Alarm Beep and Auto Lock... (Can't get it working..)
PetrolDave
Re: RE: Re: RE: Alarm Beep and Auto Lock... (Can
Post by PetrolDave » Sat Sep 22, 2007 6:35 pm
shineydave wrote:i'm not convinced that back up battery is the correct term. if it was a back up only then the alarm would still work if the battery was Donald.
Backup is the term used by the electronic bods that design these things (I've been one of them for over 30 years...).
There's 2 ways of wiring a backup battery:
- one where either the incoming power OR the battery powers the alarm. Good point is that the alarm will always work, bad point is that you don't know when the battery has died.
- and one where the incoming power goes via battery. Bad point is that the alarm won't work when the battery dies, good point is that you know when the battery has died!
Return to “DTC / VCDS”
