Cruise Control
TimDogg
Re: Cruise Control
Post by TimDogg » Thu Aug 02, 2012 12:31 am
Great topic showing how awesome RS246 members are, really good to read!
'56 ST220 (Sold)
'97 ST24 (Sold - loved lots)
RS Owner
Re: Cruise Control
Post by RS Owner » Sat Apr 27, 2013 4:47 pm
:biggrin3:
Thanks very much D_K and TonyHayers.
In summary, if
  • your cruise control will not work
  • the starter button must be held down until engine starts (normally just a quick push)
  • you find your gear changes are not as smooth as they used to be
then your clutch switch needs replacing. Easy to do yourself, I have attached the instructions I used but I found the job to be easier than the instructions make it sound (and you do not need 3 hands as they say). Takes 10 minutes including replacing panel.
I don't normally tinker with the RS4, I have just done mine myself and it is a very satisfying feeling.
Replace a Clutch Switch Part 1.pdf
(678.24 KiB) Downloaded 156 times
Replace a Clutch Switch Part 2.pdf
(931.1 KiB) Downloaded 145 times
Gone : 2017 M3 CP
hughes457
Re: Cruise Control
Post by hughes457 » Fri May 17, 2013 6:54 pm
omg i thought that was the norm,,,,
i too have the same problem and need to do the exact same thing....a big thumbs up rsowner
im a lot happier i spent time going through the forum now
