To VAG-Com users, FATS times database for the Euro S4s
Hmmm,
Can you post up your timing and boost, it would be good too see.
When I did my runs I had half a tank of Optimax. No spare wheel ( had a puncture )all 4 tyres were pretty much knackered ( not sure how much 4 or 5 mm tred size makes ) and it was only 5 to 7C
Is your car a face-lift model not sure why this would make any diff though.
DavidT was getting 4.84 I think it was before he did his turbo upgrade and I think he still had his pre-cats in.
Have you tried a 30-130 yet just to see the diff from mine to yours?
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
I forgot to mention that I had no spare wheel in on either occasion. Yes, car is facelift but cant imagine what difference that would make??
Bear in mind that DavidT had RS4 intercoolers and Miltek catback before his recent turbo upgrade. Yes, I believe he still had pre-cats in.
I'll post rest of the data shortly.
Havent tried a 30-130 yet, but I'll do that next time I take the car to Germany...
Clive
Right, here goes, hope I've copied the right block...
TIME RPM Load% Spec Actual Inj ms MAF g/s
499.1 4040 175.2 2090 2110 19.38 212.44
500.04 4520 166.9 2000 2020 18.7 223.72
501.03 5000 157.1 1930 1940 18.02 229.03
502.05 5440 151.9 1940 1870 18.02 247.11
503.12 5840 148.9 1890 1900 18.02 250.61
504.23 6240 139.1 1820 1840 15.64 252.69
505.36 6600 131.6 1800 1810 14.62 254.78
Clive
your boost is pretty much the same as mine. I have a fraction more than you in some bits but only around 0.30 bar. I have not tried logging boost now we have warmer weather. But I suspect it will be higher as the ecu tries to compensate for the hotter conditions ( less dense air )
Can't say re timing as you have not posted it.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Is that not the penultimate column Paul? (Injection time ms)Paulm wrote: Can't say re timing as you have not posted it.
Clive
Give us a clue then Mark...
Clive
Clive, you need to log block 003 for g/s and timing. If you need to record boost as well (doesn't appear to be neccessary with your current figures, then use block 115 - for consistency.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Thanks Nige
@Paulm - I'll do that and post results (not today)
Clive
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
RE: Re: RE: Re: RE: Re: RE: MRC
Right guys,
Now the weather has cooled down, and I've got some Tesco 99 in, I did a comparative run today (same ambient temp - 18.5C), but this time after fitting of RS4 exhaust with gutted precats.
Result : 5.69. This compares with my previous average of 5.75, which is obviously better but a bit dissapointing compared with Paulm's result of knocking a whole second off after fitting of precats (4.6)
Clive
Re: RE: Re: RE: Re: RE: Re: RE: MRC
Do you also have an MRC map?CliveH wrote:Right guys,
Mark
RE: Re: RE: Re: RE: Re: RE: Re: RE: MRC
Yes, Mark. In fact, Mihnea tweaked the remap a little after the exhaust was fitted.
Clive
My FATs data
and here's some data...
RPM MAF g/s TA% °BTDC RPM Load% mbar mbar
1120 17.19 8.6 21 1200 50.4 1000 1020
1400 22.97 12.2 21 1520 54.1 1000 1030
1720 36.72 20.4 18 1880 69.2 1000 1060
2160 55.22 25.9 20.3 2320 78.9 1030 1240
2600 57.31 19.6 25.5 2760 92.5 1230 1310
3160 95.97 35.3 21 3360 106.8 1420 1390
3800 118.1 34.5 21.8 4040 99.2 1220 1390
3760 6.47 5.5 21 3480 34.6 1000 1060
2960 113.58 100 18 3040 144.4 2150 1760
3360 176.67 100 11.3 3520 183.5 2120 2130
3840 199.86 100 11.3 4040 172.2 2080 2060
4360 216.17 100 9.8 4520 166.2 1980 2010
4840 224.25 100 11.3 5040 156.4 1920 1930
5320 236.14 100 12.8 5440 152.6 1920 1890
5720 249.19 100 13.5 5880 148.1 1880 1860
6120 252 100 15.8 6240 138.3 1800 1810
6440 252.17 100 15.8 6560 132.3 1780 1780
6680 75.53 19.6 17.3 5920 10.5 1000 1220
5160 16.56 7.8 16.5 5120 11.3 1000 1080
5000 16.78 7.8 15.8 4760 11.3 1000 1080
Clive
My timing is still quite a bit higher than yours for some strange reason.
4360 rpm you 9.8 me + 2
4840 rpm you 11.3 me + 2
5320rpm you 12.8 me + 4
5720rpm you 13.8 me + 5
6120rpm you 15.8 me + 6
+ 6 degrees must make quite a bit of diff. Would the cold weather really make that much diff to timing?
Looking back even before my pre cats were done I still have around + 2-3 or so on your timing
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
