alarms, imobilizers, anti theft etc
m5killer
Post by m5killer » Wed Oct 15, 2008 11:43 am
Lee@LMAudio wrote:Clifford have their black jax system, which could be fitted along with one off their alarms, a small touch pad is installed and every time the car is started a pin code must be entered, this can be programmed by the installer to a simple code so onlly a couple of presses are needed.
If no code the car will start and when the brake pedal is pressed cut the fueld pump bringing the car to a stop flashing and sounding!!!
it will only do the under 30mph so as to be safe
May be an option, you can put it in valet mode if you just want to pop into the shops etc
Hope this helps
Lee
lee i dont think you can put any clifford system on a rs4 b7, something to do with the canbus adaptor, none of the alarm companies have made one for the rs4 b7 but they have made one for the s4, i tried 5 months ago to get a pager put on my b7 it was a viper or hornet unit which is made by directed who makes all the clifford stuff, dont know if anything has changed hopefully it will as i want a second alarm on the car
Lee@LMAudio
Post by Lee@LMAudio » Sat Oct 18, 2008 7:18 pm
it can be done just a pain in the arse,
I have one on mine...
Also Clifford now make a Can alarm which will work and runs through the standard key, picke up all door inputs etc from the can signal
Lee
m5killer
Post by m5killer » Thu Oct 23, 2008 11:47 am
Lee@LMAudio wrote:it can be done just a pain in the arse,
Lee
lee can you give me some more info on that which clifford is it, model number etc thanks
Users browsing this forum: No registered users and 129 guests
