Warning....check your cam lobes..
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Apr 10, 2008 9:49 pm
rolskii wrote:be good to look at yr oil pick up strainer ... see if its picked up anything to block or reduce oil flow/cause the lobes to wear prematurely also ....
(I got crank/rods pistons if needed..? couple heads too..)
look athe bore picture and look at that nice big crack down the bore - no way anything is getting rebuilt on that engine.
http://www.MRCtuning.com
DavidT
Post by DavidT » Thu Apr 10, 2008 10:00 pm
So what do you think caused the failure please Doug ?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Apr 10, 2008 10:11 pm
for whatever reason that cam has started to wear first and led to that damage. It is very unusual for one lobe to wear with no signs of the others starting to wear - so not the usual case of an unloved engine.
buzzard
Post by buzzard » Thu Apr 10, 2008 10:18 pm
bearing in mind it is the very front lobe...do you think that it is starved of oil due to the inertia of the engine or just down to crap cam material??
S4 B5 long gone
S4 B8 Stage 2
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Apr 10, 2008 10:21 pm
i would say crap cam material or flaw
S25MRS
Post by S25MRS » Thu Apr 10, 2008 10:33 pm
Excuse my ignorance, but are the cams checked as routine at any point? What I mean is, during cambelt service, etc? Just wondered if not, I assume it may be worth having them checked as a matter of course?
Mark
Current:
B6 S4 Avant
CBR1000RR-8
Gone:
2001 RS4
MV Agusta F4
buzzard
Post by buzzard » Thu Apr 10, 2008 10:34 pm
your not ignorant mate your wise.....
S4 B5 long gone
S4 B8 Stage 2
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Apr 10, 2008 10:40 pm
The cams are not usually checked unless you have a ticking, a misfire, or have leaking camcover gaskets... I usually look inside the filler cap and see one lobe - doesn't really help if you have buzzards issue though. It is also wise to check the oil pick, the turbo oil supplies, the play on the turbo shafts.... up but it is just not somehitng that is done on a regular basis otherwise ewvery inspection is a lot of money.
S25MRS
Post by S25MRS » Thu Apr 10, 2008 10:44 pm
I'll get you to check mine when my cambelt service gets done then......
Mark
Current:
B6 S4 Avant
CBR1000RR-8
Gone:
2001 RS4
MV Agusta F4
buzzard
Post by buzzard » Thu Apr 10, 2008 11:03 pm
just lookin forward to getting her back with a nice slice of bhp/torque and a sprinkling of MRC magic.
S4 B5 long gone
S4 B8 Stage 2
Blue_Thunder
Post by Blue_Thunder » Thu Apr 10, 2008 11:18 pm
Well, if confusionhunter get's his ass into gear... there's a replacement engine right there.
quattrokid1
Post by quattrokid1 » Thu Apr 10, 2008 11:49 pm
after seeing this I think I'll walk tomorrow!!
that is one hell of a mess there
hope your back up and running soonest
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro :):)
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD :( :(
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
rolskii
Post by rolskii » Fri Apr 11, 2008 1:38 am
u edited out my post :bash: .... at the bottom .... :assflash:
rolskii wrote:.. nor a cracked bore ......
never intended for the pictured lump ... :roll:
..... probably get £30 a block next door at the scrappy Doug ...?
happy dayz .... party ....
AdamS4
Post by AdamS4 » Fri Apr 11, 2008 10:37 am
Sorry to see this :( ... I've seen plenty of Ford engines do something like this but never a German engine.
Best of luck with the rebuild
JDB
Post by JDB » Fri Apr 11, 2008 10:45 am
Good luck with the rebuild
Users browsing this forum: No registered users and 40 guests
