Boost guage
rtd
RE: Re: RE: Re: Boost guage
Post by rtd » Tue Aug 04, 2009 9:54 am
i think this would look ok however depends if you could get it to work in the 6 only advertised for the B5
http://www.amdtechnik.com/product.detai ... nceID=1875
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
EnigmaRS6
Post by EnigmaRS6 » Sun Oct 18, 2009 11:24 am
Having never owned a turbo car without a boost guage Iam keen to install one. The link above shows a very neat install in the airvent has anyone done this on a C5? The vents look the same as ours so it should fit, right?
I will give them a call in the week.....
pete2144
Post by pete2144 » Sun Oct 18, 2009 12:53 pm
EnigmaRS6 wrote:Having never owned a turbo car without a boost guage Iam keen to install one. The link above shows a very neat install in the airvent has anyone done this on a C5? The vents look the same as ours so it should fit, right?
As far as I know the vents in the B5 are totally different from C5 vents.
Post by Shoppinit » Sun Oct 18, 2009 5:40 pm
Excuse my ignorance in boost guages, but how does measuring the vacuum tell you what boost pressure you are achieving?
Balchy
Post by Balchy » Mon Oct 19, 2009 10:04 am
I might be slightly diverting this thread, but I'd like a VAG.COM alike that could link to TV-in on the RNS.
Like the dashdaq here: http://www.rs246.com/index.php?name=PNp ... ic&t=72005 but output piped through into the existing head unit.
I found this: http://www.hksusa.com/info/?id=3474 but not sure how much info you could get from the RS6 OBD port. It might end up cheaper buying a 12V PC and using that!
jd_hants
Post by jd_hants » Mon Oct 19, 2009 10:29 am
Looks fantastic. Does GPS navigation too. If there is a Tuner add-in then that could replace my RNS-D unit which I'm thinking of replacing shortly.
