Any owners out there know something we don't ?
Timster
Re: Any owners out there know something we don't ?
Post by Timster » Fri Mar 30, 2012 10:52 pm
Actually Dave... I think you've probably mentioned it more like 10 times since last year.
Are you all blind ! :shock:
Post by Ian_C » Fri Mar 30, 2012 10:54 pm
The little sprung metal flap a few inches inside your fuel filler neck that the fuel pump nozzle pushes in? You supposed to push it in with your finger before filling up?
Timster
Post by Timster » Fri Mar 30, 2012 11:51 pm
Ian_C wrote:The little sprung metal flap a few inches inside your fuel filler neck that the fuel pump nozzle pushes in? You supposed to push it in with your finger before filling up?
No.
On the B7 (dunno about your S4), there's a small black nipple (phnaw phnaw).. about an inch down on the LH side. Inside the filler tube.
That's what you have to push.
It's tricky to push the nipple (snigger) with both your finger and hose inserted.
(think I just felt something "twinge")
victor2vt
Post by victor2vt » Sat Mar 31, 2012 12:25 am
EXACTLY !!! Tried a few times to find the bloody thing, never mind push it :thumbsdown:
Mint Optic Pack saloon in Daytona Grey (Now sold)
B7 RS4 in Sprint Blue (Gone to a very good new home)
Evo V1 (wish i'd kept)
Numerous M3s
RS6chris!
Post by RS6chris! » Sat Mar 31, 2012 8:18 am
No.
Used to press my black nipple all the time.. :bigblink:
Anyway..my method was...
Fill car to brim
keep filling until petrol pump was clicking off again and again
remove nozzle from filler neck
press button
you can hear the air being forced out
nozzle back in
few more litres in
Repeat above process until the level of petrol can be seen just on the metal flap.
Hey presto a tank holding an extra 7 odd litres maybe.... :beerchug:
NOT TO BE TRIED WITH THE CURRENT PETROL FORECOURT QUEUES!!! Its time consuming and youll probably get lynched.. :<beep>_you:
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
P_G
Post by P_G » Sat Mar 31, 2012 8:41 am
PetrolDave wrote:This has to be a strong contender for the most asked question on here - I've posted "how to" at least 3 times on this.
And yet I knew so many would say "I've never heard of this" and like you say it has been mentioned I can't remember how maany times in the 4 years I have beeen frequenting this forum.
For the uninitiated, go and look inside your fuel filler nozzle and you will see what looks like a switch on one side. Next time you brim your tank to the point fuel is in the nozzle, TAKE THE FUEL PUMP OUT MOMENTARIALLY TO ALLOW ACCESS BY HAND TO THE SWITCH; either push or pull the switch and you will hear a hissing sound and the fuel in the nozzle will disappear; essentially it allows air to escape from the tank and I believe flow into the reserve as well. Good for another 5 litres in some instances but best not used if on a hot day and you aren't going to use the extraa fuel immediately as it is technically the tank should have some airin it as an expanssion gap. Great on cold days though for an extra 20-40 miles.
PetrolDave
Post by PetrolDave » Sat Mar 31, 2012 10:13 am
sonny wrote:lol first time I have heard this, I dont even know what button your talking about. Is it an "Avant" thing?
Nope it's on all B6/B7 A4/S4/RS4 saloon (sedan), Avant and cabrio models.
Take the fuel filler cap off and look inside the pipe, on the side at the rear of the vehicle you'll see a small (approx 5mm) round "nipple". Fill until the pump stops and then slide the filler nozzle slightly out, enough to get a finger in the pipe and push the nipple down and hold it, make sure the filler nozzle is still far enough in to open the one-way flap in the pipe. Then you can, slowly, get another 5-9 litres into the tank - depending on how fast the pump normally is and how early it stopped.
sonny
Post by sonny » Sat Mar 31, 2012 3:22 pm
Its crazy as its the first time if seen it on here :bash:
Thanks will do it when I next fill up! We literary learn something new every day.
Post by Ian_C » Sat Mar 31, 2012 5:25 pm
Cheers guys, something to try next time, would love to beat my previous best of 65.5 litres, especially considering Audi quote a 66 litre tank
PetrolDave
Post by PetrolDave » Sat Mar 31, 2012 5:40 pm
Ian_C wrote:Cheers guys, something to try next time, would love to beat my previous best of 65.5 litres, especially considering Audi quote a 66 litre tank
My record is 69 litres, and the DIS was showing 20 miles left so thewre was probably still more than 4 litres in the tank.
Post by Ian_C » Sat Mar 31, 2012 5:44 pm
Wow! Yeah DK says goes to zero with a gallon left - 4.54 litres. So that's more like 76 litres than 66 litres!
DavidRS4
Post by DavidRS4 » Sat Mar 31, 2012 9:23 pm
Loving the tip about holding the key fob to open and close the windows!
alex020869
Post by alex020869 » Sat Mar 31, 2012 9:27 pm
DavidRS4 wrote:Loving the tip about holding the key fob to open and close the windows!
That is one of my favouites when i park up and walk away from the car and close the windows and sunroof. I'm sure there are people seeing everything close and wondering if there are special sensors in the car doing this. lol
Alex
RS4 B7 Mugello Blue Saloon
DavidRS4
Post by DavidRS4 » Sat Mar 31, 2012 10:44 pm
Holding the auto button on the climate control is another good one. Tried them both tonight. Love the RS4 to bits. Such an amazing all round car!
PetrolDave
Post by PetrolDave » Sun Apr 01, 2012 9:50 am
If it's correctly coded you can also open the windows and doors by pressing and holding the key fob - but not the sunroof (even if you code it to enable this it doesn't work).
