Clutch problem...
TimDogg
Re: Clutch problem...
Post by TimDogg » Fri Jul 20, 2012 6:18 pm
I'd go to MRC mate.
'56 ST220 (Sold)
'97 ST24 (Sold - loved lots)
vestax32
Post by vestax32 » Fri Jul 20, 2012 8:27 pm
Does anyone know the part number for the guide sleeve on the input shaft? Apparently this part has been modified by Audi so if I can draw their attention to this I may get somewhere?!
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
66 Sapphire BMW F80 M3.
18 Mythos Black RS4
14 Daytona Grey RS6
08 Monza Silver RS6 Avant
07 Phantom Black RS4 Avant
Loads of BM's inc. 4 x M's
sar
Post by sar » Fri Jul 20, 2012 11:28 pm
vestax32 wrote:Does anyone know the part number for the guide sleeve on the input shaft? Apparently this part has been modified by Audi so if I can draw their attention to this I may get somewhere?!
i had read this somewhere aswell but i asked my parts man at my local TPS and as far as he could tell from the computer the part number has never changed or been superseded.
i can dig the part number out for you if you want as i still have mine, but i now dont think that the guide sleeve is causing the problem.
i suffered from the sticky down-slow returning clutch pedal problem and grizz at unit20 has just fitted a loba clutch and flywheel to mine to cure the problem.
i had bought the loba clutch-kit a new guide sleeve and release bearing, but on stripping mine down grizz said the guide sleeve was in mint condition no marks or grooves so didn't change it.
mine seems like its fixed now so it was either the - flywheel? - clutch plate? - pressure plate? - release bearing?.
i have never fitted a new clutch return pipe or changed either the master or slave cylinders.
ArthurPE
Post by ArthurPE » Fri Jul 20, 2012 11:30 pm
what did the interior of the release bearing look like?
sar
Post by sar » Fri Jul 20, 2012 11:34 pm
i never got to see it arthur, grizz didn't comment on it so i presume it wasn't horrendous.
ArthurPE
Post by ArthurPE » Fri Jul 20, 2012 11:47 pm
sar wrote:i never got to see it arthur, grizz didn't comment on it so i presume it wasn't horrendous.
it looks like 2 types were used
seems like hydraulics have been eliminated
seems like the release bearing guide bushing has been eliminated
that leaves the clutch, perhaps when hot the springs get weaker and can't snap back, and push the slave cyl piston back
perhaps the clutch release bearing hangs up, not allowing the clutch to fully return
http://elsaweb.spaghetticoder.org/doc/A ... 25757427/3
looks like wear on the release bearing can be an issue
ArthurPE
Post by ArthurPE » Sat Jul 21, 2012 12:38 am
here's the guide sleeve (can't tell if it's the old or new one)
SLEEVE (0A2-141-181) http://parts.audiofalexandria.com/produ ... d181).html
http://www.jimellisaudiparts.com/produc ... 41181.html
no hold down screws, looks like it will float/rotate, perhaps the revise part is bolted down?
some have said this fixed the problem
after looking at it there is a clip that retains it, but perhaps it still spins
most look like this
ArthurPE
Post by ArthurPE » Sat Jul 21, 2012 1:17 am
the sleeve is common to many models
this one is the newer version, I THINK
http://www.europaparts.com/clutch-relea ... 1181a.html
Audi A4 2002, 2003, 2004, 2005, 2006, 2007, 2008
Audi A4 Avant 2002, 2003, 2004, 2005, 2006, 2007, 2008
Audi A4 Cabriolet 2003, 2004, 2005, 2006, 2007, 2008, 2009
Audi A4 Quattro 2003, 2004, 2005, 2006, 2007, 2008, 2009
Audi A4 Quattro Avant 2002, 2003, 2004, 2005, 2006, 2007, 2008
Audi A6 2009, 2010, 2011
Audi A6 Avant 2009, 2010, 2011
Audi A6 Quattro 2009, 2010, 2011
Audi RS4 2006, 2007, 2008
Audi RS4 Cabriolet 2008, 2009
Audi S4 2009
Audi S4 4.2L 2003, 2004, 2005, 2006, 2007, 2008
Audi S4 Avant 2002
Audi S4 Avant 4.2L 2003, 2004, 2005, 2006, 2007, 2008
Grizz, do you recall which one was in the did the clutch for?
the 2 part, sleeve with clip
or the 1 piece with the bolted flange
I'm not sure which is the old type vs new type
this car had a sticky clutch, the bearing was hanging up on this guide sleeve
vestax32
Post by vestax32 » Sat Jul 21, 2012 2:29 pm
I have spoken to someone at MRC and he hadn't heard of the guide sleeve problem, but has changed lots of clutch return pipes (Part No. 8E0721465) for the same problem and this seems to cure it. As this is an easyish job I will try this first then go to the input shaft guide sleeve if it doesn't work.
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
adsgreen
Post by adsgreen » Sat Jul 21, 2012 4:16 pm
I would also raise a case with Audi customer care.
Mainly to ask where you stand warranty wise as you've reported the issue inside warranty period
vestax32
Post by vestax32 » Sun Jul 22, 2012 12:37 pm
As I said, I have already taken it to Kidlington Audi and they tell me there is nothing wrong with it, obviously I'm just making it up for a laugh, and enjoy driving to Kidlington in the rush hour! To be honest if the clutch return pipe fixes it which is a small job then Ill just get it done at my partners dads garage. If however it turns out its the guide sleeve then ill wait until the Inchcape warranty kicks in which means I can take it anywhere to be fixed, and get it done then.....
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
ArthurPE
Post by ArthurPE » Sun Jul 22, 2012 8:22 pm
vestax32 wrote:I have spoken to someone at MRC and he hadn't heard of the guide sleeve problem, but has changed lots of clutch return pipes (Part No. 8E0721465) for the same problem and this seems to cure it. As this is an easyish job I will try this first then go to the input shaft guide sleeve if it doesn't work.
I had the hose changed by the dealer
also new slave
fluid flushed
and heat shield/sleeve on the line
still happens, a bit less, but repeatable
if I rev the engine in neutral a few times, it will do it
adsgreen
Post by adsgreen » Sun Jul 22, 2012 8:34 pm
ArthurPE wrote:still happens, a bit less, but repeatable
Thats a good bit of info - worth trying as you'll be able to show an Audi tech easily.
vestax32
Post by vestax32 » Mon Jul 23, 2012 8:55 pm
Yes indeed, will try this tomo....
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
vestax32
Post by vestax32 » Mon Jul 23, 2012 8:57 pm
Have you had the input shaft guide sleeve done?
also new slave
fluid flushed
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Users browsing this forum: No registered users and 172 guests
