Flame Suit On - Another Rolling Road Day
P_G
Post by P_G » Tue Jun 16, 2009 11:05 pm
Excellent Klauster, see you there.
P_G
Post by P_G » Fri Jun 19, 2009 5:23 pm
Attendees;
Klauster RS4 Saloon (Leeds) CONFIRMED
P_G RS4 Avant (Newcastle) CONFIRMED
Caldy Heavily Modified RS4 saloon (Newcastle) CONFIRMED
Mac-Logotech C5 RS6 (Newcastle)
Lengster1 RS4 (possible)
Gogsyp RS4 (possible)
Gogsyp (Gordon), it may be that Mac has to pull out and work instead which I will know later but if so, there is definitely space and time for you on the r/r. Lengster1, are you still alive eough to attend or did you bin yourself and the Gixer in the kitty litter?
Can you guys PM me your numbers if you are still attending so we can call you en route tomorrow? Ta. :wink: 10.30am start BTW.
P_G
Post by P_G » Fri Jun 19, 2009 9:29 pm
Attendees;
Mac-Logotech C5 RS6 (Newcastle) CONFIRMED
Looks like Lengster had died and gone to Gixer / RS heaven; Gordon, look forward to seeing you tomorrow as it looks like we will defo. have enough time and room to have you on the r/r with us. 8)
lengster1
Post by lengster1 » Fri Jun 19, 2009 11:11 pm
Lengster is alive and well Gixer heaven was all good but im pooped after full day on track and 3 n half hour ride home,What time do you think you guys will be there till? Ive a lie in booked and a few things i must do while shops are open.Could you pm ME your number PG? I can give you a buzz when im sorted
P_G
Post by P_G » Sat Jun 20, 2009 8:17 am
I think we are booked until 12.30pm-1.00pm, effectively 2-2.5 hours. PM sent.
P_G
Post by P_G » Sat Jun 20, 2009 6:18 pm
Well, the day was a success for most I hope. The guys at Motoscope really do know their stuff and although from the outside it doesn't look like much, the equipment and service is spot on.
Thanks to all who came along, I'm sure graphs will be posted up soon but from memory the figures were;
caldy 424.6 bhp (AAS 200 cell cats full s/s exhaust + JD Eng. remap + air inbox deflap + cleaned inlet manifold)
P_G 396.8hp 312 ft lbs. (OEM + X-pipe) Max Power at wheels 302.2bhp @ 7,474rpm
Klauster 378.5 bhp (OEM
gogsyp 356.7 bhp (although we reckon his exhaust has a problem with vacuum lines) (OEM+ cleaned inlet manifold))
Mac-Logotech (2004 C5 RS6) (OEM + Mental supersprint full exhaust) 398.6 bhp and 450 ft lbs
Barometric was about 1015 - 1020 mBar and temp varied between 26 and 28 degrees celcius; all running tyres at 40 PSI front and 38 rears IIRC.
So in effect Klauster has gained 50bhp and I have gained 37 bhp since Paramount. Mac would have gained more but being Tiptronic it wasn't playing nice on the r/r and was hard to keep in line without it wanting to change up or down on its own.
Just as a comparison, when caldy had his car remapped by Jeroen the figure was 431.4bhp so pretty close. ArthurPE, sorry but the Dastek roads automically do corrected figures so we can't provide raw data but all runs were done in 4th. ince had a run in Sport and non -sport mode and the only difference was in extra torque in Sport but with the loss of about 2 bhp for 4ft lb gain.
Draw your own conclusions howevere I believe, caldy, Klauster, Mac and I are happy with the figures enough to believe the cars aren't underpowered. And gogsyp is taking his to have vacuum lines looked at before putting it back on again.
Correction factor is tabulated to be 100.9% to 101%
ArthurPE
Post by ArthurPE » Sat Jun 20, 2009 6:32 pm
the numbers look good...
I would expect the modded car to be higher, 5% or so and this would apply to the others...
so without knowing the cf, it would seem that these numbers are in the rated range...
with the exception of the low number, something looks wrong
did he run on the other dyno day?
what gear?
was it corrected for atm P and temp?
those numbers look more representative, with the caveat, would like to see the cf applied...
450 lb-ft! ... stump puller ;)
ArthurPE
Post by ArthurPE » Sat Jun 20, 2009 6:45 pm
reference the edit:
wheel 302/crank 397
the dyno's I've seen (MAHA) that actually measure the losses are about 100 - 110 HP at peak
this would put you right at the rated ;)
P_G
Post by P_G » Sat Jun 20, 2009 6:57 pm
Yes, the Dastek tech. reckoned wheel and crank should be within 100 hp of each other which means the bed was set up right and no losses through traction issues. Any more and these factors are not correct.
P_G
Post by P_G » Sat Jun 20, 2009 7:00 pm
ArthurPE wrote:the numbers look good...
what gear?
All runs in the RS4's were done in 4th as was the RS6 in Tip Sport mode. The Dastek road automatically corrects for atm p and temp and with each car it has a learning period based at 3000 rpm before the power runs are done and records from 2000 rpm+ to eliminate initial traction slippage.
gogsyp didn't run at Paramount, however it was clear there was something wrong with his car because there was a pronounced rattle from his exhaust. When in normal mode it sounded a little like diesel clatter, alleviated when Sport mode was engaged but when it was then revved it almost sounded like the actuator valves were rattling in the escaping gas like there was no vacuum present to the actuators? Given the same vacuum system runs the inlet manifold flaps I suspect there is an issue with the entire vacuum system and therefore the ECU has turned the wick down so I hope gogsyp can get it sorted.
sonny
Post by sonny » Sat Jun 20, 2009 9:13 pm
Top results there.
Klauster, what fuel was you running?
scaghead
Post by scaghead » Sat Jun 20, 2009 11:42 pm
klauster, it looks like the re map is working now then...
P_G
Post by P_G » Sun Jun 21, 2009 8:24 am
I'm pretty sure Klauster said his car was OEM and the map had been taken off?
klauster
Post by klauster » Sun Jun 21, 2009 3:31 pm
remap was removed at my request with Audi, I'm running 0090 software now, the car is OEM.
I may look at Exhaust and remap early next year. For now I will enjoy the car as is :D :D :D
For the record the work carried out on my car was:
Software update 0090
All sensors/Vacuum sensors checked, cleaned.
All pipes checked.
I have no reason to think the results on this day were incorrect, all cars seem to make sense of the figures, from OEM versions to tuned.
caldy
Dyno Trace
Post by caldy » Mon Jun 22, 2009 3:14 pm
Initial at JDE in Holland, post exhaust and re-map.
http://i271.photobucket.com/albums/jj12 ... AN0004.jpg
Dyno at Motoscope post inlet manifold mods.
http://i271.photobucket.com/albums/jj12 ... AN0003.jpg
Motoscope fuelling report.
http://i271.photobucket.com/albums/jj12 ... AN0001.jpg
RS4 B7 Phantom Black
Users browsing this forum: Google [Bot], vailpilgrim, Zyox and 206 guests
