Nitrous - Interested to hear about setups on RS & S Audi
imolas4uk
Post by imolas4uk » Sun Apr 13, 2008 12:00 am
:jump:
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
flashyg
Post by flashyg » Sun Apr 13, 2008 10:43 pm
Think he just knows how to mod cars, less interested in typing, thanks for sharing.
imolas4uk
Post by imolas4uk » Sun Apr 13, 2008 11:32 pm
yeah just havin a laugh :D
flashyg
Post by flashyg » Mon Apr 14, 2008 10:53 am
Lets hope his b5 stays in the garage otherwise we are toast.
rs-mad
Post by rs-mad » Mon Apr 21, 2008 1:44 am
Update - Received an email from Wizard Of Nos and to my suprise I was told that upto a 75hp shot on the RS6 being turbo there is no need for any timing <beep> as I intend to run it progressive ie 25hp@3000 50hp@4000 75hp@5000-6300rpm.
Does this sound right to you guys? I will be doing the usual ie colder plugs etc.
satanschild
plugs...
Post by satanschild » Mon Apr 21, 2008 6:46 pm
what plugs do you intend to use ..?
dont run multi point plugs either ...
if i have an old set kicking about still ill post the plug code up for you ...
but just to give you an idea .. all 6 sould cost you just over £10 you dont need platinum plugs or anything like that. you just want the biggest pure copper core you can get ..
as for your progressive controller.... what delay and build time do you normally run ...
i run a 150 shot with 0.4 sec delay and 0.8 build time ....anything more in my s4 and i dont get to see 100% before i shift....
won recon i should be running over a second delay and build time ..........
Na..... :lol:
rs-mad
RE: plugs...
Post by rs-mad » Thu Apr 24, 2008 4:44 am
Iridium Heat Range 8
I will be running a 75hp shot with the rpm based controller not sure if I will go with the controller that allows to adjust ramp in every gear individually
dummi
Re: RE: plugs...
Post by dummi » Thu Apr 24, 2008 9:06 am
rs-mad wrote:Iridium Heat Range 8
if your running big turbo's you might want to use it just to make up the lag in first only till you are making boost then progressive throughout the other gears. don't know what your set up is but that is what I would do to protect the drivetrain
rs-mad
RE: Re: RE: plugs...
Post by rs-mad » Thu Apr 24, 2008 11:14 am
Car is pretty much a standard RS6 with a custom tune and pre-cats removed :)
dummi
Post by dummi » Thu Apr 24, 2008 4:10 pm
cool, not knowing the drivetrain capability of the rs6, that is just my thoughts
satanschild
nos..
Post by satanschild » Thu Apr 24, 2008 7:22 pm
ditch the iridium plugs, the electrodes are tiny, you want a nice big juicy spark.. the biggest copper electrode, heat rating 9 and as long as it fits the thred in your heads thats what you want... As i said they wont cost you more than £15.. :D
what progressive controller are you useing ...?
rs-mad
RE: nos..
Post by rs-mad » Wed May 07, 2008 9:10 am
I am going to buy the FJO Mini.
mattysupra
Post by mattysupra » Wed May 07, 2008 9:22 pm
hello mate, im running a wizard of nos kit on my supra at the moment with 100 jets on a progressive controler. I have been speaking to the lads at wizards about the kit im fitting to my rs6.
Can i help you at all?
satanschild
controler ...
Post by satanschild » Thu May 08, 2008 11:35 pm
if you want a good controller "the best in my opinion" i have a wizards of nos maximiser that cost me £500 when i bought it a few years ago ...
going cheap if your intrested ???? i no longer need it :wink:
