No Turbos
Post by Shoppinit » Tue Jul 28, 2009 9:43 am
I think the TCU has to be opened and soldered :( Perhaps someone who has had it done can confirm or deny.
jd_hants
Post by jd_hants » Tue Jul 28, 2009 10:05 am
hmmmm sounds a bit too invasive. I had a remap done on a BMW 325 years ago which involved replacing the EPROM in the ECU. Sods law, the ECU failed a year later and left me in limp mode. Had to take to the nearest BMW garage. They replaced the ECU as it was actually a faulty coil which caused the problem. They sent the original ECU off back to Bosch in case they wanted to anayse it. Was crapping myself for months thinking they would come back to me and get me to cough up as it had been modified!!!!
jd_hants
Post by jd_hants » Tue Jul 28, 2009 2:39 pm
Just programmed the ECU back to original. Has cleared the fault codes. Not driven car yet but will see if the turbos cut in on the way home and see what fault codes are recorded when I get home. Im sure the engine mount one will be back but it will be interesting to see if the other reappears. If not then maybe it is something to do with the map. Will have to get on to CelticTuning and see what they say. Maybe its not been reported before!
As a side, now that the standard map is back. Ive booked the car into Southampton Audi for the suspension to be 'looked at' as I think its starting to sound and act a bit too dodgy now!!!! I was going to go for Camberley Audi, but Southampton Audi is only 3 miles from me and as noone seems to have used them or have anything bad to say I may as well give them a go - what could possibly go wrong!!!!!
jd_hants
Post by jd_hants » Sat Aug 01, 2009 1:04 pm
Just for completion of this thread.
I reflashed the original map back in and all is fine. No engine lights. No faults, apart from the engine mount, which incidentally Audi didnt mention when it went in recently even though I told them the engine light had been on. Presumably the engine mount fault IS a recognised Audi fault and not just a generic one which has no relevance on an RS6?????
Anyway, the original problem DOES seem related to the new map and the engine going into a non-turbo mode with the fault relating to gearbox/engine communication or maybe it is due to the engine mount fault and just tipping it over the tolerance because of the extra hp the remap provides. either way its the map. I will post my findings to Celtic Tuning for them to investigate! thanks for all your help.
Post by Shoppinit » Sat Aug 01, 2009 1:08 pm
Sounds like it could be a checksum error. Could just be a bad flash.
Audi won't generally hook up your car unless you specifically ask them to or if it's to diagnose a problem. If your car has an Audi warranty, they were probably afraid of what they were going to find!
jd_hants
Post by jd_hants » Sat Aug 01, 2009 1:18 pm
I reflashed back to original which cleared all the fault codes. I took the car for a spin and checked the codes again. P0610 Engine Mount was back!!! When I took it to Audi I told them engine light had come on, just so they would check the Fault codes. The guy told me that they hadnt found any fault relating to the engine light. Surely it would have told them about the stored fault as this is a generic OBD-II fault. There is no warranty. Weird!!
ecain63
Post by ecain63 » Sat Aug 01, 2009 2:43 pm
the engine mount code won't bring on the engine light. it just sits dormant while skimming the power from your engine.
The best thing you can do is take it to a good independant and get it changed. i think its 80 quid plus fitting. That will solve the problem.
Eddie
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
jd_hants
Post by jd_hants » Sat Aug 01, 2009 2:49 pm
yes will do thanks. i just thought that they woudl have mentioned it - very odd!
cheers
John
el_ringo
Post by el_ringo » Sun Aug 02, 2009 9:29 am
I had a similar fault about a year ago and the local Audi dealer decided to bypass the sensor (by stuffing in a resistor) instead of fixing it. It only came to light when I had Grizz do the my KWs. I have used Unit 20 exclusively ever since.
Daytona Grey (C5) RS6 saloon, but just a little better...
**** SOLD!!! :( ****
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Viper Tuning (537bhp 604lbft)
Unit 20 TCU remap
Milltek non-res exhaust and downpipes
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
All the options with the exception of stupid air suspension
Tesla Model X 60D
Silly doors and all!
Post by Shoppinit » Sun Aug 02, 2009 9:54 am
el_ringo wrote:I had a similar fault about a year ago and the local Audi dealer decided to bypass the sensor (by stuffing in a resistor) instead of fixing it.
THis is quite a common fix, I believe. WEll, not a bare resistor, but there's a special cable you can buy to fool the ECU that all is good, but I can't find it online.
THe engine mount is a common failure, but it tends to be the electronics that fail, rather than the electronics, hence the quick fix.
jd_hants
Post by jd_hants » Sun Aug 02, 2009 7:25 pm
Is it the whole mount or just a sensor that gets replaced? is it an easy job?
S2tuner
Trader (Expired)
Post by S2tuner » Sun Aug 02, 2009 8:01 pm
jd_hants: do you flash the car yourself? who did your "new improved" map?
jd_hants
Post by jd_hants » Sun Aug 02, 2009 8:09 pm
I used CelticTuning and their eMotion system. Plugs into the OBD2. Read the current map. upload to the pc through usb. email it to CelticTuning. they modify and send it back. upload to the unit and then flash the ECU! takes about 15 mins to read and or flash.
jd_hants
Post by jd_hants » Sun Aug 02, 2009 8:10 pm
p.s. I dont think their is anything wrong with the map. I think maybe its my faulty engine mount which maybe cant take the extra bhp. it was definately noticeable, car was more responsive.
S2tuner
Trader (Expired)
Post by S2tuner » Sun Aug 02, 2009 8:17 pm
Engine mounts do not trigger limp mode, but that's only my experience talking here. Feel free to let your tuner double check their map, as it could well be related to that, althought without seeing the car, I am not pointing any fingers.
Users browsing this forum: No registered users and 257 guests
