Airbox Mod
2.7 V6 30v biturbo - 380 bhp
gb
Post by gb » Thu Jul 03, 2008 12:39 pm
Lets clear a few things up now, before this thread goes skewy and confuses too many people.
The airbox is on the intake side of the turbo. Its the other side of the turbo that needs to be sealed properly to ensure boost is maximised and not lost. On the intake side can therefore be modified to maximise flow - provided the increased flow is efficient. This means accessing cold air from outside the engine bay, rather than sucking up the hot stuff from within.
The MAF will pick up on the higher air flow and the ECU will adjust fuel to maintain the prescribed mixture. The combined effect means greater air and fuel = more power :lol:
The subject mod would have you cut a hole in the face of the airbox that faces the opening to the inner guard and facing the louvres in the guard liner. This gives access to the ambient air and supplements the factory ducting. The louvres are angled in a way that minimises crap sprayed in - the balance is up to the air filter.
I have done this mod on mine and found the induction noise barely affected - its very modest and barely detectable. I haven't picked up any power gains either, but 3-4 hp would not be detectable from 'seat of the pans' in any case. Others have found gains on a dyno though.
hope this helps. :D
Regards,
GB from downunder
Durit
Re: RE: Airbox Mod
Post by Durit » Thu Jul 03, 2008 12:40 pm
Nige_RS4 wrote:This mod is for S4 airboxes, the RS4 airbox already draws in additional air from a secondary pipe, so I would question the value of doing it on your RS4 airbox.
that's right!
take a look at the "Self Study Program RS4" page 24 and 25....
the only thing you can improve is to put a fresh air duct in front of the inlet
other way, if it is always opened (if you cut a hole) you will have hot air intake (!) and you will loose the benefits of your dynamic induction....
PS: if you don't have the SSP RS4, i have it but i don't know how to upload it (pdf 11Mo)
RS4 mtm 460 "safety car", Milltek, Koni, Mov'it 6/380-4/322, teamDynamics wheels ------- S6 plus, mtm, H&R, Koni
I'm french (nobody's perfect) sorry for my bad English!
