Ok. here it is again.
Shock seals begin to fail and a small amount of fluid can be seen on the shocks. As the system pressure drops below 12 bar, the shocks will compress over bumps and such causing the car to roll and sway more than usual plus you may hear some knocking sounds coming from the 4 corners.
The shocks must be replaced. the system is bled under negative pressure to create a vacuum in the shcks and hydraulic lines. each shock is refilled under 5 bar of pressure and then sealed upon disconnect. Nest, the lines are filled under pressure and disconnected. Lastly, new central valves charged to 16 bar from the factory are installed and then connected to the already filled and pressurized lines/shocks.. when the pin is pulled, the 16 bar from the central valves pressurizes the entire system and you should see a system pressure of anywhere between 12 and 14 bar. Anything under 12 bar means incorrect refilling of shocks/lines. and must be redone.
ANYTIME YOU REPLACE/REFILL ANY SHOCKS YOU MUST ALSO REPLACE THE CORRESPONDING CENTRAL VALVES. Do not let your mechanic tell you otherwise. Most of them dont know this and its what has caused so much dissatisfaction with faulty repairs. This plus improperly drained and recharged shocks/lines leting air in the system.
Audi is reportedly coming out with a DRC kit that will allow dealers to refill the central valves in house rather than having to order them from Germany each time. This will cut the costs of repair alot. But, the main thing here is to note that while Audi is fully aware of the faulty shock design, they are not going to redesign the part for such a small number of units, so they will continue to offer these faulty ones to us which will eventually fail again. So, either we continue to pay for these repairs or go aftermarket with Pss9's etc.
DRC - is their an easy fix?
Jump to
- General Discussion Forums
- ↳ Welcome Area
- ↳ General Car Chat
- ↳ Trackdays and Meets
- ↳ Spotters Forum
- ↳ Adversaries
- ↳ BMW M & Alpina
- ↳ Jaguar R
- ↳ Mercedes-AMG
- ↳ Nissan GT-R
- ↳ Opel VXR & HSV
- ↳ McLaren
- ↳ Porsche
- ↳ Volvo S60 Polestar
- ↳ Other
- ↳ Audi S and RS Ownership
- ↳ DTC / VCDS
- ↳ Electrical
- ↳ Cleaning & Car Care
- ↳ Readers' Rides
- ↳ Off Topic Chat
- ↳ Cars
- ↳ Parts
- ↳ Group Buys
- ↳ Other
- ↳ Ads Up To End Of 2010
- ↳ RS2 (B4) 1994-1995
- ↳ RS3 (8PA) 2011-2012
- ↳ RS3 (8VA) 2015-
- ↳ TTRS (Mk3 Typ 8S) 2014–
- ↳ RS4 (B5 Typ 8D) 1999-2001
- ↳ RS4 (B7 Typ 8E) 2006–2008
- ↳ RS4 (B8 Typ 8K) 2012-2016
- ↳ RS4 (B9 Typ 8W) 2017-
- ↳ RS5 (8T) 2010–2015
- ↳ RS5 (F5) 2016–
- ↳ RS6 (C7 Typ 4G) 2013-2018
- ↳ RS6 (C8 Typ 5G) 2019-
- ↳ RS7 (4G) 2013-2019
- ↳ RS7 (C8) 2019-
- ↳ RS Q3 (Typ 8U) 2013-
- ↳ RS e-tron GT (J1) 2020-
- Audi S Discussion Forums
- ↳ S Forums (Up to 1997)
- ↳ S1
- ↳ S2
- ↳ S4 2.2 / S4 4.2
- ↳ S6 / S6 Plus
- ↳ S1 (Typ 8X) 2014-
- ↳ S3 (Typ 8L) 1999-2003
- ↳ S3 (Typ 8P) 2006-2012
- ↳ S3 (Typ 8V) 2013-
- ↳ TTS (Typ 8J) 2008-2014
- ↳ TTS (Typ 8S) 2014-
- ↳ S4 (B5 Typ 8D) 1997-2002
- ↳ S4 (B8 Typ 8K) 2009-2016
- ↳ S4 (B9 Typ 9L) 2017-
- ↳ S5 (B9) 2017-
- ↳ S6 (C5 Typ 4B) 1999-2003
- ↳ S6 (C6 Typ 4F) 2006-2011
- ↳ S6 (C7 Typ 4G) 2012-2018
- ↳ S6 (C8) 2019-
- ↳ S7 (Typ 4G) 2012-2017
- ↳ S8 (D2 Typ 4D) 1992-2002
- ↳ S8 (D3 Typ 4E) 2002-2009
- ↳ S8 (D4 Typ 4H) 2010-
- ↳ SQ2 (MQB) 2019-
- ↳ SQ5 (Typ 8R) 2013-2017
- ↳ SQ5 (Typ FY) 2017-
- ↳ SQ7 (Typ 4M) 2016-
- ↳ SQ8 (MLB) 2019-
- ↳ Circuit Days
- ↳ Destination Nurburgring
- ↳ EM Tuning Products
Users browsing this forum: No registered users and 138 guests
