Dyno Results
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
curtis11
Post by curtis11 » Thu Dec 11, 2008 7:28 pm
[/quote]
I am pretty sure someone has installed some MRC magic in your neck of the woods by post![/quote]
i would doubt it , they would not sort me out with a map for my s4 and i am in n.ireland
S2tuner
Trader (Expired)
Post by S2tuner » Thu Dec 11, 2008 7:37 pm
curtis11 wrote: I am pretty sure someone has installed some MRC magic in your neck of the woods by post!
That could be because of a different reason....
vaudiw
Post by vaudiw » Thu Dec 11, 2008 9:08 pm
The remap I have is supposed to be good for 330hp, so the output calc via the MAF is not what I would expect.
Apparantly the RR wasn't using a wideband sensor so their readings could be out. But then if the car's not running lean it's still not putting out the expected HP. So something else maybe not right.
From what I understand if I had a boost leak it would be running rich. So can I discount that? Same with N75 valve? DV's?
I'll put a new MAF in anyway and see what that does.. :?
dazzer
Post by dazzer » Thu Dec 11, 2008 11:28 pm
vaudiw wrote:The remap I have is supposed to be good for 330hp, so the output calc via the MAF is not what I would expect.
I reckon that's a tad optimistic with everything else standard. Use VAG COM to log requested boost versus actual boost. Don't discount boost leaks. Try and get it pressure tested if possible. What DVs are on the car?
vaudiw
Post by vaudiw » Fri Dec 12, 2008 2:53 am
Thanks for all the feedback so far. Just picked up a new MAF and 2 710n DV's, which I will fit this weekend.
I don't have Vag-Com so have also purchased a cable from Ebay. So when that arrives I will be able to run logs alot easier.
I'm learning heaps, and apart from the stress of thinking my car was about to melt it has been interesting trying to work out whats going on..
As I've said previously we don't have S4 specialists such as MRC out here in the antipodes so its either the dealer or independent garages who are more generalists, or DIY. So its great to have this resource :)
curtis11
Post by curtis11 » Fri Dec 12, 2008 8:31 pm
well what would that reason be? i was told that the car must be brought to you
dazzer
Post by dazzer » Fri Dec 12, 2008 11:19 pm
vaudiw wrote:Thanks for all the feedback so far. Just picked up a new MAF and 2 710n DV's, which I will fit this weekend.
Let us know how the logs go. Good luck.
S2tuner
Trader (Expired)
Post by S2tuner » Sat Dec 13, 2008 12:46 am
If memory serves, your car is far from standard and is pretty much a stage 3, if that is the case, we very rarely accept to do mail-order remaps for anyone, in fact almost never.
tartan_rob
Post by tartan_rob » Sat Dec 13, 2008 10:10 am
RE changing the maf willy nilly. Unplug the old one first and if the car runs the same or better, the old one is shot. If not, save your money...
Minhea (and MRC) knows his/their stuff, if you like your engine the way it is (and not very ill), I would listen to them.
2017 Kawasaki Z1000
2014 RS6
2014 S1
curtis11
Post by curtis11 » Sat Dec 13, 2008 2:13 pm
S2tuner wrote:
curtis11 wrote:
S2tuner wrote: That could be because of a different reason....
i could understand that but my car is only stage 2 with a remap and cat back exhaust, i just wanted a stage 1 map.
sorry for the hijack , my bad
:oops:
vaudiw
Post by vaudiw » Tue Dec 30, 2008 9:46 am
I've now replaced the MAF and run some more logs.
Looks better but still not as good as I had anticipated. FAT time puts output at 275hp.
The boost looks OK, except the @ 2720 rpm there is a big difference between Specfiied and Actual. Any ideas anyone why this would be?
I've also logged grp 116 which showed 0% for Fuel, Lambda and Air Correction, so I assume this is good.
I'll log 20 and 21 to check the knock sensors.
Any other ideas or feedback would be appreciated...
Blue_Thunder
Post by Blue_Thunder » Tue Dec 30, 2008 10:57 am
The boost spec/actual looks fine there. The difference at low revs is because the turbos haven't had time to fully spool up. It's made peak requested boost on time and holds boost well. Nothing to worry about!
Using MAF reading/0.8, that equates to about 290bhp.
My FATS times are way slower than other people running the same power. The only thing which I think is different is mid-range torque. That will be down to the map.
It's difficult to compare FATS times with cars from other parts of the world as factors such as the quality of fuel and ambient temps could make a big difference.
Get it back on the Rolling Road and see what figures they come back with.
Users browsing this forum: No registered users and 139 guests
