JD, RS4 0-60 and 0-100 Times
RS4-Junkie
Post by RS4-Junkie » Wed Oct 10, 2007 7:01 pm
ok, 5,83sec in Detail here :D measured with external GPS Datalogger ;) Any higher tests until 160mph?
youry
Post by youry » Sun Oct 14, 2007 1:58 am
turbo,
can you say you have felt the difference between std and remapped motronic ? I guess not ?
t_urbo
Post by t_urbo » Sun Oct 14, 2007 11:38 am
youry wrote:turbo,
Yes you can feel the difference, the main reason being the throttle bodies only opened 50-60% in gears 1-3 below 5500 rpm and the remap allows 100% throttle in these gears at any RPM.
Im happy with the remap because its made the engine more flexible in that the cold max rpm is now set lower, the throttle bodies are open 100% of the time, the speed limiter has been set to what i want, Hp and Torque are improved through cam/timing adjustments and not overfuelling,the exhaust flaps are open 100% of the time in Sport mode and it only cost 990 euros.
Oh and Jeroen upgraded the software version to the latest one (that being 80 at the ime) FOC.
youry
Post by youry » Mon Oct 15, 2007 7:46 pm
t_urbo wrote:
youry wrote:turbo,
interesting indeed. I had mine upgraded with new software at my dealer (indeed its 0080).
what was the difference in power and torque beofre and after, the ideal would be to have the power/torque plots... could you send them to youry@rsquattro.com
t_urbo
Post by t_urbo » Mon Oct 15, 2007 8:05 pm
Youry here's the before and after dyno plots.
1st map is 3rd and 5th gear plots before and after.
Light Blue is 3rd gear Pre Remap.
Dark Blue is 3rd gear Post Remap.
Green is 5th gear Pre Remap.
Red is 5th gear Post Remap.
The 2nd map is 5th gear before the remap.
The 3rd map is 5th gear after the remap.
Will email you them also.
youry
Post by youry » Tue Oct 16, 2007 10:26 am
Thanks, I got them. that was quick.
Living in belgium that is not far for me. pricing is reasonable (for a change). i wonder why AUDI is constraining so much the engine in lower gears....
binder
Post by binder » Tue Oct 16, 2007 10:33 am
I think a well run in standard RS4 can expect to do 0 - 60 in 4.6 secs. The factory figures are usually conservative with Audi's and I am pretty sure that the detailed Autocar road test achieved 4.6 secs (top speed 163mph as I remember. If I had not lost the issue I would give the 0-100 time etc.
AntoRS4
Post by AntoRS4 » Tue Oct 16, 2007 3:08 pm
turbo,
same air filter between original "pre remap" dyno plot and "post remap" one ?
t_urbo
Post by t_urbo » Tue Oct 16, 2007 6:23 pm
AntoRS4 wrote:turbo,
Same air filter.
I dont believe after market filters flow better than stock items (when the stock item is new /clean) and im not wanting to replace the MAF just yet.
AntoRS4
Post by AntoRS4 » Wed Oct 17, 2007 9:20 am
Turbo,
do you know about ch.211 ( Adv. meas. VAG-COM) ? it's very interesting... is it possible for you to make a 3rd gear launch and log that channel ?
g/s measured, g/s expected, MAF Ratio, intake abs. pressure
i think it's a good way to evaluate tuners job :)
t_urbo
Post by t_urbo » Sat Oct 20, 2007 7:33 am
AntoRS4 wrote:Turbo,
I found this log for g/s measured. 1st column RPM, 2nd Std RS4 3rd Gear,3rd Remapped 3rd Gear.
RPM MAF(Std) (after remap) g/s
7160 141.72.. 151.22
7240 142.86
7360 _______ 152.5
7720 149.31.. 158.47
8080 _______ 170.36
A/F Ration is spot on.
Leans out off load.
Under load Actual and Specified are the Same at 0.88 throughout.
mixja
Post by mixja » Sat Oct 20, 2007 11:10 am
NZ Autocar managed 0-62 in 4.62s on a stock RS4 - very quick...
Interestingly they could only manage 4.95s in the new M3...
Ritchy
Post by Ritchy » Sat Dec 01, 2007 9:43 pm
My RS4 has also been remaped by JD!
Very happy with the results ! initialy 394HP and 430 of torque. Sedan RS4 10000km unleaded fuel 98. Would have about 8HP more with shell V power 100
t urbo: do you have a special full exhaust system ?
sonny
Post by sonny » Sun Dec 02, 2007 2:44 pm
t_urbo wrote: Yes you can feel the difference, the main reason being the throttle bodies only opened 50-60% in gears 1-3 below 5500 rpm and the remap allows 100% throttle in these gears at any RPM.
WOW that must feel a lot different, and in my opinion would be worth the upgrade, so does this put extra strain on the clutch?
Have they removed the 155mph limiter?
t_urbo
Post by t_urbo » Sun Dec 02, 2007 3:24 pm
I dont see how it will put any extra strain on the clutch, if you launch the car above 5500 rpm then you have full throttle even without the remap. The extra 20 ish HP you gain overall is unlikely to have any major effect on it either.
I have done over 30 standing starts measuring times and stuff and its still hanging in there.
They will set the limiter to any speed you want. Mines set at just over 200 mph.
Users browsing this forum: No registered users and 386 guests
