Rough running when cold
Revolution
Trader (Expired)
Re: Rough running when cold
Post by Revolution » Thu Sep 22, 2011 10:47 am
we will defo be a custom map....cant speak for AMD
filter done and injector clean next
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
spikeyboy101
Post by spikeyboy101 » Fri Sep 23, 2011 10:16 am
Thanks guys - dont know about the AMD remap - they can take the Torque limiter off - so will ask them to do that.
Mian reason im going for the AMD remap is that its half prcie with the millteck - so only £250 - will tide me over until i decide to go for the Sports Cats, then will get a custom re-map probably from MRC.
Plus i get the car rolling roaded with the AMD re-map sp can see what power its putting out and geting anything fixed that needs it.
Car recently serviced, just done the Wynns petrol cleaner, and have the K&N air filter.
adsgreen
Post by adsgreen » Fri Sep 23, 2011 10:59 am
you can solve most of the SW080 problems by manually doing the same thing - 30 secs at 2000 revs sorts it.
Or just leave at idle for a couple mins say whilst loading. Its likely to be the cat warm up phase and the secondary air injection playing around with low throttle openings.
s4bandit
Post by s4bandit » Thu Jun 14, 2012 4:44 pm
i switched from Vpower to BP97 and the problem has gone now and the car is running much better and faster than before :-)
B7 RS4 saloon Black with black optics pack
previous
C5 RS6 avus silver Milltek with remap 493bhp
E46 M3 ( had to give it a go, hated every minute )
B6 S4 saloon Black
B5 S4 silver MRC tuned stage 1
RobbyRS4
Post by RobbyRS4 » Fri Jun 15, 2012 6:18 am
s4bandit wrote:i switched from Vpower to BP97 and the problem has gone now and the car is running much better and faster than before :-)
Me too!
Terry1948
Post by Terry1948 » Fri Jun 15, 2012 10:25 am
Sometimes if you use a petrol garage that is not busy then the fuel will be old and it does go off. Much better to use a busy garage where there is a goo dturn round be it bp or shell or texaco. Fill your car up and dont use it for 6 months and see how rubbish it runs.
adsgreen
Post by adsgreen » Fri Jun 15, 2012 10:46 am
Terry1948 wrote:Sometimes if you use a petrol garage that is not busy then the fuel will be old and it does go off. Much better to use a busy garage where there is a goo dturn round be it bp or shell or texaco. Fill your car up and dont use it for 6 months and see how rubbish it runs.
It's very true.
Old advice for storing a car was to brim the tank as this prevented corrosion. However current adivce is to leave as empty as possible as modern tanks don't suffer with this problem.
Users browsing this forum: Google Adsense [Bot] and 339 guests
