Cams
2.7 V6 30v biturbo - 380 bhp
frazered
Post by frazered » Wed Aug 26, 2009 9:06 pm
if you read the thread linked to, it was doing it for quite a short time - looking at the 3rd page it was a very close shave!
mikeyquattro
Post by mikeyquattro » Wed Aug 26, 2009 9:16 pm
missmouse wrote:Ah! it must be going for a bit before that happens tho?
Quote RSPaul
"Well, that was a close shave! Apparently my car is the new record holder of "engine getting the closest to lunching itself" Doug reckons that another 50 miles or so would have killed it!
The exhaust cam lobe on the drivers bank is practically worn away and there is a huge hole in the top of the lifter. As Doug says, if you get any ticking noises at all, get the car checked out. Mine only started doing it this week and was absolutely flying right up to the point I switched it off! "
Tomorrow is another day
MilkybarKid
Post by MilkybarKid » Thu Aug 27, 2009 3:04 am
No mate, unfortunately not.
Once the tip of the lobe is off its game over, no ones sure of how long it takes, but from seeing Pauls cams in person and the lifter in pics, Doug was being optimistic at the 50m claim, more like 5!
Ive got the cams here ifyou want to have a look
RS4_Schumi
Post by RS4_Schumi » Thu Aug 27, 2009 7:47 pm
Is checking them something any VAG mechanics would manage --- or would it be better done by one of the specialist RS places.
Obviously if they need replacing I'd be doing it a specialist but would my local spanner man be able to have a look without doing too much damage?!!
RS4 B5, Ebony Black, Miltek & MRC Magic: 450bhp
ollys
Post by ollys » Thu Aug 27, 2009 7:49 pm
RS4_Schumi wrote:Is checking them something any VAG mechanics would manage --- or would it be better done by one of the specialist RS places.
Should do - takes between 1 - 1.5 hours per side to whip the covers off and inspect and replace. You need to be ready with replacement gaskets though when they go back on.
RS4_Schumi
Post by RS4_Schumi » Thu Aug 27, 2009 7:56 pm
And is it imperative to check both or if the driver's side's fine are you good to go..? I'm going to get them to do my plugs as well -- would that overlap some of the same work?
Contigo
Post by Contigo » Thu Aug 27, 2009 7:56 pm
So if the Cams lobes are loosing shap and the purpose of the lobes is to move the followers/lifter then wouldn't the malforming of the shape of the Cam lobes cause problems with the intake and exhaust stages? And what would be the effect on the running of the vehicle if the lobes weren't coming into contact with the followers.
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
missmouse
Post by missmouse » Thu Aug 27, 2009 10:44 pm
slightly off the oringinal topic here, are there any aftermarket cams available for RS4? OR, is it worth getting a not too badly worn cam reground & re hardened? this kind of thing was available 30 years ago for tuned engines.
avus1
cams
Post by avus1 » Tue Sep 01, 2009 8:10 pm
Checked mine today, not too bad a job, 89000 miles, long life services until i got an they all look like new!!!! thankfully!!! :o
avus1
RE: cams
Post by avus1 » Tue Sep 01, 2009 8:20 pm
oh and it did have a ticking noise, while i was dirty i thought id have a dig around!!! its coming from the goldy coloured unit bolted on the back of the drivers cylinder head!!! any ideas????
2001 RS4 B5 MTM Chip
Airbox Mods, Panel Filter
RS6 Front Brakes
H&R Springs
Contigo
RE: cams
Post by Contigo » Tue Sep 01, 2009 8:37 pm
The Injectors are noisy on these and give that ticking sound on tickover.
2006 BMW M6 - GONE
S4INT
Re: RE: cams
Post by S4INT » Tue Sep 01, 2009 8:40 pm
avus1 wrote:oh and it did have a ticking noise, while i was dirty i thought id have a dig around!!! its coming from the goldy coloured unit bolted on the back of the drivers cylinder head!!! any ideas????
Could be the cam chain tensioner?
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
avus1
RE: Re: RE: cams
Post by avus1 » Tue Sep 01, 2009 8:55 pm
i did check the chain as my old 16v golf had the same set up and the chain was perfect, can the tensioner rattle without loosenin the chain??
RS6 Front Brakes
H&R Springs
TopBear
Re: RE: cams
Post by TopBear » Tue Sep 01, 2009 11:20 pm
What's this about a 'cam chain tensioner'? The B5 has a cam-belt
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
imolas4uk
Re: RE: cams
Post by imolas4uk » Tue Sep 01, 2009 11:49 pm
the cam belt only drives the exhaust cam from that cam there is a chain to drive the inlet cam (in each head)
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
Users browsing this forum: No registered users and 95 guests
