience is made more exhilarating than ever.
rs4v8
Post by rs4v8 » Fri Feb 26, 2010 9:39 pm
All that'll explain the extra 75kg's then!!
Current
'10 Nissan GT-R Black Edition, Kuro Black.
'59 Scirocco 2.0 TFSI
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'07 RS4, Phantom black saloon
'57 Clio 197
'04 Aprilia RSVR Factory. Black.
E46 M3 SMG, Alpine white
E46 320i coupe
E36 328is coupe
VW golf VR6
Screw you guys!' - Eric Cartman
toomuch
Post by toomuch » Fri Feb 26, 2010 11:16 pm
rs4v8 wrote:Yeah but the M6 is a big GT styley coupe. wallowy in the corners compared to a SS+ equipped RS4 (I've never driven a standard suspension RS4). I'd be very confident of hosing on an M6 in anything other than a straight line and even then I'd not be too far behind. I think those are the cars you are comparing isn't it? Exactly the same reason why the GTR is so fast. Proper chassis setup for track / fast road work and lot's of go.
I love my RS4 it gives me massive confidence in the twisties to drive flat out, but believe me, my M6 would completely and utterly destroy an RS4 in a straight line end of.
Current Fleet:
07 - Dayton RS4
55 - Indy Red M6
08 - Silver ML420cdi
mark758
Post by mark758 » Sat Feb 27, 2010 1:48 am
Well with only RWD and another 90 bhp you would sincerely hope so!
Reminds me of one of the videos on M5board....where an M3 has just beaten an RS4 in a drag race with lots of excited merriment in the bmw cabin....the camera pans away from the audi to the track ahead...it then goes very quiet in the BMW cabin, you then hear a panicked scream from the passenger 'CORNER!'.....lots of anchors thrown out the window to slow down....camera stays focused on the section of track with bends in ahead....in the distance you can just make out the rear lights of an A4 disappearing :lol:
2013 Ibis White RS7¬
¦ParkingPackPlus¦Sunroof¦HUD¦AudiConnect¦HeatedRearSeats¦RearSideAirbags¦RedBrakeCalipers¦QuattroPuddelights¦SoftCloseDoors¦NightVision¦Dynamic Package¦CarbonPackage¦CarbonMirrors¦21" GlossBlack¦ACC¦Stop&Go¦PreSensePlus¦SideAssist¦LaneAssist¦B&O¦BlackOptics¦OEMBlackBadging¦Gyeon Q2 Duraflex¦
ArthurPE
Post by ArthurPE » Sat Feb 27, 2010 2:03 am
there is no denying the M6 is an amazing car...amazing
the fact that with the same tires & driver the RS4 and M6 are the same time around the Ring is equally amazing, 8:09
they weigh ~ the same and the M6 has 20% more HP and torque...
considering the $$$ differential the RS4 has nothing to be ashamed of :D
Sims
Post by Sims » Sat Feb 27, 2010 4:13 pm
sonny
Post by sonny » Sat Feb 27, 2010 4:54 pm
So that will mean its 420hp then lol
Sims
Post by Sims » Sat Feb 27, 2010 5:31 pm
ArthurPE wrote:there is no denying the M6 is an amazing car...amazing
:thumbs:
Sims
Post by Sims » Mon Mar 01, 2010 4:52 pm
sonny
Post by sonny » Mon Mar 01, 2010 5:02 pm
Hmmmmmmmmmm not really sure!
mark758
Post by mark758 » Mon Mar 01, 2010 6:36 pm
I am 8)
rs4v8
Post by rs4v8 » Mon Mar 01, 2010 7:19 pm
toomuch wrote:I love my RS4 it gives me massive confidence in the twisties to drive flat out, but believe me, my M6 would completely and utterly destroy an RS4 in a straight line end of.
Completely and utterly destroy?? Maybe a wee bit of an exaggeration perhaps? :roll: A fair bit quicker in a straight line no doubt.
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
rs4v8
Post by rs4v8 » Mon Mar 01, 2010 7:24 pm
Absolutely Arthur,if you were to throw in a wee bit of anything other than bone dry race track (or replace the 'ring familiar pilots with novices) and I'd be fairly confident the M6 wouldn't even be close.
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
Return to “RS5 (8T) 2010–2015”
