Exhausts!! It's time!! Which One :-)
4.2 V8 32v FSI - 444 bhp
Which Exhaust do you have; or would you get?
Akrapovic
25
45%
Capristo
8
14%
HMS
1
2%
Armytrix
0
No votes
Don't be silly - Milltek it is
10
18%
JCWeld - Currently Development
12
21%
Total votes: 56
neilparf
Re: Exhausts!! It's time!! Which One :-)
Post by neilparf » Mon Sep 14, 2015 5:54 pm
RossDagley wrote:
ROjj wrote:I'm convinced my stock gets louder each time I drive it, if only there was a way of continuing the sound at cold start. Quickly put it into sport then back to park and blip...woof. How can I get that all of the time?!?!
JCWF...
This.
Gone but never forgotten:
Noyjatat
Post by Noyjatat » Mon Sep 14, 2015 6:10 pm
The downpipes have some terrible restrictions too.
Afsimba
Post by Afsimba » Mon Sep 14, 2015 9:42 pm
Can't wait to hear this hope it's all good quality looks amazing
RIV
Post by RIV » Mon Sep 14, 2015 9:45 pm
Looking good, post up a vid when it's fitted :beerchug:
Afsimba
Post by Afsimba » Mon Sep 14, 2015 10:03 pm
Thanks riv ! Never tried to post a vid before so hopefully I will manage
I'm very impressed with the quality and price point thanks to the euro !
Initially wanted an akra but this was a total no brainer with currency rates . The quality looks immense
Not heard anything exhaust wise on these cars except the standard sports so fingers crossed it's great
esp_mm-270
Post by esp_mm-270 » Tue Sep 15, 2015 8:58 am
neilparf wrote:Dents like that - can you imagine the turmoil in the gas flow through to exit... :audibash:
I'm not a welder but am wondering about the inside of the tube. As with your table the welds can be ground down to look lovely outside but how do you/they make the internal part of the weld not disrupt gas flow like the standard B8 exhaust. Just thinking about it now if the weld is proud or recessed it would disrupt flow and it's not like you can see it to check?
neilparf
Post by neilparf » Tue Sep 15, 2015 10:39 am
Welds on the outside - the metal builds up on the weld side, not internally. I think purge pressure welding helps but looking at mine, and seeing the system starting to be built up when I was at JCWF, there's minimal weld material on the interior.
When I referred to the dent, I was referring to the narrowing of the tube that would upset the flow - looking at Ross' OEM system, they are rife throughout the system and I suspect that many would surely upset the flow...
esp_mm-270
Post by esp_mm-270 » Tue Sep 15, 2015 10:45 am
Ok but with the many pieces of exhaust wouldn't the internal side of the welds be recessed rather than smooth then? As apposed to a one piece tube bent? Or are these less likely to mess up the flow than the stretching of bent pipe? If you see what I mean Neil?
Not poo pooing just I see this and just wondering of the effects :)
v8 omfg
Post by v8 omfg » Tue Sep 15, 2015 11:13 am
I like it!
lots and lots, no time served. It’s gets funnier, from yesteryears cars to ones due in months :piss:
RossDagley
Post by RossDagley » Tue Sep 15, 2015 11:28 am
I agree. I like her too!
Previously:
neilparf
Post by neilparf » Tue Sep 15, 2015 11:36 am
esp_mm-270 wrote:Ok but with the many pieces of exhaust wouldn't the internal side of the welds be recessed rather than smooth then? As apposed to a one piece tube bent? Or are these less likely to mess up the flow than the stretching of bent pipe? If you see what I mean Neil?
I know mark - no poo here ;) I know what you mean...
From what I've seen the internal weld of a pipe is so minimal. Purge welding with Argon gives a flatter inner seam. When welding stainless steel, titanium and other corrosion-resistant materials, it is important to create a perfect weld environment in order to retain the desired corrosion resistance and to eliminate weld contamination. During welding, the heated weld seam is exposed to air and oxidizes if it is not protected. By filling the welded tube with argon, the internal portion of the tube is protected from the oxidizing atmosphere. This gives a weld that is structurally superior and lays flatter for less exhaust flow turbulence
All JCWF's are Argon Purged...
esp_mm-270
Post by esp_mm-270 » Tue Sep 15, 2015 11:39 am
Beautiful, thanks Neil. I used to fill welding gas bottles for boc using co2, argon and helium. Understand their use a bit now :)
neilparf
Post by neilparf » Tue Sep 15, 2015 11:40 am
esp_mm-270 wrote:Beautiful, thanks Neil. I used to fill welding gas bottles for boc using co2, argon and helium. Understand their use a bit now :)
:biggrin2: :thumbs:
smudge
Post by smudge » Tue Sep 15, 2015 12:05 pm
Afsimba wrote:Not heard anything exhaust wise on these cars except the standard sports so fingers crossed it's great
Here's a few of my Cap:
https://www.youtube.com/user/exclusiveNo1/videos
Still loving it - you won't be disappointed.
:thumbs:
It's all torque talk.
GordonBoy
Post by GordonBoy » Tue Oct 06, 2015 3:57 pm
Hi
Any update and picture on the JCWeld exhaust?
Users browsing this forum: No registered users and 238 guests
