Dectane
P_G
Re: Dectane
Post by P_G » Tue Mar 29, 2011 9:34 am
andre, the two you have selected are exactly like the BM-Town ones and have bilbs rather than LEDs for the fog, reverse and indicator lights.
I think the Li-Tec ones are OK and may opt for the RA12SLRCL instead and the indicator LED block resembles the OEM B7 cluster rather than being an l-shape.
Timster
Re: Dectane
Post by Timster » Tue Mar 29, 2011 9:45 am
Dannyrs4 wrote:I've got an issue with my lighting the now ever since I've fitted the LEDs which look superb btw. when I'm driving and I have my light switch set to off I have front sidelights on but the rears are off, any idea's?
Nothing to do with the DRL's is it?
Or am I being a bit obvious.
Stoffle32
Re: Dectane
Post by Stoffle32 » Tue Mar 29, 2011 10:19 am
Has anybody tired these for the DRL's from Dectane!
They state they 21W tested, which has always been the problem with past LED's for the DRL's even with the Canbus!
https://www.dectane.de/product_info.php ... 57d824327a
andre3k
Re: Dectane
Post by andre3k » Tue Mar 29, 2011 4:27 pm
P_G wrote:andre, the two you have selected are exactly like the BM-Town ones and have bilbs rather than LEDs for the fog, reverse and indicator lights.
I think the Dectane ones are a little different. The line of LEDs nearest the fogs seems much less angular with a bit of a curve to them which means there aren't as many LEDs in that bank (6 Dectane vs. 8 BM Town). Also, they have two versions of these on their website, the more expensive of which (€269) are all LED as far as I can work out save for the reverse lights:
.LED Position light
.LED Brake light
.LED Indicator
.LED Fog light
.Rear light
.reflector included
.compatible with board computer
.E Mark
.bulb and wire included
.set includes 4 pieces
PetrolDave
Re: Dectane
Post by PetrolDave » Tue Mar 29, 2011 4:37 pm
Check the DRL coding - there are 2 options - front only, or front & rear.
S4Player
Re: Dectane
Post by S4Player » Tue Mar 29, 2011 6:52 pm
My drl's are off though? As in the little switch is at zero so I assume they should be turned off?
PetrolDave
Re: Dectane
Post by PetrolDave » Tue Mar 29, 2011 7:13 pm
Dannyrs4 wrote:My drl's are off though? As in the little switch is at zero so I assume they should be turned off?
So why are the front lights on at all?
Still worth checking the coding IMHO.
S4Player
Re: Dectane
Post by S4Player » Tue Mar 29, 2011 7:19 pm
That's what I don't understand light switch is at off and drl switch is at off.but front sidelights stay on all the time but rears are off it's a real pita
Guernsey70
Re: Dectane
Post by Guernsey70 » Thu Mar 31, 2011 9:21 pm
Hi
I'd like to get some rear lights for my silver saloon. Could someone tell me which ones are as close to what Audi are rolling out at the moment?
Also, where could I get them fitted or are they easy to do yourself?
G70
S4Player
Re: Dectane
Post by S4Player » Thu Mar 31, 2011 9:26 pm
Dave could you pm me how to check the coding because this issue is annoying me. I'll post pictures of the lights on my car they look great
PetrolDave
Re: Dectane
Post by PetrolDave » Fri Apr 01, 2011 6:06 pm
Dannyrs4 wrote:Dave could you pm me how to check the coding because this issue is annoying me.
See here http://wiki.ross-tech.com/wiki/index.ph ... 8EC/8ED%29
Timster
Re: Dectane
Post by Timster » Fri Apr 01, 2011 8:43 pm
Dannyrs4 wrote:That's what I don't understand light switch is at off and drl switch is at off.but front sidelights stay on all the time but rears are off it's a real pita
Now I'm not stating that this is the problem.... but certainly with domestic LED lamps (the 240v GU10 type for example): You can sometimes have a glow from the lamp even with the positive feed disconnected.
This is due to live induction into the neutral return.
Not sure if this is ever an issue with automotive 12V electrics and l.e.d.s
Just a thought.
S4Player
Re: Dectane
Post by S4Player » Fri Apr 01, 2011 9:24 pm
It doesn't look like a glow tim it's as if my sidelights are actually on all day and my drl switch is off
Timster
Re: Dectane
Post by Timster » Sun Apr 03, 2011 12:32 am
Sounds like an incompatibility between the new lamps and the car then.... send 'em back.
MB2
Re: Dectane
Post by MB2 » Sun Apr 03, 2011 1:14 pm
Danny - is it your side-lights or your DRLs that are on all the time as trouble-shooting will depend upon which one is lit up ?
Users browsing this forum: Google [Bot], Zyox and 215 guests
