New RS4 Owner
arnnie
Re: New RS4 Owner
Post by arnnie » Sat May 26, 2012 7:18 pm
Cheers for all the comments guys about the car, its great to have such a nice response when first posting on the forum. I must say i cant wait to pick the car up and aim to take some nice photos of it over the jubilee weekend and post them up when i finally get her home after the long trip to Boss.
Thank you also for the comments with regards to the exhaust, i would like an exhaust however i don't want the cabin drone, however i do want it loud outside just not in on the motorway runs. Prior to this i had a new shape Focus RS and i had a Milltek on that which was great on the motorways but sounded lovely when you opened it up, believe that was resonated and would be looking for similar for the RS4 :mrgreen:
rwilsonrs4
Re: New RS4 Owner
Post by rwilsonrs4 » Sat May 26, 2012 7:38 pm
Don't get me wrong , the Miltek sounds awesome and i don't regret getting it as it certainly turns heads , the cabin resonance is ONLY at 1800 -1900 ish rpm , it is quiet in the cabin at all other times at any road speeds and rpm other than stated and as i said you can drive around it by either running a gear higher or lower depending on your speed and tbh its only in town that i have this issue as its low down the rpm range , but thats just my personal opinion with mine
1/4 mile 12.01 secs 123.5mph
arnnie
Re: New RS4 Owner
Post by arnnie » Sat May 26, 2012 7:49 pm
rwilsonrs4 wrote:Don't get me wrong , the Miltek sounds awesome and i don't regret getting it as it certainly turns heads , the cabin resonance is ONLY at 1800 -1900 ish rpm , it is quiet in the cabin at all other times at any road speeds and rpm other than stated and as i said you can drive around it by either running a gear higher or lower depending on your speed and tbh its only in town that i have this issue as its low down the rpm range , but thats just my personal opinion with mine
Many thanks for the detailed reply with regards to this, sounds a little like the one on my RS was, would you say the valved option was worth it? As i noticed it quite a bit more expensive and seems to me something else to go wrong. Having never driven an RS4 what RPM would you say would be motorway cursing around the 75-80mph mark?
stu
Re: New RS4 Owner
Post by stu » Sat May 26, 2012 7:57 pm
Well done on the mugello blue / optic combo - about 18 months ago I very nearly bought an avant with the setup. Beautiful combination. I ended going for a local car in daytona that ticked 99% of the boxes for me. FON :D
rwilsonrs4
Re: New RS4 Owner
Post by rwilsonrs4 » Sat May 26, 2012 8:25 pm
The valved option is way more expensive as you have seen ,the valves are open in S mode at idle and then between 1000 and 4000 rpm they are closed in gear 1,2 and 3 and then open again above 4k ( some crap about drive by noise legslation )but open at all times when in 4,5 and 6 when in S mode
an option may be to go for a second hand one , they come up regularly on here and ebay when ppl move the cars on as dealers won't give more money in a trade in and some people don't want them, the whole original exhaust comes off behind the cats in one piece so is easy to remove and refit if needed (transporting or storing it may be tricky but some places will keep your exhaust for you while the milly is on the car ), the valves don't really give trouble , at worst they may stick after a long time , but some lube sorts them out. As I said I had the valves disconnected a while which would be the same as none fitted obviously ,and it was much louder and more intrusive inside , and I have the resonated centre section on mine .
basically its 25mph per 1000 rpm in 6th gear so quite low geared for such big engine. Cruising on the motorway your at about 3000/ 3300 depending on your mood :-) so well above the drone , its not an issue then at all
arnnie
Re: New RS4 Owner
Post by arnnie » Sat May 26, 2012 9:16 pm
rwilsonrs4 wrote:The valved option is way more expensive as you have seen ,the valves are open in S mode at idle and then between 1000 and 4000 rpm they are closed in gear 1,2 and 3 and then open again above 4k ( some crap about drive by noise legslation )but open at all times when in 4,5 and 6 when in S mode
Cheers for the great reply, and that is alot lower geared than i expected. I did notice a few millteks up for sale in the classified areas and i must say it is on top of the list of things to get for the car. Cheers for all the help with regards to it, have to see if there are some local RS4 owners who have an exhaust similar to what i am after so i can have a listen before hand.
arnnie
Re: New RS4 Owner
Post by arnnie » Sat May 26, 2012 9:17 pm
stu wrote:Well done on the mugello blue / optic combo - about 18 months ago I very nearly bought an avant with the setup. Beautiful combination. I ended going for a local car in daytona that ticked 99% of the boxes for me. fON :D
Cheers for the reply :mrgreen: I must say this one being in Bury and me being in kent isnt local however it was at the right price and after seeing the blue and black combo it won my heart and hence i am making the trip. Cant wait for the drive home :D
PJC
Re: New RS4 Owner
Post by PJC » Sat May 26, 2012 9:20 pm
Pop along to the next Kent meet if you can.
arnnie
Re: New RS4 Owner
Post by arnnie » Sat May 26, 2012 9:22 pm
PaulRS4 wrote:Pop along to the next Kent meet if you can.
Hi Paul,
Think you could give me some more details on that? As i would be very interested.
Chris
PJC
Re: New RS4 Owner
Post by PJC » Sat May 26, 2012 9:26 pm
Here you go Chris,
Where is Kent are you pm if you prefer.
http://forum.rs246.com/viewtopic.php?f=10&t=96793
sutts
Re: New RS4 Owner
Post by sutts » Sun May 27, 2012 10:00 am
Hi, that is a great looking car that you will be picking up. I am also in Maidstone and have recently bought a 56 plate Daytona Grey Avant, so may well see you about :beerchug:
Mine's completely standard and I would be interested to see/hear what yours is like with the Milly if you go for it. Was yours the white Focus RS I used to see around the town?
Daytona Grey B7 RS4 Avant
HoopsRS4
Re: New RS4 Owner
Post by HoopsRS4 » Sun May 27, 2012 11:51 am
Terry1948 wrote:Black exhaust tips were part of the optics pack
Correct - and mine has them too.
RS4 B7 Avant
Daytona Grey
Black Optic Pack
Milltek Non-Res Valved with Satin Black Tips
BMC Filter
H&R Springs
C6 RS6 20" Alloys
Conti 5P's
arnnie
Re: New RS4 Owner
Post by arnnie » Sun May 27, 2012 3:00 pm
sutts wrote:Hi, that is a great looking car that you will be picking up. I am also in Maidstone and have recently bought a 56 plate Daytona Grey Avant, so may well see you about :beerchug:
Hi, well if you fancy a meet up once i get the car be more than happy to do that as be nice to meet another owner in the local area :beerchug: Yes i could well have been my Focus RS, was white with Anthracite Wheels, black ford badges and Milltek / Mountune system on it. Was a nice car i just missed 4WD having had a high power Evo before it.
Hopefully get a nice system on the RS4 not to soon after i pick it up :mrgreen:
Users browsing this forum: No registered users and 131 guests
